Is there a way to reset transfer belt and fuser in Oki c6050?
Soulvisitor
  • 1113 Answers
SOURCE: oki 9800 230 fatal error
No reset need to fix fault then clears...check toner carts are secure on drums, all their contacts are clean,
Replace Toner Cartridges with Gen OKI new ones... are you using non oki product? Cause Toner carts, thats where I would start looking cause the error is the machine not receiving correct information from a little chip built into the toner cartridges to allow operation to begin.
Posted on Dec 21, 2007
SOURCE: oki 5500 n
You cant do it via admin code or software.
Inside every part is a little green picofuse.
When the printer starts, it looks for continuity. If present, it burns the fuse and resets the corresponding counter.
If you want to be creative, you can replace the little fuse. Easiest done in belt and fuser. Almost impossible in drums.
Or one might construct a little device with a fake fuse to insert between the part and the corresponding connector.
Posted on Dec 17, 2008
Joed911
  • 4338 Answers
SOURCE: Fuser reset / transfer reset
RESET OKIDATA TONER DRUM by RTINSC (11/17/05 10:34 AM) reply + / -
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
6. Window shows "NV-Ram- Initial Table 1".
7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
8. Restart printer.
All toner, drum, fuser and transfer figures return to 100%.
Posted on May 16, 2009
SOURCE: Oki b2540mfp fuser error. Is there a reset in
replace main board...thats what i had to do...
Posted on Apr 15, 2010
alpug
  • 1961 Answers
SOURCE: I have an Oki c9650
not 8 0\'s...... use only 6
password is 000000
Posted on Oct 18, 2010
How do you reset maintenance count on a dell 3130?
You don't. You can't.
When you install a replacement Transfer belt (it has it's own counter chip) that resets the transfer belt pagecount, and as a result clears any transfer belt life related warnings/errors.
When you install a REPLACEMENT Fuser (that has it's own counter chip) that resets the fuser pagecount, and as a result clears any fuser life related warnings/errors.
PLEASE NOTE - The fuser supplied with the DELL 3130 when new DOES NOPT have a counter chip - the fuser life warnigs are triggered by the printer pagecount. Installing a fuser from another printer (even if it has a ZERO pagecount WILL NOT reset the fuser pagecount (because the 'ship with' fuser has no counter chip.
Aug 27, 2014 | Dell 3130cn Color Laser Printer
Oki c5800 belt life reset
It may require a complete service kit, you should check with Okidata to see if there is a kit available or what steps you should take to reset the life counter.
Jan 29, 2013 | Oki Electric Industry Okidata C5500, C5800...
All three lights blink rapidly. The computer says it cannot communicate with the printer. When I plug the USB into the computer the computer doesn't acknowledge that anything was plugged in. If I...
It sounds like your main board (the brains) in the printer is fried (I got the same problem with mine). That part (when purchased new) costs so much, your better off just getting a new printer, and it's not your typical user serviceable part (hard to remove, many wire/plugs going to/from it).
The problem with replacing it with a used part, is that the used circuit board will still have the consumable counters in it set to old values from the printer is was pulled from, and NEW or RE-Chipped consumables will be needed to reset those back to zero again (not just the toners, but also the photo drums, fuser, and transfer belt). So, if the used board was connected to "old" consumables (nearly depleted), you won't be getting too many prints before it's asking for either new toners, photo drums, fuser, or transfer belt. The fuser and transfer belt cost upwards of $175 or more each....
How it works is like this, according to Okidata's Tech support guys. When you put a new "consumable" (toner, photo drum, fuser, transfer belt) into the printer, that main board resets the counters AND THEN it immediately blows a fuse (not a regular fuse, but a microchip fuse) in that comsumable so it can never reset the counter for that consumable again. When that consumable's counter reaches it's predetermined number of prints, the printer refuses to print until it is replaced (or it is "re-chipped" with a new fuse).
They make toner refill cartridge chips, and I think even a photo drum kit (seen it on Ebay). But I haven't found anything that would rest the fuser or tranfer belt. Let me know if you find something to reset the fuser or transfer belt.
Jun 10, 2011 | OKI C3400n Laser Printer
OKIC5450 . in portrait Left side fades off (about 2") in all colours but worse in black. All drums over 50%, Fuser 100%, All toners at least 39% belt 22% colour page count 38000
When you touch the faded side with your hand after the paper comes out of the printer, does the toner come off on your hand? If so, it's the fuser. If not, it's probably the transfer belt.
May 27, 2011 | OKI C5100n Laser Printer
Transfer belt warning on oki c3200. How do I reset
8. Restart printer.
Hope this helps
Positive Feedback ALWAYS Appreciated :)
Mar 06, 2011 | Office Equipment & Supplies
MY COPIER (KYOCERA 1635) DISPLAS ERROR C6050. HOW
C6050 Abnormally low fuser unit thermistor temperature The fuser temperature remains below 90°C/194°F for 1 s. Poor contact in the thermistor connector terminals. Reinsert the connector. Also check for continuity within the connector cable. If none, remedy or replace the cable. Broken fuser thermistor wire. Measure the resistance. If it is ∞ ω, replace the fuser thermistor. Fuser thermistor installed incorrectly. Check and reinstall if necessary. Fuser thermostat triggered. Check for continuity. If none, replace the fuser thermostat. Fuser heater M or S installed incorrectly. Check and reinstall if necessary. Broken fuser heater M or S wire. Check for continuity. If none, replace the fuser heater M or S. Code Contents Remarks Causes Check procedures/corrective measures
Apr 09, 2010 | Copystar CS-1620 Copier
Oki 5500 n
Dec 09, 2008 | OKI C5100n Laser Printer
8. Restart printer.
Aug 11, 2008 | OKI C5510 MFP All-In-One Led Printer
Oki 9800 230 fatal error
Dec 07, 2007 | OKI 9800hdn Laser Printer
jasbo
jasbo
