Question about Apple 20" Aluminum Cinema Hd Display M9177ll/a A1081 Faint Scratch
Apple Cinema M9177LL/A 20" A1081 Widescreen LCD Monitor blank screen
No lcd shows blank
FixMySadMac
  • 10 Answers
SOURCE: Screen resolution.
Hello there!
It's fortunately quite easy to adjust the resolution your MacBook Pro sends over to your external display.  Try this:
  1. Click the blue Apple icon, at the top-left of your display (while connected to your 23" external monitor).
  2. Click on "System Preferences".
  3. Click on "Displays" in the "Hardware" row.
  4. A display preferences window should now open on each display... one on your laptop, and one on the 23".
  5. In the "Display" tab of this preference window, specifically the one located on your 23" display, should be a list of resolutions available.  Scroll down and select the highest resolution, which for a 23" should be 1920x1200.
This should adjust your resolution to the maximum.  To make these settings easier to get to in the future, check the box in the display preferences labeled "Show displays in menu bar".  You'll see a small icon, meant to look like a display, appear in your menu bar.  Going forward, you can click on this to set/change resolution settings without going through all the above steps.
Hope this helps!
Posted on Oct 15, 2007
SOURCE: blank screen (Apple Cinema HD 23"LCD)
Had a similar problem with similar symptoms. Try unplugging the firewire and usb. Might help for a while. It did for me. In the end I risked the price of a new power supply. That fixed it and my 23" has been working fine since. Have to order the power supply directly by contacting Apple's service people. I found no other way to get one.
Posted on Sep 14, 2008
  • 51 Answers
SOURCE: Dim 20" Apple Cinema Display
Double check you power cord and try switching plugs.
sounds like its not getting enough power or a CCFL is going or is out and you need to get it serviced if thats the case.
Do not attempt to repair this your self Monitors usally have there own power supply built ind can store massive amounts of energy and will cause serious injury or death.
Posted on Jan 30, 2009
  • 35 Answers
SOURCE: Apple 20" display black screen
I've read that aftermarket DVI cable adapters don't work well with this set-up. You might try the Apple DVI to ADC adapter. It's expensive but I see them on eBay or craigslist from time to time at less than half the normal $99 cost.
Posted on Aug 17, 2009
  • 39 Answers
SOURCE: apple cinema display 23. lost power. rebooted.
have it service with registered technicians
Posted on Mar 17, 2010
How to connect normal pc to a1081 lcd monitor
Check first you have a vga input in your LCD monitor, then use a vga to vga cable from pc to LCD monitor. And before connecting all that, set your screen resolution to 800 x 600 just to make sure compatibility at start. That should do it, then later on using the monitor, adjust the resolution to suit yor taste.
Aug 18, 2013 | Apple A1081 20" LCD Monitor
Apple 1081 no power
You need to track down a replacement 68W power supply for Apple monitors. eBay is a good place to look.
Mar 04, 2013 | Apple 20" A1081 Widescreen Cinema Display...
How can i fix my apple model a1082
What kind of problem do you have? Any error code from the front LED?Common problem with this model is due to bad VR3 3.3VDC Regulator.See more pictures here:http://s807.photobucket.com/albums/yy352/budm/MAC%20Monitors/MAC%20CINEMA%20HD%20Display%2023%20inch/
Dec 28, 2011 | Apple A1082 CINEMA DISPLAY 23" LCD Monitor
Someone is selling an Apple Cinema Display 20"
It is fixable the question though is it worth fixing? because the problem usualy resides in the cost of repair.
May 11, 2011 | Apple 20 inch LCD Monitor
Apple cinema display has interference
Check your DVI cable for breaks. If that's not the problem, then you'll need a new IP board. Not sure of the part number for this monitor, it's printed on the circuit board. It starts with 820-XXXX or 620-XXXX in some cases.
Nov 24, 2009 | Apple Cinema 20" LCD Monitor
Aug 26, 2008 | Apple 20" Flat-Panel TFT LCD Cinema...
Blank screen (Apple Cinema HD 23"LCD)
damn gay i got t is 23 apple screen for 14month and it has a black screen now :( .. what can i do to fix this .?
Jun 06, 2008 | Apple Cinema HD 23" LCD Monitor
Verticle lines through screen
Many times this is caused by a poor connection at the circuit board ribbon connectors to the boards, pull the TV cabinet off, unplug and re-plug all the connector to the boards a few times, take care not to damage them.
May 04, 2017 | Apple Cinema 20" LCD Monitor
Apple 20" Aluminum Cinema Hd Display M9177ll/a A1081 Faint Scratch Logo
42 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
