I ;have a series 80 kenmore washing machine aand I need to replace the safety swich. How do I remove the top of the machine?
  • 413 Answers
The switch you're talking about is called a "lid switch". It can be by-passed, but it is there for a reason. The switch is used to prevent the tub from spinning or agitating with the lid open. This is a safety measure to prevent personal injury. You mentioned that the switch was "missing". It may have simply come loose and fallen inside the washer between the case and tub. More than likely, it is hanging by a ground wire and a plug. If you can retrieve the switch and screw it back in place on the rim of the wash tub opening, you may actually fix your problem. However, if the switch is broken, you need to replace it. Here's how:
First of all, unplug your washer. You will need to remove the console in order to get to the lid switch. The washer may have release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up. If not equipped with this type of console, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. Once you have the console loosened, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps:
1. Under the console you will find the lid switch connector. Unplug the switch from the connector.
2. There will be two brass colored clips. You will need to remove these to remove the machine casing. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver away from you while holding into the groove and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Now pull the case from the frame by lifting from the back first.
You do not have to remove it all the way from the frame, just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in and a ground wire. It's a pretty easy repair job. Some models will have the switch located on the right-hand side of the lid rim opening, while other models will have the switch located on the left-hand side near the lid hinge.
Once you've completed your switch installation, make sure you get the case back on the frame correctly by following these steps:
1. While looking down through the lid opening, place the front lip of the machine case UNDER the washer frame and start leaning it back onto the frame. There are four small cleats that must fit into four slots on the case or the washer will vibrate. Make sure the frame is seated properly, lean forward from the front of the washer, grasp both sides of the rear panel and pull towards the case. The rear panel should be seated and flush with the casing before inserting the retaining clips.
2. Insert the brass-colored clips into the slot on the washer rear panel first, and then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
3. Make sure you plug the connector from the console back into the lid switch receptacle BEFORE you reassemble the console. This is easy to forget.
PS To answer your initial question about by-passing the switch, when you remove the console and disconnect the lid switch, you can take the connector that is MOUNTED ON THE WASHER TOP and remove it by pressing the release tabs and pulling it from under the tub rim. This is the connector plug that runs to the lid switch. Cut the plug from the switch, leaving a couple of inches of wire. Short the two black wires together, insulate the ends and cut the green wire flush. You now have made a by-pass plug. Simply plug it in to the connector that is RUNNING FROM THE TIMER and (voila!), you have a working washer. Keep in mind that now your washer will NOT stop when you open the lid. Use caution if you're going to operate your machine in this manner.
Now...if you're going to go this far, you should replace the switch. A new switch runs about $35 or less. Its an easy repair if you follow the directions. Keep the plug handy in the event that you run into this problem again and need to drain and spin the water out.
Good luck to you and let me know if you need any further assistance.
Posted on May 08, 2009
I have a kenmore ultra care fabric series 80 and need to replace top cover on drum. How do I do this?
the top cover can be removed after removing the cabinet, the top snaps or clips on all alround the tub every 10 or so inches, u just have to unsnap it little by little
Mar 01, 2015 | Kenmore Washing Machines
Kenmore 80 series fills with water then doesn't
the lid switch under the control panels bad replace it and it will again wash,they just unsnap out of the top of the cabinet after you remove the control panel
Jul 07, 2011 | Kenmore Washing Machines
I have a Kenmore Series 80 (8543549) top load washer. It will fill, but not agitate or spin or drain or anything else. The knob does not advance except manually. What component is causing this problem?
if its a top load which i believe a series 80 is,then you need to replace the lid switch to make it operate again,its located under the control panel,some can be replaced from the top,but some need to have the outer case removed to replace this switch
Jul 04, 2011 | Kenmore Washing Machines
How do you remove the top off the washing machine to replace the lid switch in a kenmore super capacity 80 series?
The following link explains step-by-step how to replace the lid switch on a Kenmore top loader:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
If you have any questions about this repair, please post back and let me know. I hope you find this information helpful.
Oct 26, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 80 series model 110 after wash clothes are left soaking
when empty and off, open the lid and see if you can rotate the inner wash basket by hand. if you can easily, then the clutch is worn. This will prevent the basket from going into a high spin and wringing the clothes out. Replace the clutch by removing the top control panel, removing the clips that hold the cabinet, pull cabinet off, remove drain pump clips and pump, remove motor clips and motor, remove transmission (3 bolts). Now you will have access to the clutch, replace as needed, reverse dissasembly to complete. remember to unplug.
Jul 01, 2009 | Kenmore 22422 Top Load Washer
How do you open the console on a Kenmore 80 Series Washing Machin
To replace a motor coupling on a Kenmore top loader, follow this link:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
Included are all the step-by step instructions you need (including how to open the console). If you still have questions, or require additional assistance, please let me know. I hope this helps you.
Feb 25, 2009 | Kenmore 24032\24036 Top Load Washer
How do I take apart the outer shell to my Kenmore -Series 80 washing machine?
I have Serial # CF2467934 Model # 92588210 Kenmore Ultra Fabric Care Heavy Duty 80 Series. The top agitator is stripped out, how do I take it out to replace it?
Aug 11, 2008 | Washing Machines
Kenmore 80 series
sounds like your control switch needs replacing.
Apr 15, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
