Emachine password reset
Was giving the tower but forgot to ask for a pass word. I have no Cd or anything to reset. How do I wipe it out so I can log on and change the settings
  • 27,725 Answers
  • Is this a Tower or Laptop computer >???????
  • Which operating system>??????
  • EMachines laptops run the Microsoft Windows operating system.
    Therefore, if you want to change the password you have set on your laptop, there is nothing specific you need to do with the laptop itself.
    Rather, the change simply needs to be made with the Windows operating system.
    Changing your password from time to time is a good idea if the laptop is in a location where others can easily access it.
    Turn on your eMachines computer.
    Press the "F8" key as your computer starts up. A screen called the "Windows Advanced Boot Options" menu will appear on your monitor.
    Highlight "Safe Mode."
    Tap "Enter" to start your computer in Safe Mode. Click "Start" and type "lusrmgr.msc" into the "Search" box.
    Press "Enter."
    Click "Local Users and Groups," then click "Users."
    Right-click the account for which you are resetting the password and choose "Set Password."
    Type the new password, then type it again to confirm it.
    Click "OK."
Posted on Nov 26, 2013
  • 36 Answers
SOURCE: Compaq Evo N800c BIOS PASSWORD LOST
the only way is to open the laptop up and there will be a small watch type battery, quite big but flat. it will be on the motherboard. take the battery off the otherboard for at least 10 seconds and then put it back in. this should reset the bios to factory default.
Posted on Jun 18, 2009
  • 14 Answers
SOURCE: dell inspiron 5150 laptop, reset admin. password.
Restart your laptop and keep tapping F8 key the moment you see something on the screen. You will get a black screen with some options written in white. Select the option Safe mode and then you can create a new user with admin rights. Or else at the windows login screen press and hold ctrl and alt key and tap delete key twice and then it will take you to a login screen. Dont put any password there just hit enter. And you will be able to login with admin rights.
Thanks
Deepak
Posted on Oct 28, 2009
parrotheadpc
  • 2600 Answers
SOURCE: I forgot my bios password
If you have forgotten your BIOS or system password, there are no software tricks or magical gimmicks that will get the password cleared. Laptops are different in that they are designed to not work with “backdoors” etc. for security reasons. There is one true way that works most of the time and that is hardware.
The Cmos (RTC) battery that is mounted on the motherboard in most cases holds the key, if your motherboard has the battery that is connected to the motherboard by using a two wire socket that plugs into the MOBO, then here is the procedure.
On the motherboard where the battery plugs into, you will see two pins sticking straight up, these engage the plug on the battery side. These two pins have to be “shorted” and then the motherboard powered up for approx. 30 seconds, then power down the system and replace the Cmos battery and reboot. Only reboot with the AC adapter plugged in, not the main laptop battery. Your password problem should be cleared up. The best way to “short” the pins is get another cmos battery and cut the wires from the battery part, bare the ends and twist together, this will short the pins. Make sure you tape the connection good on the jumper you just made….don’t want to touch anything else with powered up bare wires. Good luck.
If the battery is the disc type and sits in a horizontal socket on the motherboard, then it is a little more difficult to perform but the theory is still good, the positive and negative have to be shorted and the same procedure done. In most cases, just removing the cmos battery does not work in laptops, this is because there is extra security needed because of their portability.
Posted on Jan 12, 2010
  • 69 Answers
SOURCE: forgot password to dell inspiron 1440
Dell Laptop with bios or hard drive password set ? Unlock your dell laptop using the link below if it display a message that says "this computer system is protected by a password authentication system, you cannot access the data on this computer without the primary or administrator password, when you turn on the computer. This message is what you get if the BIOS is protected by a password. or you get system disabled
Go to: http://dell-inspiron-1440-bios-password.biospwd.com to get your dell bios password authentication and get full access to your dell computer, they can unlock almost all dell laptop such as dell inspiron, xps, latitude, precision, studio, vostro
Posted on Oct 01, 2012
Forgot my password and would like you help me find it
Graham, no one in the world can retrieve your pass word, if you can't. That is why they invented the pass word security.
The only way to find it, is to write down all passwords you ever used and still can remember. Perhaps you did forgot a capital while using the last one.
