Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
Fuel line replaced wont suck gas through line
  • 27 Answers
It may need a carb kit if you run ethanal gas it drys the rubber parts out or if there was dart or trash in the gas tank it could be the wire filter in side of the carb got clogged
Posted on Mar 07, 2015
    Habit-Forming:
  • 88 Answers
Hav eyou tried priming the line with fuel before fitting?
Posted on Nov 26, 2013
My l100 wont start but when i put gas in carborator it runs till gas is gone
Not 100% sure but the fuel is either blocked or the line may have a tap that is turned off. Check to see if you have an in line tap that turns 90 degrees, the ears of the tap should be inline with the fuel line, also check to see if the fuel line is pinched or if it was sucked of fuel causing it to collapse. Hope this helps
Jul 15, 2016 | Garden
I ran my 2003 f250 super duty out of gas and ever since it has no power,it wont run over 10 mph but its getting plenty of gas
If it's a Diesel engine, your gonna have to bleed you fuel line because there is air that got in to your fuel line. If it's a gasoline engine, well I'm guessing there must be something blocking your gas line, some sediments must have been in the bottom of the tank and it got sucked in your lines. I would start by changing the gas filter first and go from there.
Apr 26, 2016 | Cars & Trucks
Location of fuel pressure regulator on 2006 dodge caravan 3.3
Replace fuel pump and filter that is not a regulator problem.
Bad fuel regulator will cause vehicle to surge at cruise speed or they leak and cause engine to suck excessive fuel into intake if vacuum control then blows black smoke.
Jan 24, 2015 | Dodge Cars & Trucks
What do I do I ran out of gas re fueled now it wont start Etec 50 1997?
Check and make sure your fuel filter isn't clogged up. Alot of times when you run a tank dry you will suck trash into the fuel line.
Sep 01, 2014 | Cars & Trucks
Flooding starting
Check fuel pressure. You may have a bad fuel pressure regulator. Pressure may be too high, or the regulator diaphragm may have failed-if it is vacuum operated, pull off the vacuum line-if any evidence of gas in the line, the regulator has failed, and letting gas get sucked into the engine through the vacuum line. That could explain the gas smell and the flooding.
Dec 26, 2013 | Land Rover Discovery Cars & Trucks
I have a 124l e-tech trimmer and the prime bubble wont fill
Sounds like you have an air leak. Either in the primer bulb is split or punctured, hole or leaking fuel line or primer bulb base, and is sucking air instead of fuel.
Aug 20, 2012 | Husqvarna 124L 28cc Gas Line Grass Lawn...
RAN OUT OF GAS, I THINK..PUT GAS IN STILL WONT START... FUEL PUMP MAYBE ?
When older vehicles are driven to the point of running out of fuel, the deposits in the tank are sucked into the line and clog the filter and the line. On a 13 year old vehicle, I'd say you probably had this happen. You may be able to clear the debris by removing the gas cap and putting a small amount of compressed air backwards through the system by removing the line that feeds your fuel rail. put the air into the line slowly and have someone listen near the tank. After a while the debris will be cleared of your lines and backflushed through the filter. Gas should flow freely after that. Change your fuel filter asap though after it's running again. Or yes, it could be the pump.
Nov 14, 2010 | 1997 Jeep Grand Cherokee
PRIMER BULB WONT **** FUEL INTO BULB. NO HOLE IN
Run a small paperclip into the fitting that the fuel line is attached to on the back of the primer bulb and make sure it is clean. Then go to the other end of the equation and make sure that the fitting is cleaned out on the carb where the fuel line attaches. Hope this helps and good luck.
Jul 11, 2009 | Garden
Car wont start
When i replaced my fuel filter before and fired it up the gunk from the bottom of my tank got sucked into the filter blocking it up. Try checking the fuel lines are clean.
Dec 25, 2008 | 1998 Lincoln Town Car
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
131 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
