Question about Audiovox Comcast, Xfinity, Roadrunner, Cox, Charter, Approved Rca Dcm 425 Cable Modem
Xfinity cable remote code for Prizmo hd TV - Audiovox Comcast, Xfinity, Roadrunner, Cox, Charter, Approved Rca Dcm 425 Cable Modem
What is the code for xfinity cable xr2 remote control?
Your XFINITY remote can be paired with XFINITY X1 TV boxes, allowing you to control the TV box even when it is placed out of sight, such as in an entertainment center or in another room (up to 50 feet away). XFINITY remotes can be identified by the model number on the back panel or within the battery compartment of the remote.
Note: Once your remote is successfully paired with a TV box, it will not control any other TV box until paired with the other TV box. XFINITY remotes can only be paired with one TV box at a time.
To Pair an XFINITY Remote Note: These instructions apply to XR2, XR5 and XR11 model remotes only.Make sure the remote batteries are installed and your TV and TV box are powered on.Set the TV input to the input connected to the TV box.Press the Setup button on your remote until the LED at the top changes from red to green.Press the xfinity button on the remote. The LED will begin flashing green. (Note: When pairing an XR2 or XR5 remote to a DTA, you may need to press the xfinity button up to five times).Follow the instructions by entering the three-digit, on-screen pairing code.
Once the on-screen pairing code is correctly entered, your remote is paired with the TV box. Note: If you do not see on-screen pairing instructions after pressing the xfinity button in step four, press the xfinity button again. You may need to press the xfinity button multiple times if there is more than one TV box in range.
how4474_072816_01-kmuj4sm5av3gyijxunj5wf5e-1-0.png NOTE THE BELOW CODES ARE FOR THE SAMSUNG SMART TV's ONLY
Type in the 4-digit or 5-digit code listed below using the number buttons. Additional codes may be found in the remote manual.
Most likely code
10812
Others to try
11632, 10702, 10060, 11959, 10766, 11903, 11060, 10587, 10329, 10482, 10650, 10814, 10032, 10178, 10030, 10019, 11575, 11597, 10427, 10408, 10217, 10056, 11581 for more info on what device you are trying to pair it with the codes are available here > https://www.xfinity.com/support/remotes/ Just select the Remote and the device and continue and the page will display the most common codes for that Device you are trying to pair it with.
Apr 26, 2017 | Televison & Video
I have a universal ge remote control will it work on my 19 inch prizmo tv
082,087,038,024,004. Check these codes. If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy.
Mar 21, 2013 | Universal Remote Control GE174Universal...
I can't get my xfinity remote to work on my new Sony Bravia tv.
Call Xfinity to get another Digital HD DVR mine is a RGN200N it has a programmable remote you can program 3 devices using the codes provided in the guide. Does the box that remote controls offer HD? Or just digital TV?
Nov 10, 2012 | Televison & Video
WESTINGHOUSE LD-4655VX CODE FOR XFINITY REMOTE
The Westinghouse LD-4655VX TV has code compatibility with Sony TVs (http://westinghouseelectronics.com/wp-content/uploads/2012/06/Remote_Codes_2012.pdf). I accidentally discovered that the Sony TV remote RM-YD040 works with my he Westinghouse LD-4655VX (because I have both TV sets).
Feb 02, 2012 | Televison & Video
Need the prizmo tv codes for a universal remote
Prizmo TV no universal remote codes work. I called RC Willey (where I purchased the Prizmo TV) to get a replacement remote for my Prizmo 19" TV. Customer service finally gave me a number for Red Rock Sourcing 1-702-252-5049. Red Rock took my Prizmo TV model number and they apologized for any inconvience. I told them no universal remote codes work for the Prizmo TV. Red Rock Sourcing is sending me a free replacement Prizmo remote by Fed-Ex. I hope this helps you.
Aug 14, 2010 | Uniden WHAMx4 LCD Remote Control
Cannot find the tv code for a Prizmo TV, to set up a remote control
RcWilley where I purchased my Prizmo TV 19" referred me to Red Rock Sourcing 1-702-252-5049 I gave them my Prizmo model number and they are sending me a free Prizmo replacement remote by fed-ex. The universal remote codes don't work on the Prizmo TVs
Jun 07, 2010 | Philips Magnavox 27MS343S 27" TV
Prizmo remote code
Prizmo TV universal remote codes do not work. I called RC Willey where I purchased my 19" Prizmo TV. I was referred to Red Rock Sourcing 1-702-252-5049. Red Rock is sending me a free Prizmo replacement remote by fed-ex. I hope this helps.
May 21, 2010 | Televison & Video
CANNOT FIND CODE FOR PRIZMO TV
universal remotes do not work for the Prizmo TVs. RC Willey where I purchased my 19" Prizmo TV, referred me to Red Rock Sourcing at 1-702-252-5049. Red Rock is sending me a free Prizmo replacement remote by fed-ex. I hope this helps.
Apr 24, 2010 | Philips Magnavox 27MS343S 27" TV
Unable to sinc the "comcast digital transport adapter univ remote
where is the remote, try the store you purchased the TV and get them to source replacement remote for you - or google
Mar 19, 2010 | Televison & Video
Audiovox Comcast, Xfinity, Roadrunner, Cox, Charter, Approved Rca Dcm 425 Cable Modem Logo
32 people viewed this question
Top Audiovox Computers & Internet Experts
Greg Cann
Greg Cann
Martin Murray
Computer Repairing
Computer Repairing
Are you an Audiovox Computer and Internet Expert? Answer questions, earn points and help others
