Don't know how to refill a Dell M4640 ink cartridge
I need to find out where the refill hole is on a Dell M4640 ink cartridge.
  • 413 Answers
Kindly visit the link your problem would be resolved automatically
http://www.ims-ink.com/pdf_files/english/IMS%20Ink%20Manual.pdf
Posted on May 08, 2009
Refilling procedure
You need to specify what brand is your printer.But the procedure is as simple as dirty. Make sure you have a cloth or paper to handle the messy part :).
Requirements: 1. Printer-Ink 2. Syringe with thin needle3. Piece of cloth
I will write how to refill HP cartridge, because I don't know your model.Ususally Hp cartridges have colored or black spot ont white sticker.Under this spot there is a tiny hole. This hole is designed to be used for refilling. You need to pierce the spot with the needle and start the refilling process.Make sure that there are no bubbles in the syringe and start filling slowly the cartridge. Do not hurry! Don't fill the cartridge to its full capacity. If your cartridge is 20ml fill only 15 or 16ml.After you finish set aside the cartridge for 30 minutes so that the ink settle. This is it!Good luck!
Dec 19, 2011 | Office Equipment & Supplies
I don't know how to refill?
Refilling HP color printer ink cartridges saves money and time spent running to the store to find the right ink cartridge, which sometimes is out of stock. By having the refill kits for the HP ink cartridge, you can just refill the cartridge when the ink runs out. The refilling process is easy to do and anyone can do it in a few minutes. The ink kits come with directions and all the colors one will need to refill the ink cartridge.
1.Place a piece of paper towel on a flat surface. Remove the empty ink cartridge from the printer. To do this, open the cover and wait for the ink dispenser to move the ink to the open door. Lift up the tap that holds the ink cartridge in place and pull out the cartridge. Push the tap holder back down and close the cover.
2.Place the ink cartridge on the paper towel. Gather the ink refilling kit together with directions and place the ink jars on the paper towel along with the syringe needle.
3.Find the indents on the top of the empty ink cartridge. Poke these holes open with the pen. Sit the cartridge down and open the ink containers. The colors are yellow, cyan and magenta.
4.Read the directions to see where each color goes in the ink cartridge. Insert the syringe needle into the ink container and raise the stopper up until you have the recommended amount of ink to fill into the particular hole.
5.Insert the needle into the hole on the ink cartridge and slowly dispense it into the cartridge. Remember to go slow with this step. If you see the ink oozing out, stop filling and wipe with a paper towel.
6.Cover the holes with the tabs that come in the refill kit or you can use tape. Make sure the hole is sealed to prevent spilling or the ink drying up. Then replace the ink cartridge back into the holder in the printer.
I hope you find it very helpful. Thank you for using fixya.
Aug 22, 2011 | HP PSC 1315 All-In-One InkJet Printer
Can you refill dell series 21 ink cartridges?
Any ink or toner cartridge is refillable, For ink cartridge, check for the small pin hole at the top of the cartridge to inject the ink refill. But remember that the ink should be compatible with your ink cartridge model. Good luck
Jan 05, 2011 | Office Equipment & Supplies
Don't know exactly where to drill a hole to refill Epsom T0711 printer ink cartridge. Can you help?
Thanks for using Fixya.
You won't need to drill hole anywhere.
Visit this link to get all the instructions required to refill the ink in Epson T0711 cartridge.
But remember you would need a chip resetter gun to re set the chips on the ink cartridges after you refill the cartridges.
Visit this link to buy Universal chip reseter if you don' t have.
Good luck and have a nice day.
Jul 05, 2010 | Epson Stylus Multifunction Inkjet Printer/...
We have a Dell 944 showing Error 1102 consult user guide...cannot find the user guide. We just replaced color ink cartridge with a re-processed one ordered online. Please advise...many thanks!.
Hi there
Dell Printer 944 error message 1102
Please unplug the printer from the wall. Now remove the power brick from the back of the printer for 60 seconds. Now plug everything back in. This will reset any error messages the printer has. Now open the printer with the power on and the cartridges should go to the center to be replaced. Take out both Dell Series 5 ink cartridges and make sure the tape is off the cartridges and insert both back in and make sure the seat properly and latch. Close the printer and it should print an alignment page. If you still get the error message
Why does my Dell ink cartridge level still show up as "low ink" after refilling them?
