Question about Reddy Heater-170,000 BTU Kerosene Deluxe
I have a thermoheat 125000 kerosene heater it will run with the top cover off but if i put it on it will not ignite help
SOURCE: my thermoheat 210,00 btu kerosene heater works
SOUNDS LIKE YOU HAVE A BAD THERMOSTAT.
Posted on Dec 01, 2010
Buffalo12980
  • 625 Answers
SOURCE: RM115 Reddy Heater forced air heater problem
air pressure should be no more than 3.5 psi. could be your pressure is too high and is blowing out the flame.
Posted on Dec 06, 2007
tbugger
  • 232 Answers
SOURCE: Heater will not stay running
Spark plug or hot surface ignitor?
Posted on Nov 19, 2008
  • 188 Answers
SOURCE: Kerosene Portable Forced Air heater comes on, runs awhile
Here is a link to your owner's manual... http://12.153.20.74/manuals/123919-01A.PDF. Look on page 8 and 10. It could be several things. It could only be a dirty fuel filter or the pump pressure may just need adjustment. If you need a part you can contact Master Parts at 800-466-1446 or you can find them on-line at www.masterparts.net. I hope this helps!
Posted on Jun 30, 2009
SOURCE: Dayton kerosene heater 3E219B will not turn on
I have a Dayton Model # 3e219b 150,000 BTU potable heater and it runs fine with the top cover off.But if I put the cover on it will go out is less than a minute and trip the reset.
Posted on Dec 05, 2009
Thermoheater 210,000 BTU will not run. The ignitor is working, fuel is spraying across ignitor. If fan blade is removed, unit will light? It seems to be getting too much wind from the fan blade, causi
Doug, I'm not sure if I understand completely. Are you saying that the problem existed when you still had clean 1-K Kerosene in the tank? If that is the case, I would first check the spark ignitor to ensure that it is clean and set at the correct gap. Understand that Kerosene which has been standing in the tank since last season will not be as volatile as fresh kerosene and probably should not be used. Diesel fuel, especially Diesel #2, is also not nearly as volatile as it should be. I believe these heaters should only be used with fresh kerosene or #1 fuel oil.
Feb 01, 2015 | Washing Machines
Thermoheat kerosene heater
Push the reset button.
Dec 16, 2013 | Heating & Cooling
Thermoheat dtu torpedo heater reads E1 error
These are some possible causes:
1. Wrong pump pressure
2. Dirty Air Output,Air Intake or Lint Filter.
3. Dirty Fuel Filter.
4. Dirt in Nozzle.
5. Dirty Photocell Lens.
6. Photocell Assembly not
Properly installed.(Not seeing the flame)
7. Bad electrical connection between photocell and MAIN PCB assembly.
8. Defective Photocell.
If all those check out ok, then check these:
1. No fuel in tank.
2. Wrong pump pressure.
3. Carbon deposits on spark plug and/or improper gap.
4. Dirty fuel filter.
5. Dirt in Nozzle.
6. Water in fuel tank.
7. Bad electrical connection between ignitor and MAIN PCB assembly.
8. Ignitor wire is not attached to spark plug.
Nov 29, 2013 | Protemp 125000 BTU Kerosene Forced Air...
Hello, I have a 70,000 btu readdy heater that don't want to ignite. When I pull the top cover off the heater works fine, but the minute I put the cover back on it does not want to ignite. I'm stumped.
Does your heater have an oxygen sensor on it? If so try gently cleanig dust,lint or other debris from it . If that does't help I would replace it. I hope thishelps you. Thanks
Nov 25, 2010 | Reddy Heater-70,000 BTU Kerosene w/T'stat
I have reddy heater 125000 and it wont start
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Oct 23, 2010 | Reddy Heater RH125T Kerosene Forced Air...
Dyna glo pro model #rmc kfa 125tdgp flashing code e1
I have same heater and problem-1) Check fuel inlet screens at bottom of hose in tank 2) Check air filters at fan module opposite end of the fan blade 3)Check for spark in ignition chamber 4) Check for fuel flow in ignition chamber (look at pressure gauge at opposite end from air exit) You'll have to remove the top cover to do these checks. The side covers will hang on each side ok. I hope these checks help you out.Good luck.
Jan 27, 2010 | All-Pro Kerosene Garage Shop Heaters - All...
Jan 31, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy Heater-170,000 BTU Kerosene Deluxe Logo
65 people viewed this question
Top Reddy Heating & Cooling Experts
Mack Baxter
paulcarew
Richard Marsh
Richard Marsh
Level 1 Expert
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
