Question about Xerox Phaser 7760/YDX Laser Printer
Find a lift assebly
Please how do I get a replacement of the lift assembly and at what cost
  • 47 Answers
006K23012 is the part number but no price sorry
Posted on Dec 08, 2013
Error code 929
Pls check the Wast toner full. or not and check wast duct assembly,
that assembly spring was damaged, pls replace duct assebly and change new wast toner,
Mar 11, 2014 | Xerox Phaser 7400/DXF Laser Printer
Need to replace bulb for front parking light/turn signal on a 94 ford probe
There should be a cover on the back of the assebly. a few crews and some metal clips. I dont think you have to remove the whole assembly to change it if i remember right. it should just be a protective cover.
Sep 16, 2012 | 1994 Ford Probe
Will not print. says it's out of paper but the tray is full
Sounds like the paper pick-up assebly has gone bad. The lifting mechanism has gone bad for that particular cassette and the only thing I've done is replace the whole assembly. I tried to repair the assebly but it's too time consuming and you still have a used assembly.
Mar 04, 2011 | Canon imageRUNNER 2200
How to change the rear wiper blade? It is not acting like what the owner's manual describes it. 2009 chevy traverse
Lift it up and pull the retainer ring off, then pull the whole assebly off. They sell the whole assembly as a replacement, not just the blade.
Feb 23, 2011 | 2009 Chevrolet Traverse
I want to replace the entire headlight assembly on the drivers side of a 2006 Chevy Cobalt. How do I do that?
on most of the new cars the head light assembly comes out pretty quick and easy. on top of the assebly there is typicaly two pins. there are eather steal or plastic. you have to pull these pin up and out of the back of the assebly. steal pins come all the way out, but plastic typical come only part of the way out. the assembly will then pull strait out, but can be a tight fit sometimes. unplug light bulbs and reverse procedure with new headlight assembly
be carefull not to touch the glass on the bulbs with you fingers. the oil from your skin will cause the bulbs to fail prematurely.
Apr 24, 2010 | 2006 Chevrolet Cobalt
Dear sir , we have one error on printer E02-01 , whats problem printer Model DP-8020E
the paper lift assembly will be broken or some paper will be struck check both the piont ,also check the voltage
Mar 02, 2010 | Panasonic DP-8020E Black and White Copier
How do I remove the driver side window switch on a 2004 saturn ion?
In pull cup inside back part of switch assebly lift rubber insert (FLAP) there will be 2 screws,remove then lift in pull cup area and pull backwards.
Jun 12, 2009 | 2004 Saturn ION
Remove and replace wiper blade assebly 89 chevy silverado
there is a keeper on the inside of the arm. its easier to get to if you remove the whole arm. lift the wiper arm and near the pivot point there is a little flat bar that sticks out along the arm itself. its about a quarter inch long. pull that out alittle and slide the arm off the peg. makes it easier for me. if you cannot get the wiper off still, destroy it. your replacing it anyway and the arm is pretty sturdy.
Jun 03, 2009 | 1989 Chevrolet K1500
How do i replace halogen bulb for headlight
The easiest way is to open the hood and on top of each headlight assembly is a L-shaped rod. lift up the one bent end of the rod and slide it out of the assembly. lower the light assebly towards the bumper to expose the back of the bulb plugs. Unscrew the dead bulb and replace. (as stated before. DO NOT TOUCH THE BULB) grease from your fingers creates a hot spot on the bulb and it will fail much sooner than expected. hope this helps.
Jan 16, 2009 | 2004 Chevrolet Avalanche
2006 toyota corolla left headlamp replacement
start in the back the hol assebly comes out
Dec 27, 2008 | 2005 Toyota Corolla
Xerox Phaser 7760/YDX Laser Printer Logo
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
