Question about Staples Executive Desktop Tape Dispenser, Silver
How to change the tape roll
We cannot figure out how to change the tape roll, whats the trick
    Top Expert:
  • Staples Master
  • 78,010 Answers
Tape roll on what may I ask?
Posted on Jan 12, 2017
    New Friend:
Facing the dispenser with the cutting edge pointed toward you slide the axle to the left
Posted on Oct 24, 2014
How do you open a Scotch Tape Dispenser C60 to change the tape
The entire carriage lifts out using a good amount of lifting force. Slide your finger under the empty roll from the front of the dispenser. Apply upward pressure. You may be concerned that you will break the plastic roller, you won't. the entire carriage will pop up. When it does it's a simple matter to replace the old tape with a new roll. Snap the carriage back into place to use the new roll.
Jan 21, 2013 | Scotch C60 black 2 Tone Desktop Tape...
Minutes left on tape not displaying
Is it when you do playback on tape or when you do a recording
Dec 09, 2011 | Sony Video Cameras
When I push play there are lines and rolling and I can not control with tracking .
Always best to see if a good clean will do the trick. You can do this yourself better than a cleaning tape, but you can try one if you don't like the idea of messing with the VCR yourself. If you want to do the work, then get some Servisol Video 40 (you can find it on-line). Take the top cover off the VCR - disconect from the mains first. Then spray the servisol where the tape touches, especially the tape heads. If you don't know what to spray then after you take off the top of the VCR insert a tape and press play and watch where the tape touches. Remove tape turn off power and spray. You can use a cotton bud in the tricky areas too. Allow to dry and try a tape. You might have to do the clean again depending how dirty the VCR was. If the VCR lives in a smoke filled room that will make more work to clean it.
If it still doesn't stop rolling then you might have got a head fault.
Aug 20, 2011 | GE VG2040 VCR
Of BlackBerry 8900 trackball randomly scrolls to the top of the screen. And once this starts it does it continually. Then a next time it stops and doesn't respond to any movements of the track...
Sounds like you might have something stuck in the trackball. I would roll a piece of tape so the sticky side is up and roll the ball around on the tape to try and get some of the dust and other things off of it.
Mar 08, 2011 | Computers & Internet
Can't get the timer record to set. The tape ejects when I turn TV off. There is some trick and I do not have the manual to figure it out.
Try a new tape, or put a piece of tape over the hole found in the back of the tape you are using. If the record safety tab is still present it may be bent. A piece of tape will rectify this too.
The tab is there to protect the tape from being recorded over by accident. If removed or bent slightly, the vcr will detect it and will not record on the tape.
Most VCRs will eject the tape, or show some kind of error message.
Jan 04, 2011 | Symphonic SL2940 VCR
I need to change the wind direction from left hand to right hand. In order to remove the e-clip from the spindle, what tool should I use to remove it with?
A pair ofs tweezers should do the trick, and some tape.
You might want to try for more help.
Hope it helps.
Sep 22, 2009 | Bauer Premium Fly Reels Toys
I feel like a ****** but I can not figure out how to feed a new roll of calculator tape through the DR-T220 calculator. I see the picture inside but it doesn't help.
Put the roll in and feed the loose end up and actually all you need to do is put it between the two pieces of the hinge top. it is a thermal printer so it does not need to be fed like a regular took me a few tries before I figured it out.
Sep 15, 2009 | Casio DR-T220 Calculator
Yes you can. If you can see it, try using a magnet taped to a stick, or adhesive tape rolled sticky side out on a stick. If you cannot see it, get a dryer brush (~$10 @ Lowe's/similar). Bend the brush to approximate the curvature ofyour lint caxity and sweep it back towards you. Once you can see it, try the tape or magnet trick to remove it. Don't go any further into the dryer without unplugging the dryer.
Best regards, and happy fishing!
Jul 19, 2009 | Kenmore Elite Oasis ST 6806 Electric Dryer
Check Printhead cleaner Path
    1. Attempt to duplicate the message by turning the printer on, reloading the media, and printing several test prints.
    2. Note the movement and position of the carriage when the error occurs.
    3. If the carriage stops on the left-hand side (roughly 12 inches from the ink supply station), unplug the power cable from the printer, open the top cover and try to move the carriage to the right. Closely inspect the ink tubes for wear, and check for ink tube binding or catching on the tube guide (stopping/hindering carriage movement). If true, continue with the remaining steps below.
        NOTE: If the steps above do not describe the issue correctly, refer to the work instruction for a typical “Switch Power Off, Check Printhead Path” message (bpp90070).
Check/replace the Ink Tube Systemgtabtop.gif
    1. Turn the printer off.
    2. Remove the old Ink Tube System (refer to pages 8-53 of the Service Manual).
        NOTE: If the printer is installed on a Multi-roll feeder accessory, some additional disassembly is required to gain access to the printer. Instructions for multi-roll disassembly are listed at the bottom of this document for reference.
    3. Move the carriage assembly to the right side of the printer.
    4. Clean the rear tube guide assembly with a moistened lint free cloth to prepare the mounting of the Mylar tape.
      Figure 1:Cleaning the rear tube guide assembly
    5. Remove the backing on the Mylar tape and align the line on the tape with the front edge of the rear-tube guide so that the narrower section is towards the front of the printer. Do not attach the tape yet.
      Figure 2:Aligning line on Mylar tape with front edge of rear-tube guide assembly
        NOTE: Ensure that the Mylar film is perfectly aligned with the rear Tube Guide surface with no protrusions or unevenness.
    6. Carefully position the Mylar tape about 1/4 of an inch from the left-end of the rear-tube guide (do not go all the way to the end as the beveled edge will cause crimping of the tape).
      Figure 3:Attaching the Mylar tape
    7. Ensure tape is evenly positioned and any air bubbles are smoothed out along the tape.
      Figure 4:Smoothing out the air bubbles along the Mylar tape (view from rear of printer)
    8. Carefully fold under the narrow section of the tape to the underside of the rear tube guide assembly and smooth out any air bubbles.
      Figure 5:Installing Mylar tape under rear-tube guide assembly (view from front of printer)
    9. The Mylar tape should look like the image below.
      Figure 6:Final installation of Mylar tape (view from top of printer)
    10. Once the Mylar tape is installed, install the new Ink Tube System (refer to pages 8-53 of the Service Manual).
    11. Following replacement, verify printer functionality.
like a bad belt.
Feb 11, 2008 | HP DesignJet 1050c InkJet Printer
Tape wont register on this after we changed the tape
Make sure that it is installed properly ... going under not OVER. Does the paper feed when the paper feed key is depressed ??
1. Lift the paper holder up.
2. Fold the leading edge of the paper roll 3 to 5 cm. (Do not fold it slantwise.)
3. Insert the paper roll from the left side of the paper holder and make sure the paper
roll is set in the proper direction (with the paper feeding from the bottom).
4. Insert the leading edge of the paper into the opening directly behind the print
5. Press the paper feed key and feed the paper under the edge of the paper cutter.
Dec 07, 2007 | Sharp EL-2196BL Calculator
Staples Executive Desktop Tape Dispenser, Silver Logo
213 people viewed this question
Top Staples Office Equipment & Supplies Experts
Saleem Baig
Saleem Baig
Tom Chichester
Are you a Staples Office Equipment and Supply Expert? Answer questions, earn points and help others
