Question about Refrigerators
Not cooling in fridge,fridge temperature in freezer
    Top Expert:
  • Refrigerators Master
  • 12,962 Answers
Self defrost mechanism has a problem. Check the defrost timer and defrost heater element for proper operation. Ice buildup is the culprit.
If you unplug and defrost overnight, replug, it will work fine till the ice builds up again.
Posted on Nov 27, 2013
HVACRH20
  • 237 Answers
SOURCE: fridge freezer not cooling from new - buttons not working
Sounds like an air flow problem from the freezer section to the refer section. Check that nothing is blocking the air vents, and that the dampers are operating properly (they control the flow of air). Of course if it's under warranty... call the service techs out.
Posted on Nov 09, 2006
SOURCE: fridge tempertature
I have the same symptom too - freezer temperature flashes at -2. "Power Freezer" or setting it to any other temperature is not working either.
As a result, no ice being made. Please help!
Posted on Sep 01, 2008
miket756
  • 2702 Answers
SOURCE: the fridge temperature display of my samsung
its likley to be the thermostat packed up on you, the only fix is a new thermostat fitted,,,
Posted on Oct 28, 2009
SOURCE: Samsung cool n cool fridge
fridge is not getting cold freezer is ok
Posted on Jan 26, 2010
SOURCE: Electrolux ER 7626 Fridge not cooling
On these units there is a defrost heater which comes on after about 12/14 hours running time depending on usage.It would cut in for about 15 mins just to get rid of ice accumulated around the Evaporator.This heater or the timer has failed and ice has got between the duct. supplying cold air to the fridge unit.The best thing to do is to defrost unit for 24 hours and then try it and see if you can feel cold air coming up into the fridge.The repair for this is not that successful and you would be better off defrosting unit like a normal fridge/freezer.
Hope this was a help.
Posted on May 12, 2010
Refrigerator cooling defrost freezer
Buy a freezer thermometer from any supermarket, it has a guide.
Red light on for High Freezer Temperature Warning
or freezer not cooling, but fridge is and a lot of noise from compressor.
Also, fridge drain hole blocked, water in bottom of fridge.
This is a common fault in Hotpoint Fridge Freezers and can also happen if the door has been left open or has been a power cut.
1. Turn off fridge freezer, or at least turn down the freezer temp to minimum, though not ideal.
2. Open freezer door and remove all drawers.
3. Remove the back panel on the inside of the freezer. This is held in place with 4 screws, which might be 6mm hex head or star allen head. Pull the panel out.
4. Behind where the panel was, there is a cooling element for cooling, pipes, and below this a temperature sensor. If the fridge freezer is not switched off, then fold together a few layers of tinfoil and wrap around the sensor.
5. Use a hairdryer to slowly melt the ice. Melt it around areas where it appears to be hanging on, such as the corners of the cooling element or bolts, as well as any thin sections below the main block of ice around the cooling element, which will be supporting the main block. Use a plastic ice scraper to remove ice but not near pipes or sensor.
Warning: Be careful using electrics around water & melting ice & drips.
6. Below the cooling element, there is a drip channel & drain hole. If this hole is full of ice, pour a small amound of warm water down, leave for 10 seconds and pour a bit more until clear.
In the fridge, clear the drain hole in the same way.
Warning: Do not pour a lot of water down, as this water drains onto a tray above the hot compressor at the rear of the fridge freezer to be evaporated by the heat of the compressor and the tray will only hold a small amount.
7. When all ice is removed, dry all moisture. Put the shelves back. Close door. Turn on fridge freezer. Turn up the freezer temperature to your normal setting. Turn on fast freeze if available. After 1 hour, check with a thermometer. It should be cold enough after 1 or 2 hours.
Nov 20, 2013 | Kolpak SK8-818-CI
I have a samsung SR-S2028cvw American style fridge freezer. The temperature on the dials are at the coolest but both the fridge and freezer are warming up to the warmest temperature before the motor kicks...
Try hoovering the cooling rad on the back of the fridge freezer, as this tend to clog up with dust and other matter, which reduces the cooling efficiency
Feb 28, 2010 | Samsung Refrigerators
Fridge compartment is not cooling down to set temperature
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Jul 08, 2009 | Refrigerators
MY FREEZER IS GETTING TOO COLD AND THE FRIDGE IS NOT GETTING COLD AT ALL
In most refrigerator freezers, the refrigerator gets its cold from the freezer. The evaporator fan circulates air over the coils in the freezer and cold air circulates into the refrigerator through vents. If the vents are blocked or closed, then the fridge will not get cold enough but the freezer will. If neither is cold enough, then the number of possibilities increases.
Lowering the freezer temperature will increase the cooling cycle activity. Setting the refrigerator temperature may have little affect on the cooling cycles because it simply changes the vent opening size. Decreasing the fridge temperature opens the vents more and increases air circulation from the freezer.
The temperature can be adjusted using the controls found inside the refrigerator or freezer. The ideal freezer temperature is about 0 to 5 degrees (F) and about 38 degrees (F) for the fridge.
Measure the temperature by placing a cup of water with a cooking thermometer into the refrigerator for about 2 hours or more. To test the freezer, substitute alcohol or cooking oil.
Oct 08, 2008 | Whirlpool Refrigerators
Fridge tempertature
Aug 03, 2008 | Samsung RS2630SH Side by Side Refrigerator
Fridge and Freezer losing cooling
we bought a f&p fridge freezer and in summer noticed it wasn't cooling and the freezer wasn't freezing, when the service guy came out he noticed our ducted air con was blowing onto the fridge, once we had redirected the air con outlet the fridge started working as normal, apparently f&p's work on air being convected around the cabinet of the fridge and air blowing on the fridge can effect the temperature of the convected air. hope this helps you or someone
Nov 23, 2007 | Fisher and Paykel Active Smart E522B...
Refrigerators Logo
99 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
