Question about Sharp XE-A207 Electronic Cash Register
What is the ink ribbon for the XEA207 - Sharp XE-A207 Electronic Cash Register
Tip
Determining whether your ribbon is CSO or CSI
A ribbon used in thermal printing will be either:
  • CSO - Coated side out
  • CSI - Coated side in
The ink is on one side or the other of the roll of ribbon. To determine which side the ink is on, take a label and stick it to the ribbon and peel it back off. Ink will stick on the adhesive, turning it black on the side that has ink on it.
on Aug 20, 2010 | Office Equipment & Supplies
Why doesn't my new corrector ribbon/ink ribbon work? The wheel advances-nothing shows on paper.
Put in a multi-part form, type if the carbon is OK the problem is with the ribbon. Look at the ribbon if there is an impression on the ribbon but no ink transfer the ribbon is very ols, if there is no impression then the ribbon isn't lifting. THere ix a 2" black gear on the right side of the printer it should move easily if not wiggle it back and forth they get tooth for tooth with the drive gear.
DickyO
Oct 10, 2014 | IBM Wheelwriter 6 Typewriter
How do you reset the sharp xea207 cash register ?
Go to sharp electronics .com Then slect cash registers or enter in seach box and there will be operating instructions and troubleshooting on their site. Good luck.
May 11, 2014 | Sharp XEA207 Cash Register
I have a brother GX6750 typewriter do not understand how to install correction ribbon
well, the correction ribbon is for erasing mistakes, it literally, pulls the ink off the paper, but you have to hit the correction button, the type writer will back up and pull the ink, but you would hear ait and be able to tell the diff. I think maybe you should check 1st that the ink ribbon is the 1 closest to you, and the correction ribbon is behind the ink ribbon- also make sure they are in the correct direction- ink side of the ribbon facing your paper- sticky side of the correction ribbon facing the paper- so its you, the ink ribbon and then the correction ribbon then the paper
Feb 07, 2012 | Brother GX-6750 Typewriter
My Z4M Plus printer is not printing the label all the settings are fine no error. The ribbion shows the image but it doesnot print on the Label.
Two possiblities: 1. the darkness is not high enough for the ribbon/label combination. 2. the ribbon is on backwards. if the ribbon is on backwards, you will still see an impression on the ribbon but not on the label. This means all the ink transferred to the printhead which should then be cleaned.
The ink side of the ribbon needs to face down to the label to print so the easiest way to make sure which side has the ink is to use a label or piece of tape and touch it to the ribbon. If no ink comes up in the adhesive then that is the wrong side.
Hope that helps !
Apr 01, 2010 | Zebra Z4Mplus Label Printer
The button becomes red once I print a test page
The red light means out of paper or ink ribbon. Some people chose not to use the ink ribbon and get thermal direct paper which requires no ink ribbon but The red light means out of paper or ink ribbon. Some people chose not to use the ink ribbon and get thermal direct paper which requires no ink ribbon but the printer has to be told by the driver not to expect ribbon or the red light will come on. Also not having the correct paper height set in the driver will make the red light come on as well so check the advanced tab in the properties of the driver then click printing defaults. In the ZDesigner driver height and width are entered there. In the zebra universal, its the same path but one extra click. Click paper output and enter the size.
Oct 05, 2009 | Zebra TLP 2844-Z Thermal Label Printer
I channged the ribbon and the printer will not print tried several thing but it look like everything goes ok but there is nothing printed on the labels
Check that ribbon is installed correctly. Zebra ribbon only has ink on one side. ink side must be facing label. Use a label to check which side ink is on stick label onto ribbon and peel off.
Jun 14, 2009 | Zebra LP 2844 Thermal Printer
Brother intellifax 770
Winding technique:
To wind a new ribbon, take the cartridge housing apart and remove the old ribbon and two cardboard cores. The new ribbon is fitted with the larger roll (the ink ribbon supply spool) at the rear side of the cartridge (as the housing is viewed when it is normally installed into the machine). The ribbon winds over the topside of the rear spool (the supply side) and feeds into the underside of the front spool (the take-up side). Make sure the ribbon is wound neatly, evenly and is tight. If the ink film has become detached or is too loose on the front spool it will not wind on and cause a machine error. If required, use a small amount of sticky tape to secure the ink film to the front cardboard spool and then neatly wind it on to the take-up spool a minimum of five turns, making sure the film does not overhang at the edges. Now reassemble the housing and refit into the machine.
If it’s still not fixed:
If problems persist after fitting a new ribbon, try replacing the entire ink ribbon unit (cartridge housing + a new ink ribbon) using a new, genuine Brother unit before requesting a service; this will be less expensive as the actual housing may have been damaged and is causing the problem and this unit is readily available as a consumable item through sales outlets. If the machine still has problems, book your machine in to be repaired with an authorised Brother Service Centre.
Feb 25, 2008 | Office Equipment & Supplies
Ribbon empty
Winding technique:
Feb 17, 2008 | Brother FAX-575 Plain Paper Thermal
Sharp XE-A207 Electronic Cash Register Logo
Top Sharp Retail Supplies Experts
Electroboy
Electroboy
Patrick Tinashe...
Are you a Sharp Retail Supply Expert? Answer questions, earn points and help others
