Question about Kohler K-3386-0 Rialto one-piece round-front toilet with seat and left-hand
We want a soft close seat for the rialto - Kohler K-3386-0 Rialto one-piece round-front toilet with seat and left-hand
I have a Koehler model 703 84679aa. The seat bolt is loose and you cannot get to the but without pulling the toilet. Does anyone know how to tighten the seat without removing the whole toilet?
Kohler Rialto / San Raphael toilet problems # 84499 ...
? 13:04
www.youtube.com/watch?v=Hmhb4H4HYMY
Mar 31, 2012 - Uploaded by Dino Pinch best kohler rialto / san raphael toilet repair video on youtube. ...the kohler brand rialto model wisks away the offending lumps of ur behind product, never to be seen again. .... 'can't screw a lightbulb in'. .... How to Install Toilet Seat on Kohler One-piece ModelK3434 - Duration: 7:10. by emf4kv 20,891 views.
Jul 26, 2015 | Home
Self closing all in one tolet seat boxed, hidden screws, how to tighten
If you are trying to install a standard toilet seat on a special "smooth sides" toilet, it likely will not work. Most hidden bolt toilets come with a special seat because you cannot get to anything from below. This special seat has a set of expanding style bolts that are attached to the screw that is part of the seat. The plastic expanding bolt goes into the hole(s) on the toilet, and as you tighten the screw on the toilet seat bolts, they expand the plastic part in the hole of the ceramic toilet.
Aug 29, 2013 | Kohler 3386-6 Rialto Skylight Round Front...
I have a koehler rialto toilet and am unable to replace the seat as the screws keep spinning and there is no way to access the bolts form underneath as the toilet is totaly sealed. Other than replacing the...
Wrap a putty knife with a wash cloth, and push it between the toilet ceramic surface and the plastic hinge for the seat. Wedge it in there. Now try unscrewing the hinge screw. This provides back pressure against the hidden nut on the other side and may let you successfully remove the screw.
Jul 04, 2011 | Kohler 3386-6 Rialto Skylight Round Front...
Rialto toilet flapper pulled to left and does not seat
The pull mechanism can be replaced with a universal one. This isn't a free thing but there are several different length's.
Pull yours out [ simple to do - unhook - use a pair of pliers and remove the large nut inside the tank and remove]
then take it and compare with a longer one. - Or there is a chain extension if you want to go that route.
Best of it
Mar 20, 2010 | Kohler 3386-6 Rialto Skylight Round Front...
Is it easy to enlarge the holes on a koeler toilet
Enlargeing the holes will not turn out well.
Modify the seat to take the plastic bolts.
Hope this tip helps.
R/
David
Jan 19, 2010 | Kohler 3386-6 Rialto Skylight Round Front...
I can't unscrew the bolts on my Kohler 3386 rialto toilet to replace the toilet seat.
There is clips where the bolts should be .Flip the clips up grab hold of the seat and pull it strait out towards the front of the toilet.
Dec 03, 2009 | Kohler K-3386-0 Rialto one-piece...
Kohler Rialto flap valve leak
if so cut 1/4 inch off the bottom of round part of flat valve
Feb 23, 2009 | Kohler 3386-6 Rialto Skylight Round Front...
Kohler K-3386-0 Rialto one-piece round-front toilet with seat and left-hand Logo
32 people viewed this question
Top Kohler Home Experts
john h
Tim Whalen
Mike
Are you a Kohler Home Expert? Answer questions, earn points and help others
