my fridge has bizarre temp controls. It has a vertical dial with letters and a round dial with numbers. Its an old GE "No Frost" freezer on top style. The problem is trying to figure out the 2 dials to make it colder.
can you provide me with a model # of your appliance? Depending on the model, the controls are different. email it to me at jordanaschmidt@aim.com and I'll follow up with you with fix. thks
first ice dispenser and water dispenser were slow to trigger, then stopped working with dislay...
(More)
first ice dispenser and water dispenser were slow to trigger, then stopped working with dislay blinking, then temperature display went blank and showed "HRS", now just blank and no cooling.
My ice dispenser keeps freezing up and clogging. It appears the flapper that closes after ice is...
(More)
My ice dispenser keeps freezing up and clogging. It appears the flapper that closes after ice is dispensed does close tightly and allows warmer air and humidity to enter to enter the freezer. Can the tension spring on the flapper be adjusted or does it need to be replaced?
the fridge and freezer are not working.. the light comes on and you can hear air blowing in the...
(More)
the fridge and freezer are not working.. the light comes on and you can hear air blowing in the freezer, but it is somewhat warm air.