Dell ink cartridges have a sensor that reports the ink level as low once it reaches a certain level. The sensor can not
be reset. If you refill an ink cartridge that previously reported low ink, it may print fine, but the sensor will always
report low ink. Buying or replacing ink cartridges with new Dell cartridges will resolve the low ink message.
Dell discourages ink refills. Refilling ink may lead to print quality problems, and even eventual hardware problems.
This post is in no way a validation of refilling ink cartridges.
Why my printer is reporting “low ink" after using refilled/remanufactured ink cartridges?
Most ink cartridges have sensors that report the ink level. The “Low Ink” is usually the last sensor (fuse) before
running out of ink.
Since the sensors are fuses that open when the ink level drops, they cannot be reset. If you are using refill or
remanufactured ink cartridges, the best thing to do is to disable “ink alerts” on the printer’s software so you don’t keep
getting “low ink” messages.
To disable “Ink Alerts” on Dell inkjet printers:
1. Open the Dell printer software (All-In One Center, Tool Box, etc)
2. Go to Settings
3. Advanced
4. More Options
5. In the “Appearance Mode, window, check “Never display the Printing Status window” and “Display the low
ink alert only when the cartridges are almost empty.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 23, 2010 | Office Equipment & Supplies
Dell 926 Printer ink refill instructions
I don't have a Dell but we have Lexmarks which use similar cartridges. I'm guessing your color and black has a flat top. Your printer should be using a 2 cartridge system and most likely w/ 4 colors. Black, Cyan, Magenta and Yellow. The Black cartridge is a single color cartridge. The CMY (short for Cyan,Magenta,Yellow) is in another cartridge. If you don't know which one, get a paper tower and dab the bottom of the cartridge near the nozzles which are usual silver in color. If you have the color you now need a very thin needle to fit those very small holes. If your needle wont fit then you will have to enlarge the holes. To refill,you really will enlarge it anyway to inject the syringe needles in. Stick the needle into the hole as deep as you can and stop just before you hit bottom. Just approximate the height of the cartridge to the needle. When you take the needle out, use a paper towel or toilet paper to wipe off the ink. What you wipe off will be the color of that chamber. You just need to do one more on any of the 2 remaining holes. Label as you go so you know what color it is. Don't do mental gymnastics. One mistake means you either print w/wrong colors or buy a new cartridge. I'm not familiar w/ the cartridge so I'm guessing on the color you should put between 1-2ml of ink per color. On the black maybe 5-8ml. This is to be on the safe side. Don't overfill it. There's no guarantee your cartridge will print, cuz manual refills are not as good as those done on a machine. If it works you may be able to refill another 2-3 times. Manual refilling is a gamble. Just ink the ink in very slowly and be patient. take about 15-20 seconds to inject 1 ml. Hope this helps.
Nov 13, 2008 | Dell 926 All-In-One InkJet Printer
*see the manual and follow the instructions and fill it
* contact manufacturer about details
Jul 02, 2008 | Dell 962 Photo All-In-One InkJet Printer
Refilling an ink cartridge
The holes are under the top label - I'm not sure which hole is for which colour.
Apr 11, 2008 | Office Equipment & Supplies
Go to this webpage: http://www.ldproducts.com/Dell-Ink,Photo-all-in-one,926,Ink-Cartridge,3234,printer.html Click on the links for InTec Refill Kit for Dell MW175 Black and InTec Refill Kit for Dell MW174 Color. Scroll down to Specifications and click on the Instruction Video link for each. That should help some.
Feb 25, 2008 | Dell 962 Photo All-In-One InkJet Printer
Incorrect colour cartridge error
Here is a possible solution to the dell printer BS when I bought replacement cartridge for the black I didn't want or need the color. When I attempted to replace it would say unsupported cartridge on the computer screen and right cartrige error or w/ever it said. who cares . It is a S C A M but if you only need black try this... Take a hammer and smash the printer NO DON"T ... Roofer joke. Seriously though just remove the color cartridge and snap it shut empty with the black " replacement cartridge " snapped in and your good to go in black and white. I bought my replacement cartridge at
( S T A P L E S ) no one has one better. good luck sorry if it doesnt work for you I'm only saying that it worked for me. P.S. Thank you and "DUDE I'M NOT GETTING A DELL"!!
Dec 18, 2006 | Dell 962 Photo All-In-One InkJet Printer
k24674
jasbo
jasbo
