Question about Goodman CLQ36AR49 Air Conditioner
Replacing old 3 wire condensor fan motor with new 4 wire
I'm going to replace the fan motor but the new one has 4 wires and so where does the extra wire go?
  • msweeth May 09, 2009
    Hey Mike and Seabreeze thanks for the info was a bad connection to the motor Mike
  • Goodman Master
  • 4,655 Answers
The extra wire is a additional speed wire and the existing model that you are installing is possibly not set up for that additional speed. It depends on the exact model of air conditioner that your post says you have, but we can never be sure until you confirm the model number of your Goodman, if its a split unit, a package unit or condenser fan or evaporator fan. Let me know all of those answers and I will help you determine the answer, Thanks, Sea Breeze
Posted on May 08, 2009
  • John Tripp
    John Tripp May 09, 2009
    Thank You for returning an answer and the votes! Bad connections to a motor will burn one out also. Wish I had the time to tell you all the repair war stories I have been through. Some were funny and others not a happy ending.
    But glad to here from you and what you found,
    Thanks, Sea Breeze
    Problem Solver:
  • 4 Answers
The new one needs its own capacitor 5 to 7.5 uf hook to the 2 brown wires
My Emerson model k55hxjcp-2593 electric fan motor has 5 wires connecting to the motor. The replacement motor only has 4 wires. I need to know how to connect the new motor seeing there is only 4 wires
the motor should have wireing diagram on side. i would expect 2 of the wires go to a run capacitor & the other 2 are your 110 or 220 depending on unit need.
Jun 17, 2014 | Coleman Mach III Air Conditioner
I have a 1994 olds. bravda 4.3, when vehicle is in the off and parked position with the key out of the ignition, the heater fan motor continues to run even with the fan switch in the off position, to stop...
Starting with the cheap, easy repairs first is the way to go. So, that being said, the relay would be the first thing to check. Replace the in-line relay and see if that fixes it
Oct 30, 2013 | 1994 Oldsmobile Bravada
Replaced a ge condensor fan 3 wire with new dayton the wires are different...old fan has a wire connectort mouted to it orange,black yellow, the new one 2brown 1 with white stripe, purple, black, i have...
the new ge fan requires its own capacitor, the brown and the brown/white go direct to new fan capacitor. black to relay (leg one of power) purple to relay (leg two of power. the compressor will have a wire to the relay and the other to the herm terminal. you now will have nothing to the original capacitor fan terminal.
The new motor will have the diagram showing this. you need the capacitor that goes with the new motor. the grainger guy should have sold that to you with the motor.
Apr 11, 2013 | Heating & Cooling
Can I replace 2 single capacitors on a A/C unit with 1 dual capacitor?
Yes. You will have the terminals HERM, FAN, and COM on the dual capacitor. You will take the wire that comes from the compressor to the Herm terminal, then there is a wire that comes off the contactor to the capacitor(s), that is the Com, you will run it straight from the contactor to the Com terminal. The fan motor will usually have two wires going to the capacitors, finding out which one is which can be difficult sometimes, but there are a few ways to tell. First, it usually has the fan motor wiring diagram on the side of the motor that tells you the colors and what they are. If that is not visible or accessible, then you can see if there are any brown wires. Those are usually the capacitor wires. Since I'm not sure of the model or brand of equipment you are working on, I cant say 100%. You will have up to 4 wires that come into the electrical panel. 3 wire motors are 1 Com, 1 Power. and 1 Cap. 4 wire motors add an extra Capacitor wire which can be eliminated when using a dual capacitor, but you have to know which wire it is. Commonly, there is a Brown wire and a Brown/White wire which you wire nut and insulate the Brown/White and just use the solid Brown. Process of elimination is used to find the Com on the fan. If you have found the capacitor wire, and found the Power wire, obviously the last wire is Com. When it's all over, you should have compressor on Herm, Common from the contactor on Com, Com from Fan on Com, and remaining wire on Fan.
Sorry it's jumbled a little, but without knowing what your working on, I can just give you the general basics. Hope this helps, if you have any questions, feel free to ask.
Jun 19, 2012 | Heating & Cooling
My old motor on my central air unit has 4 wires and my new motor has 5 wires. wich brown wire do I use and what do I do with the extra one
There should be a wiring diagram on the side of the motor. Usually when you have two brown wires they connect to the terminals on the capacitor.
May 05, 2012 | Emerson Condenser Fan Motor 1/6 Hp 230v...
I REPLACE CONDENSOR FAN ON A LENNOX BUT THE FAN IS OVER HEATTING AND STOPS& COOLS DOWN AND RUNS
Did you replace the fan blade or the fan motor? If you replaced the fan blade, is it exactly the same blade as the old one? If it has more blades, or wider blades, or if the blades are at a different pitch than the original, it is capable of moving a greater amount of air, but the old fan motor is not big enough in Horsepower to do the extra work. Thus, you should change the blade again to one that is exactly the same as the old one. If it is a window unit, you could try running the fan on a lower speed and it might work.If you replaced the fan motor, you must check to make sure that the new motor is exactly the same as the old one. You also could have it wired wrong, so you must check that also.
Jul 05, 2010 | Heating & Cooling
Can't find cooling fan resistor which i was told was located on the fan body. Low fan does not work...have replaced coolant switch at bottom of radiator. High fan comes on when heat gauge is about 3/4....
hi craig cooling fans on those cars have two or three connection wires. two wires means one speed. three wires means two speeds. they work with extra poles in the motor, not with a resistance. when you have a motor with 3 conn. wires and only one speeed, you have to replace the motor. most types haves only one speed. extra speed fan motors where optional for extra heavy duty or high temps. if you have more questions let me know. greetings.
Feb 22, 2010 | 1987 Volkswagen Cabriolet
Wire an AC fan motor
Look at the schematic on the new motor , but i think if the 2 purple wires go each one to each side of the capacitor, the black to line and you need to connect the other line which Im 99% sure is the whte wire which is the only one left.Remember you need 220v between the fan motor lines for it to work.
Sep 30, 2009 | Carrier 38CKC036 Air Conditioner
Goodman CLQ36AR49 Air Conditioner Logo
1,230 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
