Question about Radio Communications
Need Batery charger for ray 102 radio - Radio Communications
Ray 102 vhf radio
You may be able to find an aftermarket battery on Ebay, but I found the batteries to be so expensive, that I just waited for the unit to go on sale and bought a new one.
Apr 10, 2014 | Raymarine Boating
Ray 102 vhf radio
I had a similar situation, didn't have much luck on line. Finally I went to a local battery supply - like batteries plus, or similar. They used the information off the dadio and the battery to find a supplier. Not cheep though.
Need manual for a Raytheon Ray102 VHS Radio
I'm not sure what you want but if its for CB radio try cbtricks.com.
I viewed a RAY-Tel 102 service manual on this site.
Sep 22, 2012 | Radio Communications
Battery malfunction. both lights flashing on charger.
your batery has shorted you need a new batery I sugest you get another tool with same bater and charger just the batery alone will almost 1/2 this much
Oct 24, 2010 | Ridgid 18v Drill R86007 Rigid
I can't find where to conect the batery charger to the batery?
The battery is located under the seat. You can connect the charger directly to the battery there or you can connect the positive battery charger clamp to the post on the starter and the negative charger clamp to a good frame ground.
Good Luck
Steve
Oct 22, 2010 | 2003 Harley Davidson FLSTC Heritage...
Need a new rechargable battery for Ray 102 portable vhf.
Can get it Radio Shack,....hope this helps...
Feb 27, 2010 | Radio Communications
Cobra 29 NW ST No Sound, litesup, keys up, needle swings
It sounds like it may have been hooked up backwards when hooked up to the battery charger. If so it probably blew the polarity diode (D23) (1N4004) and with no sound it probably blew the audio IC (TA7222AP) mounted to the case of the radio. Also look at all of the large capacitors and make sure that the tops are not swollen or busted open if so they need replaced also.
Dec 28, 2008 | Cobra 29 LTD CB Radio
Replacement car charger
Try Radio Shack. They had a car charger for the 709 model
Dec 12, 2008 | Durabrand Televison & Video
Batteries not charging
Michael
Are the batteries the original power pack? this charger are disigned for work just for this batery packs only.
Check if the conctas on the battery lead for dust or corrotion.
Oct 08, 2007 | Motorola Talkabout T5700 AA (22 Channels)...
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