If you have problems accessing an internet account, and you did set it up correct, you did give the provider of that site a mailers where he can send a reset code.
Not giving more clues, I have to do some assumptions. Anyway, check the login page carefully and check for buttons like problem logging in. or forgot password and press that one.
If your account is hacked and the person who did that, was quick enough, he perhaps did change the return mail address and then you have lost the account forever.
Although even Facebook will if asked send a reset code to an old mail address if you have a quick response.
Don't use the same password twice and change passwords regularly.
Dec 16, 2014 | Computers & Internet
I have a acer aspire 5551-2306 and I have forgotten the password and cannot do anything. How do I get pass this?
You can reset a lost or forgot Windows password with 4 methods below:
1. Another valid administrator account which can normally log on.
2. A password reset disk or a repair disc, which is created in advance ( before you lost password ).
3. Third-party software to create a bootable password reset CD/DVD or USB, like Windows Password Breaker.
4. Re-install. Will lose data.
Jan 19, 2011 | Acer Aspire 5551 Notebook
My niece got a new computer, she gave me this one and she forgot administrader pass word,how do i make myself the administrader so i can upload my work without her pass word. thanks john
e-mail me at grahamforde1@hotmail.com and i will give you instructions
If running XP. Turn laptop on and keep pressing F8. once you get to the options, start in safe mode and there is a hidden admin account. log into that and remove the password from her account
Jan 16, 2011 | Acer Aspire 5315 Notebook
My wife has her son's tower how does not care to keep the computer...she would like to use it....he forgot the password to log on....F8 even asks for the password
id you cant get the password to go through the normal way and the system f8 asks for the password also. find a system os disk (windows xp 7 etc) and just do a clean wipe and reinstall
Sep 17, 2010 | E-Machines T1100 PC Desktop
I forgot the password to my toshiba lap a100-036 can u help me
If you forgot the windows login password and want to recover or reset windows password, there is two methods to reset windows login password:
Methods 1: Use the password reset disk to recover the Windows password, by this methods, you need create a Windows password reset disk before you have lost or forgotten your Windows admin password.
Method 2: Using Windows Password Recovery software to recover Windows password
As an easy method to recover the forgotten Windows password, there are only four steps as follow:
Step1: Download Anmosoft Windows Password Reset V8.0( http://www.resetwindowspassword.com
)and install it.
Step2: Burn the ISO image file onto a blank CD/DVD or USB.
Step3: Boot up your Windows PC by the bootable burned CD/DVD or USB in minutes.
Step4: Remove the forgotten Windows password on the operation interface and logon PC without password.
Jan 05, 2010 | Toshiba Satellite A100-S8111TD Notebook
I forgot my password on my emachine computer.
ok what you want to do is restart the PC and keep tapping F8 when it asks you to start windows in safe mode or with networking hit enter on windows safe mode ... not with networking any ways... it will then ask you to log in Type in user name Administrator and then hit Enter .. go to control panel change your password jobs a gooden :D Good Luck
Sep 07, 2009 | E-Machines eMachines T3830 PC Desktop
Forgot password to log in to pc
Please mention your problem clearly....
If its BIOS password (when system boots it will ask for password) then shutdown the system and remove the COMS battery for 2 minutes which is present in the one of the corner of the motherboard.
If its user password (asking the user name and password) then you need to install a fresh copy of windows xp. to install a windows xp, Insert the XP bootable cd into the CD-ROM. Restart the system. Then the system will boot from cd. If its not asking to boot from cd then you need to change the settings on BIOS menu. When system restarts keep-on pressing the DEL or F2 keys or both. then it will take you to BIOS setup. there change the boot priority. Select first boot device as CD/DVD ROM. After please click on the below link or copy the URL and paste it in your web browser. Follow the steps.
http://www.microsoft.com/windowsxp/using/setup/winxp/install.mspx
Thank you........
Aug 19, 2008 | E-Machines eMachines Refurbished EMA...
Forgot my windows login password...
For removing Windows Passwords in safety, I highly recommend windows password reset tools. Last week, and then I downloaded it and used it to remove the lost password successfully. You can download one from: http://www.reset-windows-password.com
Jun 12, 2008 | E-Machines eMachines Desktop PC
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
