Question about Yamaha Full-Size Keyboard
Trying to find felt strips to replace those on a yamaha clavinova clp930.
  • 1137 Answers
SOURCE: yamaha clavinova clp 200 - ear phone jack slid
The control panel hinges upwards and you have to move the keybed back a bit to get at the jack. All the screws on the bottom for the keybed. I'm not sure where the ones for the control panel are.
Posted on Oct 24, 2009
  • 5603 Answers
SOURCE: yamaha clavinova CLP200 the amp has lost power
I might suspect that the volume control itself may have a break in the resistance element by your description. There can be many causes however including LOOSE CABLES. IF the unit has been moved recently, then a loose cable MIGHT be the cause. In any case, servicing iis required. If you are not familiar with electronic repair you will need to find an experienced repairman.
Posted on Nov 10, 2009
  • 5603 Answers
SOURCE: Our Yamaha clavinova CLP-115 is buzzing, even with
Without power to the unit no sound should be generated. Make sure there are no other connections.
MAYBE you have a wall transformer behind it that is buzzing. MANY wall transformers develop buzz.
Another source is flourescent lights and even some of the low voltage halogens have noisy transformers in the base.
Posted on Nov 18, 2009
SOURCE: Can I replace the pedal unit to the Yamaha Clavinova CVP-75?
I can't solve the problem, but just wanted to sympathize because I have the same problem. My pedal is broken on my Yamaha Clavinova cvp85a. It worked wonderfully for years but finally it broke.
I'd be in the market for buying a new pedal or fixing the old one. But I've not found any suggestions in any of these forums for either solution.
Posted on Feb 27, 2011
sounddoctori
SOURCE: i need a replacement board XE771 for my yamaha clavinova cvp-20
406-582-5849 if you want to talk about it. I have one here and I'm repairing it. Maybe if yours has part of the upper surface intact I can figure out how to fix mine from yours and fix yours at the same time and test it here
Posted on Jul 20, 2012
HOW TO REPLACE CONTACT STRIP OF YAMAHA CLAVINOVA CVP 92 DIGITAL PIANO ?
Successful repair of my Yamaha Clavinova CLP 880
The principal to replace your contact strip will require one further step to that shown here where the customer has replaced the felts.
When you have the keybed out you will see the contact strip part 220. This is held in place behind the circuit boards. Remove boards, replace strip and reassemble.
It might be worth considering felts whilst you have the keyboard in bits as these wear out.
http://www.beckettsmusic.co.uk/shop/scripts/prodView.asp?idproduct=19108
Aug 09, 2014 | Yamaha Music
Yamaha clavinova cvp55
Try resetting the piano.
Mar 05, 2014 | Music
Yamaha clavinova repair
I Bim
which clavinova model you have
Jan 19, 2014 | Music
Need manual for CVP-700 english version
how opening yamaha cvp-700
Jun 30, 2012 | Music
I need a replacement board XE771 for my yamaha clavinova cvp-20
Apr 28, 2012 | Yamaha Full-Size Keyboard
Yamaha clavinova cvp-83s
Hi, did you manage to sort your problem as the same thing has happened to my clavinova (same model). Thanks.
Oct 05, 2009 | Yamaha Full-Size Keyboard
Jul 21, 2009 | Yamaha Music
Yamaha Clavinova CVP-83S NO SOUND OUTPUT
clavinova 83s...comes on but goes off within 20 sec.,sometimes comes on display lights up but no sound or functions?
Apr 01, 2009 | Yamaha Full-Size Keyboard
Yamaha CLP-860 Digital Piano Keys Making Noises
The part numbers are only available through the Yamaha Corporation. The Service manual, which is available for purchse (note that this is NOT the owner's manual) will have them.
I repaired mine on my own. I used a sticky foam tape of the correct width (approxiately 3/8 wide) and overlaid one layer directly over the original felt pad. I used a white foam tape like is used for carpet or other indoor needs. If I were doing it again I would probably use something just a little thicker and softer than what I used (appx. 1/16 thick).
Disassembling the Clavinova and removing the entire GH88 keyboard for this work is not hard if you are even moderately handy. I had the entire mechanics of the unit laid bare in 45 minutes with no manual (and not one curse word).
I am going to write up a tutorial on this soon as many people have asked about it.
By th way, I have heard that the factory pads are $100. My solution cost me about $3. Even if I have to do it again in a year, it's a win.
Nov 17, 2008 | Yamaha Full-Size Keyboard
Yamaha digital piano clp 170
This is a common problem with Yamaha keyboards. The problem is caused by worn-out rubber contacts in the keyboard assembly. In my old Clavinova CLP-500, there was one long rubber contact strip under the keys with two parallel strips of semiconductor material. The Clavinova circuitry determines key velocity by measuring the timing between when the key hits the first and second strips of semiconductor material. The harder you play a key, the less time it takes the key to hit the second semiconductor strip after hitting the first.
After years of playing the keyboard, the keys eventually cause tears in the semiconductor material and this messes up the timing measurement for key velocity. The only solution is to take the keyboard apart and replace the rubber contact strip with a new one.
I got rid of my CLP-500 four or five years ago and got a new CLP-170. The CLP-170 is now having exactly the same problem that the CLP-500 had. Yamaha has re-designed the rubber contacts in the CLP-170 so that there are now eight individual contact strips instead of one long one. The problem is essentially the same, though. You have to take the keyboard apart and replace the worn out rubber contacts.
Here are the part numbers for the rubber contacts that need to be replaced in the CLP-170: V8286600 Rubber Contact, 12 keys, D-C#   Qty. 6 V8286800 Rubber Contact, 11 keys, A-C#   Qty. 1 V8286700 Rubber Contact, 5 keys, D-C   Qty. 1
I suggest you also get a copy of the CLP-170 service manual, part number 001677. It has descriptions of all the steps necessary to take the thing apart and put it back together again. You'll also need a "rod" (which is just a long dowel), part number TX000670. Before you take the circuit boards off the keyboard assembly, you have to insert the dowel between the keys and the frame to keep the keys from falling back and getting in your way. A 5-foot long 1/4-inch dowel will probably work. (I haven't yet taken apart my CLP-170, and I don't have Yamaha's "rod," so I'm not sure if 1/4 inch is the right size or not. I'll report back here if it's not.)
Good luck, Howard
Sep 03, 2008 | Yamaha Full-Size Keyboard
Yamaha Full-Size Keyboard Logo
62 people viewed this question
Top Yamaha Music Experts
Matthew Spark
Matthew Spark
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
