Hi,Someone was going to give me a magnavox flat screen.Not sure what was wrong with it,but I turned it on,and theres a picture.Was a little greenish spotty on the whole right side about 4 inchs in.Then it seemed to dissapear somewhat.And then I noticed a top to bottom dark spot slowly creeping across the screen from the left to the right..Kinda like a wand moving over it slowly.. Is this something that can be easily fixed?Or any ideas on what to do or what it might be?Thanks,Scotty :)
  • 6 more comments
  • Scotty Houge Nov 26, 2013
    it is a 32 inch flat screen i believe.
    It wasnt on cable when i checked it.Just turned on and the menu came on.Nothing else is hooked up to it.What u mean by switch inputs?
    Add a CommentIt wasnt on cable when i checked it.Just turned on and the menu came on.Nothing else is hooked up to it.What u mean by switch inputs?
  • i meen the ic what switchd the inputs on tv set
    Oh ok.I know my kid used it for video gaming alot.But it started acting up afterwards..humm
    Its like a black cloud goes over the screen.And it moves from left to right.You can see the rest where the cloud isnt at.
  • sorry i must see the problem but i think maybee a pdp panel problem if it a plasma tv or y drive
    Guess i don't know between plazma and the other.It was a kmart flat screen tv about 2 years ago he bought it.Ok thanks for your help :)
  • 68 Answers
Hi maybe you heave ghost picture of some equipment what you heave ketch on tv set like a pc or dvd recorder or you heave a problem with a signal board it not switch of inputs on your tv
Posted on Nov 26, 2013
Testimonial: "It wasnt on cable when i checked it.Just turned on and the menu came on.Nothing else is hooked up to it.What u mean by switch imputs?"
4 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: I have a Flat screen
Are the lines all the way across the screen? or just a few? Solid black - or trannslucent?
Like this??
Horizontal drive has either data, voltage, or control problem from the pixel registry circuit......get it serviced before the problem spreads causing further damage.
However, in all likelyhood, the panel itself is bad. The Bravia line has had a bad rap about the faulty displays, and at $1800 replacement (plus labor) - it may be time to call SONY direct to complain!
Thanks!!
nc
Posted on Apr 02, 2010
Raditronic
  • 196 Answers
SOURCE: My 4 1/2 year old Sony KDF-42WE655 TV is on its
NEED A NEW OPTICAL BLOCK UNIT AND CLEAN THE DUST IN FANS
Posted on Apr 22, 2010
SOURCE: I have a Sanyo 46 inch flat screen hdtv purchased
I have the same problem, my television is faded black on the left side with lines on the left top side. I have had the 46 inch unit for 1 year and 7 months. I am planning to write a demand letter to Sanyo and then taking them to small claims court woth evidence that this is a common problem with their units that they know about and is not trying to remedy. Also the Attorney general in Texas should have an interest in them (Walmart and Sanyo) selling these defective proucts in the state.
Posted on Jul 28, 2010
I have a Magnavox 55" Led Tv it will play about 2 or 3 seconds then the picture messes up for about a second and come back on,keeps going in and out,I replaced the main board but didn't help.
Hi Bill,
this sounds more like a timing fault than a main AV problem, I would suspect a faulty T-Con board to be giving this fault, you could try to catch the fault in an image and post it here someone may have had a similar experience.
Feb 13, 2016 | Magnavox Televison & Video
Vertical line on screen
Hi, This is a problem that's far too common among flat-panel and projection LCD TV's?and it's generally known as "vertical banding." If the lines are there all the time or intermittent but in the same location it is an indication of a bad panel. The panel driver can also be the cause of this symptom. Samsung panels have had issues with the connector that carries the LVDS signals to the panel itself, this is not serious and can be resolved and little cost. These faint vertical bars (often most apparent when the screen is totally dark or displaying a solid background, like the sky) are defects that occur during the manufacturing process, and while the worst offenders are typically screened out, many more make it to store shelves. Since you've pinpointed the banding and it's driving you nuts,also its under warranty, call the manufacturer and demand a replacement; in most cases, they'll capitulate and send you a new set, although you'll probably have to go to the trouble of packing and shipping back your defective TV (make sure the manufacturer covers your shipping costs). Regards sreejith
Jul 30, 2007 | Philips Magnavox 42MF521D/37 Television
Hi we have a 720 Magnavox flat screen tv that is about 5 years old. When i went to turn it on the other day the picture started flasing and making a chirp noise.. and won't fully
power supply problems does it have a separete power supply if so you can try to change or if you have someone with the same you can ask to try it.if its internal power supply it needs to be fixed.
Aug 20, 2012 | Magnavox 37MF437B37 37 in TV
Magnavox 32MF231D/37
Hold a flashlight up to the tv while the tv is on. If you see a picture your CFL is burnt out.
Mar 21, 2009 | Philips Televison & Video
Sound but no picture
GE TV CTC 203 the oicture is very cloudy
Dec 14, 2008 | Televison & Video
No Picture, No Sound
You can get a repair kit from www.magnavoxhelp.com for under 30.00 dollars.
Jun 15, 2008 | Philips Magnavox 51MP392H Rear Projection...
NO PICTURE HAS SOUND
When you say small do you mean shrunk up top and bottom as well as from side to side. You definitely have a deflection problem either horizontal or vertical.If the picture just shrunk top and bottom you have a vertical deflection problem. Do you have the service manual for your model? If not let me know and I will email you one. Describe the shrinking issue a little more and I should be able to give you some guidance.
Feb 06, 2008 | Philips Magnavox 9P6034C 60" Rear...
RCA 52inch TV
If the screen control for the green picture tube is set too high, then the colors will be greenish, there will be green where there should be black and there will be fine curved lines (retrace lines) in the picture. If you feel confident then you can open the set and look for the focus block which has the 3 focus and 3 screen controls. One row is labeled Screen and the green control will be the center one. Try turning that control down a little and see is the green background and curved lines go away. If they do not go away then there is something more serious wrong. If you do not have experience working on projection sets then allow a qualified tech to handle it for you.
Jul 13, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Open Questions:
Televison & Video Logo
Top Televison & Video Experts
