Question about Whirlpool SF367 Gas Kitchen Range
  • 146 Answers
Replace the sensor. Pretty easy. It's in the upper left or right corner of the oven close to the broiler.
Posted on Dec 21, 2007
My RBD275PDB14 Whirlpool double electric oven started displaying an E6 F2 error message and intermitently shutting down after a power outage. I replaced the control panel but it is still displaying the...
F2 - E6 Cancel key drive line open 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Nov 03, 2010 | Whirlpool RBD245PDS Electric Double Oven
My dryer is stopping after about two minutes and displaying message code F22. What is wrong?
its an open temperature thermistor located in the exhaust vent housing,usually between the blower and the rear exhaust opening that leads to the outside,the thermal fuse is also next to it on the tube
Jul 29, 2010 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Burners not comming on
Remove the grill and slide out the glass top. Take a close look at them burner. If all look ok then it may be the switches.
Jul 17, 2009 | Whirlpool RF379 Electric Kitchen Range
Whirlpool eletric range model RF363PXDW w/F1 display
The manual to this oven is here:
That should fix almost any problem you have
Mar 17, 2009 | Whirlpool RF364 Electric Kitchen Range
Roaring Sound During Operation of Dryer
Does the roaring sound occur after the machine warms up? If so, it could be a bad drum bearing. the heat from the dryer causes it to expand in its housing and, since it may been defective, could start "roaring". If so, The dryer drum shaft/bearing assembly will need to be replaced
If however, the roaring is immediate upon start up then u may have a bearing in your dryer motor. The entire motor may have to be replaced.
Dec 07, 2008 | Whirlpool LER4634J Electric Dryer
Whirlpool Gold Range Model#GR773LXSS (WD Sensor Open)
hi thanks for the question. the sensor at fault is located in oven top left looks like a pen , replace the sensor thanks the appliance doc
Oct 04, 2008 | Whirlpool GR773LXSS - Stainless Steel...
Whirlpool gold stove (wd sensor open)
on my stove i pushed the lock button for my oven now it want unlock. it is like it is froze up, it want let me cook or anything
Oct 04, 2008 | Whirlpool GY396 Electric Kitchen Range
Whirlpool Electric range model RF386
cant nfind euf5 code can find eo f5 its a door loc code saing the door and latch switches do not agree try pushing stop/cancel and try again also does the oven light go off and on when you open and close the door
Dec 31, 2007 | Whirlpool RF364 Electric Kitchen Range
F3 means the oven temp sensor has failed E0 means it failed open If you have a test meter i can tell you the resistance at room temp is 1100ohms. otherwise call for service Hope this helps PLEASE rate my solution Thnks...
Oct 02, 2007 | Whirlpool SF315 Dual Fuel (Electric and...
Whirlpool SF367 Gas Kitchen Range Logo
69 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
