Question about Amana Dryers
CHANGING HEATING ELECTRODE ON AMANA ELECTRIC CLOTHS DRYER MODEL N9O. YNED 7200 TW
SOURCE: Amana Electric Dryer runs but does not heat up - model ndw2330ayw -
I HAVE AN AMANA DRYER MODEL LE8217W2 ITWILL COME ON FOR A SHORT TIME AND THEN CUT OFF. I CHANGE THE BELT, THE MOTOR AND THE THERMOSTAT. THE DRYER STAYS ON , BUT WILL NOT HEAT UP. WHAT'S NEXT ???? PLEASE HELP!
Posted on Nov 06, 2008
SOURCE: Amana electric dryer model LEA30Aw will not heat
The heating element measures 10 Ohms at 68 degrees farenheit. Usually if the element is bad, it will measure infinity.
Posted on Dec 29, 2008
danromarris
  • 101 Answers
SOURCE: My dryer wont heat up...It just blows cold air....?????
It may be the thermal fuse but it could also be the heating element. The way to check is to open it up as described above and run the dryer. Watch the element and if it turns on then off again immediately then it is your thermal fuse. That is only about 15 dollars to fix and you can get a new fuse at any appliance repair shop. If the element doesn't ever come on then the element is burnt out and needs to be replaced. This is a little more expensive. I hope this was helpful and if you have any more questions feel free to ask me. Good luck.
Posted on Jan 22, 2009
erpaalai
  • 999 Answers
SOURCE: I have Amana electric dryer, model number LEA30AW.
There are 2 screws along the bottom and the lower panal will drop down and off. You can look in from there.
Eric
Posted on Jun 10, 2009
EllaWatson25
  • 725 Answers
SOURCE: I have an Amana NED7200TW Electric Dryer that was
You probably busted the element during the move and this not a serious problem. These parts are fragile and easy to repair. Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service and we will get the correct part out to you asap.Call us from 7 AM until 9 PM CST. We hope to help you repair your dryer. Thanks, Ella
Posted on Nov 17, 2009
Amana dryerned7200tw not heating. no error codes
Its either your 220 or heating element or thermal fuse use a continuity tester to see which one it is heres a link that might help.
Dec 04, 2013 | Amana NDE2330AY Electric Dryer
Amana 7200 no heat
That could be the heater element or one of the safety limits mounted on the heater housing. I looked up the model posted and this is a newer whirlpool dryer with the filter in the top. Here is my homemade video of one of these dryers with a heat problem:
Nov 12, 2012 | Amana NED5200TQ Electric Dryer
MY ELECTRIC AMANA DRYER HAS 3 SETTINGS .ON THE LOW HEAT IT WILL TURN ON BUT DOSENT GET HOT . ONT THE OTHER TWO SETTINGS IT JUST BEEPS AND WONT START.REPLACED THE HEATING ELEMENT AND THERMAL FUSE BUT STILL...
I would keep my patience and use the warm settings and use the cloths airer to finish the dry ing.
sorry for my late answer but I have not been feeling wellfor the past months-OK now or almost.
good luck
Kolbrun
Nov 22, 2011 | Amana NED7200TW Electric Dryer
Dryer will not start
It is very likely that the dryers heating element is burned out, that would be the 1st thing I'd test.
Nov 19, 2011 | Amana NED7200TW Electric Dryer
Amana 7200 dryer, runs but has no while running.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 31, 2010 | Amana NED7200TW Electric Dryer
Gas dryer neptun DC does not heat and dry cloths
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 04, 2010 | Dryers
Not drying my cloths . runs but there is no heat
Since the unit will run but won't heat...
The following are things that could stop an electric dryer from heating:
bad heating element(s)
loose, corroded or burnt wire(s)
thermostat(s)
thermal fuse ( not all models )
motor heat switch
timer
selector switch
The older the unit the more likely it's heating elements or thermostats
Sorry....this can take some time to diagnose
Apr 10, 2009 | Amana ALE866SB Electric Dryer
Dryer runs but does not dry my cloths.
Hello, If the dryer appears to be running ok but will not heat you probably have a bad heating element or switch. Usually the heating element.
I hope this helps
CYA Gator241
Feb 09, 2009 | Maytag PYE2300AY Electric Dryer
Dec 24, 2008 | Amana Dryers
Nov 05, 2007 | Amana NDE2330AY Electric Dryer
Dryers Logo
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
