Question about Sharp AL-1553 Black and White Copier
Sharp AL - 1553 is producing blank copies - we have put the stuff to be copied in the right way - what to do?
checkitright
  • 1362 Answers
SOURCE: wHERE CAN i DOWNLOAD A FREE iNSTRUCTION bOOKLET FOR A SHARP PHOTOCOPIER AL - 1552
tr this site you may have to register for free, and the manual is free
http://www.nodevice.com/user_manual/sharp/copier_and_mfp.html
Posted on Oct 01, 2008
  • 29 Answers
SOURCE: Sharp AL-1631 coper - toner problem
the problem in your machine is on the drum unit there is a arching on the mc unit.located in the upper portion of the drum unit.if you have an old drum unit try to install it again just for testing.and check if ther is a dumping toner again.
Posted on Nov 05, 2008
  • 5 Answers
SOURCE: Sharp AL 1631 ---- Getting blank copies
Hi, you can stop a copy half way to see if it image is on the on the drum if not check and make sure toner unit is turning. if not main charge. thanks dale.
Posted on Jan 23, 2009
tehnik_bdg
  • 91 Answers
SOURCE: sharp al-1631 copier wont copy
It probably the toner cartrisge is empty or if there's an error code H4, the heater lamp is spoiled
Posted on Apr 03, 2009
tehnik_bdg
  • 91 Answers
SOURCE: Bad copy from Sharp AL-1661CS
Try print from a pc, if those lines still appear then you should replace the drum unit. If not then clean the copy glass and the scanning mirrors.
Posted on May 13, 2009
Its a Sharp AL-1631. It'll copy from the auto feed
Check under the scanner, there is a scanner lock that you may have hit removing copies. Its most likely in the locked position and stopping scan.
Jun 03, 2011 | Sharp AL 1631 Copier
Our Sharp AL-1553 produces faded copies. The item which attaches to the side door and which faces the drum when closed, has a thin wire which breaks. The item has been replaced three times, but after a...
this unit is the main charge unit it holds a corona wire and is the length of the drum unit you can re wire it with a spool of corona wire how eber i would check from trhe people you are buying the unit from if there are any modifications for the unit i have not seen any break the wire breaks thats all
Jan 26, 2011 | Sharp AL-1553 Black and White Copier
When we switch it on it shows H then 4 and won't let us do anything. It's a Sharp AL 1553 PHOTOCOPIER
To reset the H4 condition on just about any Sharp AL series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
Some model's use 2 other initial codes, so you may need to use one of these 2 alternate codes to get your display to go blank. The rest of the procedure is the same.
Alternate codes are: #, * , C, * or pound,star,C,star and also
#, Interupt, C, Interupt
If done correctly the display should go blank.
Now key in 14 as if you were going to make 14 copies.
Now press the print button.
The machine should reset and the code should be gone.
9 times out of 10 this is a false code that pops up due to power surges or noise.
If the code comes back this means you have a heater lamp or thermal fuse (more common) failure in the fusing area and will need service.
Jan 10, 2011 | Sharp Office Equipment & Supplies
H4 showing on model AL 1553
Hello my friend.
It is a fuser temperature error or one of the sensors is dirty.
You could try removing the fuser assembly - ensure power is switched off- then try cleaning the sensors as they tend to get paper dust and melted toner which collects between the surface which senses the heat from the fuser `Hot` roller.
if this doesn't fix it you may need to replace the fuser.
There is also an engineer code that you can enter to clear the fault
PRESS: Clear - exposure - clear - exposure = the LED display will turn off.
PRESS: # of copy keys until you have 14 displayed.
PRESS: Enter.
Feb 05, 2010 | Sharp AL-1553 All-In-One Laser Printer
After putting on the copier the scan lamp carriage is vibrating for about 3 to 4 minuet then after the code e7 came.
You need to clear the code, press the following buttons in the order below.
  • Clear Key (far right key)
  • Exposure Key (far left key)
once you do this correctly the screen should go blank. Type in the following
  • 14 (using the copy quantity keys)
  • Press your copy key
  • 1 (using the copy quantity keys)
  • C (until the machine restarts)
If the code comes back then you are having a reference error and will need to call a local Sharp Authorized Dealer to service your machine.
Oct 09, 2009 | Sharp AL-1000 Copier
Jan 22, 2009 | Sharp AL 1631 Copier
Model al-1540cs, copier produce blank copies
THERE ARE TWO CORONA THAT PRODUCES BLANK COPIES, ONE IS IN THE DRUM UNIT ON TOP OF THE DRUM UNIT. THE OTHER IS IF YOU STAND IN FRONT OF THE COPIER OPEN THE COVER TO THE RIGHT, THERE IS A WIRE LOOKS LIKE A GUITAR STRING IF IT IS BROKEN OR MISSING, NEED TO REPLACE. GOOD LUCK
Dec 04, 2008 | Sharp AL-1540CS All-In-One Laser Printer
I have 2 model al-1540cs copiers that are producing blank copies. The scanner doesn't seem to be moving and is in the unlocked position. I am getting no error messages, the paper is facing in the right...
When [L1-00] appears, the scan head
locking switch is locked. Turn off the
power, release the scan head locking
switch, WAIT 10 SECONDS and turn the power back on.
Sharp AL-1553 Black and White Copier Logo
26 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
