Question about Asrock ConRoe945PL-GLAN (4711140874418) Motherboard
No display (black screen)when i put a radeon hd 5450 (pcie 2.1) on asrock conroe 945pl-GLAN how can this be solved?
I ve tried to replace a graphic card in a pc with a mother board asrock conroe 945 pl-GLA i give a new one club radeon hd 5450 noiseless edition and start computer but the screen is black i tested the same graphic card on other pc and it works with out problem i update the bios to latest without result same black scre en
  • 2,113 Answers
I was swapping graphics cards and i had the same problem. I just had to be persistent. I had to try booting up i heard some error beeps. I waited 5 minutes to give the bios time to update i rebooted two or three times more before it worked
Posted on Nov 26, 2013
lolita
  • 385 Answers
SOURCE: ASRock K7S41 no boot screen at all
Try plugging the monitor to the onboard video card and then enable the graphic card in cmos settings.
Posted on Mar 17, 2007
syedmujahed
  • 158 Answers
SOURCE: CPU OR Motherboard
its your motherboard problem if its have a warranty then send it to the asrock service centre if not then repair it
Posted on Sep 27, 2008
discovervinu
  • 3 Answers
SOURCE: Which latest Graphic card can be supported by my Asrock P4i45GV?
Hey dude Try to find the drivers in the Asrock homepage and search for Word 'p4i45gv' or try to google the same I'm sure U will get the drivers and Mobo compatible Graphics cards list also.
I would prefer Nvidia Fx5500 graphics card which has 256Mb onboard Ram, And All NFS series works fine for me. wid dis Mobo.
Posted on Mar 20, 2009
SOURCE: ASRock Wolfdale1333-D667 and Radeon 5770 graphic card
Same issue here with ASRock 1333 GLAN and Radeon 5770 Sapphire... No solutions...
Posted on Nov 18, 2009
rajeshpait
  • 542 Answers
SOURCE: getting on board vga video to work on asrock
As per discription provided by you, Suspect the physical RAM is having problem. Check and insert the RAM properly may solve your problem.
Hope the above solution may resolve your problem. Please give us the feedback on the solution to provide the best resolution in future.
Revert Back for more assistance or clarifications.
Posted on Dec 26, 2009
Screen occasionallly flashes black for 1-2 seconds at a time winXP
is it intermittent or possibly this happen when you change some settings in your pc, try another monitor to isolate the problem, screen usually turns black in windows when you change some settings. you have good graphics why not upgrade to higher version of OS it is possible also that your encountering compatibility issues
Jan 30, 2014 | XFX Ati Radeon Hd 5450 1gb Ddr3 Pci...
Driver download
http://support.amd.com/en-us/download
Step 1: Desktop Graphics
Step 2: Radeon HD Series
Step 3: Radeon HD 5xxx Series PCIe
Step 4: seclet your current Operating system.
Click "display results"
Oct 21, 2013 | XFX HD-545X-CDH2 HD5450 2GB DDR3 64Bit...
Hp 7900 usp make problems when i connect ati radeon hd 5450
your hp only has a 350 watt power supply, you need at least 400 watt, preferably 450 - 500 watt.
Jul 19, 2013 | Computers & Internet
Graphic card
Yes provided the expansion slot on the motherboard can fit this graphics card. If your motherboard has a built-in graphics chip then you most likely need to disable the on-board graphics before installing this graphics card and driver..
Sep 05, 2012 | Jetway JI31GM4-L-LF Motherboard
My ati radeon 5450 series card getting overheat
you could be pushing the video card to its max, and/or there might be something wrong with the heatsync fan
Jun 28, 2012 | ATI RADEON HD 5450 DDR3 PCI Express (PCIE)...
PC wont boot
Check your specs for this one on your Card (should be on the box or in your included documentation), but I believe your card is PCIE v2.1. If this is the case, your card won't work. Your mainboard is an older one, and you can tell by the black PCIE slot that it is only PCIE 1.0. NOTE: PCIE v2.0 cards will work with PCI v1.0 as long as they meet power requirements, etc. (yours should be fine) but there are no updates to fix this on your mainboard. Time to dig out your receipt and look over the return policy. Again, a PCI v2.0 should work OK, just not the v2.1 cards.
Please take a moment to leave feedback if I helped you out today.
Jan 27, 2012 | Sapphire RADEON HD 6750 1 GB DDR5...
My computer will not recognize my video card. My PC is a Compaq Presario SR5233WM and the video card is a Radeon 5450. The card is firmly in the PCIe slot, and i've set in the BIOS the video to PCIe x 16...
Do you get any display at all? If so then it's needing a driver. If it isn't working at all then:
1. it's in the wrong slot - slot won't support it. Double check the board specs. Some versions say it's supported but it really doesn't.
2. (without my looking at the mother board manual...) is there an onboard video card? If so there could be conflicts. You'd have to disable the onboard video and try it.
3. the radeon is bad.
If the board supports it etc you should be getting some kind of display even if the resolution is low. (then you'd need to adjust it). However if you aren't getting any output then it is one of the things listed above.
May 03, 2011 | Gigabyte RADEON HD 5450 PCI Express Video...
My hardware does not work properly.
Have you installed the latest video drivers for it. With the correct and up-to-date video drivers the card will run more effectively and the way it should.
Just go to the AMD download support website.
Step 1) Desktop Graphics
Step 2) Radeon HD Series
Step 3) Radeon 5xxx Series PCIe
Step 4) Then select your operating system
Then click Display Results.
Download the Catalyst Software Suite, it should be around 52.2MB.
Mar 05, 2011 | MSI R5450-MD1GD3H/LP RADEON HD 5450, (1...
What is the cost of Radeon HD 5450 1GB DDR2 PCIE HDMI and .......
Amazon show a XFX ATI Radeon HD5450 1 GB DDR3 VGA/DVI/HDMI Low Profile PCI-Express Video Card HD545XZCH2
For $34
Amazon com XFX ATI Radeon HD5450 1 GB DDR3 VGA DVI HDMI Low Profile PCI...
eBay shows one USED for $19
XFX ATI Radeon HD 5450 HD 545X ZQH2 HD545XZQH2 778656056176 eBay
GOOD LUCK getting a seller to ship to India! Have a friend in the US buy one and let THEM ship to you!
Anthony
Jan 07, 2018 | ASUS Computers & Internet
Actually, one thing. Intel motherboards, like your Wolfdale is an Intel board, they don't work with AMD graphics cards. I've seen this arise many times, the graphics card is AMD and your MOBO/CPU is Intel... that's a red flag in my book automatically. Take it back and try an Intel Graphics card.
Oct 20, 2009 | Asrock P4I45GV R5 Motherboard
Asrock ConRoe945PL-GLAN (4711140874418) Motherboard Logo
219 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
pankaj rautela
pankaj rautela
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
