Question about Maytag Kitchen Ranges
How to remove oven light bulb on maytag precision touch control 800 smoothtop
How do remove the oven bulb cover in a maytag precision touch control 800?
the trick is to push the metal ring IN at the same time as turning the bulb cover counter clockwise
Feb 01, 2013 | Ovens
My mom has a 2003 maytag precision top control 500 electric smoothtop oven. problem- uneven heating and also seems to need to bake on a higher heat than recommended.
Hello & Welcome to FixYa
This indicates a open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Feb 03, 2011 | Maytag MEW5527D Electric Single Oven
I have a Maytag Touch Control 500 electric smoothtop, about 4 yrs old. The entire display panel is dark, but the burners oven light work. The oven does not work.
Hi. Been there. You will have to take it apart so you can see the panel. it should have a fuse on it. It could be bad. Or mo voltage going to it. Or hold on........The board is bad
Ken
Sep 21, 2009 | Kitchen Ranges
One surface element went dead.
Make sure that element didnt come unplugged. Just push it in firmly and it should be fine.
Mar 18, 2009 | Cooktops
Kitchen range cleaning
Use Glass cook top cleaner by Weiman. For stubborn burnt on food use a scraper or razor blade and hold it at and angle almost parallel with the top of the stove top and scrape off gunk.
Apr 03, 2008 | Kitchen Ranges
Maytag,electric stove-
you need to order a custom control kit, electronic switch that contorls onlly that one burner
Dec 07, 2007 | Maytag MEC5430BDS Electric Cooktop
Where is the model number on my Range?
As you are facing the range, there should be a metal plate (held on by one screw) on the left hand side behind the console. Model and serial number should be located here. On some models the information will be along one side of the oven door opening, or bottom drawer. Hope this helps you.
Aug 11, 2007 | Maytag Model MER4351AAB
Kitchen Ranges Logo
89 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Joyce Nokleby
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
