Question about Baby Gear
Mothercare spin Hi, I have the mothercare spin and one of the screws have come out what hold the basket to the frame, does anybody know where I can get replacement ones also the black plastic bit fell off too
  • Baby Gear Master
  • 1,629 Answers
Hi Stacey
Pop into your local Mothercare store or contact their customer care team for assistance.
Posted on Nov 29, 2013
4 Suggested Answers
farmerbear
  • 490 Answers
SOURCE: a screw fell out that secures the handle to the
There should be a second screw still in place.If this is so, remove it and take it to the local hardware store for a match. Otherwise, if you can tell me the manufacturer and model, i may be able to locate a source for OEM parts. Hope this helps a little:)
Posted on Aug 23, 2010
SOURCE: quinny buzz shopping basket
1. take off the front wheels by squeezing the two buttons on the aluminium tube just up from the wheels.
2. slide the metal clip up the groove in the tube.
3.use the two velcro straps around the tubes that support the rear wheels to hold up the rear of the basket.
4.re fit the front wheels and make sure the buttons snap into the holes in the tube
Posted on Aug 15, 2008
SOURCE: urban detour, mothercare
I've lost the protection bar of Urban Detour Xtreme - actually, I bought it without the bar and the seller cannot find it anywhere :( do you know how I can get one? I am not in England, I'm from Bucharest. Thank you.
Posted on Mar 28, 2010
Hi my mothercare spin pram has decided its not going to spin, any suggestions on how I can fix it please? x
The mothercare spin had a lot of problems so mothercare took them off the market and fixed the problems and then released as the orb, as the name spin had got such a bad reputation. Might be worth popping in to mothercare to see what they say but imagine it was bought too long ago for them to offer help. Worth a try though
Mar 01, 2015 | Baby Gear
Intructions for mothercare moses basket stand
Refer this issue directly to Mothercare as the screws may be special for safety-related reasons.
Sep 09, 2014 | Baby Gear
Does anybody know Where can I get replacement screws for the mothercare spin
Best to contact Mothercare customer service they should be able to supply you with parts.
Nov 26, 2013 | Baby Gear
I am a grandma who can't put up mothercare my4 stroller
hi jane go to this link and paly video
http://www.mothercare.com/Mothercare-MyChoice-Pram-and-Pushchair-Chassis---4-Wheeler/993835,default,pd.html
you will need to watch a good part of it till it shows you who to fold it up and then put it back up ( watch out for what she dose with her right hand before opening it back up there is a black bar to pull a way from the frame hope this helps Mark
Jun 25, 2012 | Baby Gear
Kenmore washer (110.92389200) drains, but will not agitate or spin; also, cannot turn the basket by hand. Where is the access for service?
check the motor coupling,take out the two screws that hold down the top console,flip up the console,unplug the lid switch harness in the middle or a little to the right from the middle and with a screw driver pop the two metal clips,tilt the frame to you and remove the whole frame of the washer.with a screw driver pop the two clips holding the pump on and slide the pump forward off the motor.take out the two screws and pop the motor clips and pull the motor forward,you'll see the motor coupling,there should be three arms coming off the coupling and three arms on the other part of coupling and a piece of rubber that they slide into,if it's cracked or worn in the middle replace the coupling and cut down on the size of the loads you put into washer.when putting the motor back on look at the four corners of the motor,if any of the rubber spacers are missing look where the motor goes and take the rubber spacers off the frame and stick them in the four corners of the motor and then line the motor up and install it,it's to hard to get the motor back if you don't do this.good luck and let me know what you find,if you need any more help let me know
Jul 31, 2010 | Kenmore Washing Machines
Replacement screw set winnie the pooh cot bed
Just ring the mothercare customer service help line and they will order them for you free of charge - you do not need your receipt.
Feb 09, 2010 | Baby Gear
MY WASHER DOESNT SPIN OUT YOU HAVE TO KEEP GOING IN THERE TO ADJUST THE CLOTHES TO MAKE IT SPIN
i am assuming this is a top load. if so place a screw driver in the lid switch button, turn dail to spin and while holding the spin basket in place turn on. is it very easy to hold basket from spinnihg? if so you may have a slipping clutch. to replace, remove washer body by removing 2 screws from timer console. they may be in front or behind. remove body clips located under timer console and lift off body. next remove agitator. next remove 3 , 1/2 inch bolts at bottom of transmission. slide out. clucth is right there on top side of transmisson. part # 285785
can be purchased at repairclinic.com
Jan 29, 2010 | Whirlpool Washing Machines
Model 23832 Spin cycle doesn't spin
I believe this is the direct drive model. Your clutch is slipping. There is a quick easy fix available that I have used in the past. Remove cabinet from washer. Make sure you know the easy way to do this... 2 screws on top back of washer and 2 holding control panel. cabinet tips toward from of unit and off. Real easy... Remove wire harness from motor under basket. Remove 3 screws holding motor to basket. Remove agitator inside basket. 1 screw holds it in place. Remove entire motor and shaft from unit. Clutch is attached to shaft on top of motor. Pinch spring to remove clean everything with alcohol. Insert #10 washer between cup and spring to give a little more tension. Replace and viola.... all should work well.
Jul 10, 2009 | Kenmore 23822 Top Load Washer
Washher does not agitate or spin but does drain
HI, if the motor is running and it still will not agitate or spin, here is the most common and probable problem and solution.
Normal 0 Removing the cabinet. UNPLUG the washer. There are two screws holding the control panel to the cabinet. Most models the screw are in front but, some models have the screws in back. They are on each end. Now raise the control panel up and let it rest on the hinges. Unplug the lid switch harness and locate the clips on each side (bronze in color) and release them.
Now the cabinet will lift off the frame and you can set it aside.
How to replace a coupler:
Now that the cabinet is out of the way, remove the pump from the motor and set the pump off to the side. Remove the two screws holding the clips on the motor and remove the clips. Unplug the motor harness and on some models you wil need to unplug the capacitor.
Now you will need to replace all three parts to the coupler. I use a ½” socket and a small hammer to force the coupler onto the motor and transmission shafts. Put the rubber part onto the coupler half on the transmission and then line up the post on the motor shaft with the holes on the rubber part and it should go on ok. Put the clips that hold the motor in place and plug in the harnesses.
Put the pump back on and the clips to hold it in place. Set the cabinet back on the frame. Make sure the lip on the front cabinet is under the front rail of the frame. Ease the cabinet on the frame making sure the two rear sides of the cabinet set down on the tabs of the frame.
Put the two clips back on that hold the cabinet and plug the lid switch back in. Fasten the control panel down and you are all set.
I hope this helps.
Please let me know if I can assist you further.
Vic
May 27, 2009 | Washing Machines
Basket out of balance
YES !! also could be a loose or broken screw that holds the inner basket , hope it helps AJ
May 21, 2008 | Whirlpool GSC9455 Top Load Washer
Baby Gear Logo
170 people viewed this question
Top Baby Gear Experts
Jennifer Rock
Jennifer Rock
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Baby Gear Expert? Answer questions, earn points and help others
