Question about Motorola Mobility Digital Baby Monitor 7-inch Flat Screen MBP700
Picture is fuzzy and background is pink - Motorola Mobility Digital Baby Monitor 7-inch Flat Screen MBP700
Pink sky in background.
Try and use the SCN. Mode.
Bright light is never recommended for any pics.
Contact KODAK they might have more ideas or can arrange a repair for you if needed.
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 25, 2009 | Kodak EASYSHARE M1063 Digital Camera
Pink color background and on clothing in sunny shots using auto
That is typically a bad CCD sensor.
To start you can take out batteries for a couple of minutes , but I do not think that will solve the problem.
The CCD sensor is the optical device that captures light and generate the picture on a digital camera.
Whe it is faulty it must be replaced at a repair centre.
Canon covers the repair expenses for CCD sensor replacement , even when warranty is expired on several of their models.
Call manufacturer at the number listed on the user manual to get information, if your model is in Canon list you may have the repair done for free, otherwise get a quote on repair.
May 29, 2009 | Canon PowerShot A630 Digital Camera
Pink scrable in background
your cable provider is using high compression causing the distortion.
Dec 07, 2008 | iLO 3200 32 in. LCD Television
I can hear background music but no picture on any tv i try
The solder under the GPU has lost Contact. We do offer this repair service. email us
xbox360fixer@comcast.net
Thanks
Oct 03, 2008 | Microsoft Xbox 360 Console
Pictures appear with a pink background
I had the same problem with the Canon PowerShot S410. I called Canon and they said it was a known issue. They are going to send me a return, paid postage label and replace the sensor at no cost. Canon rocks!
Liz
Nov 11, 2007 | Canon PowerShot S500 IXUS 500 Digital...
Fuzzy and ghost picture
Sounds like Either the cable from the wall to the TV is bad usually this will cause ALL channels to be fuzzy.Or your cable on the outside of the house is damaged.another common problem is the outlet on the wall has a bad connection.If they get painted over with wall paint this will also cause the problem.change the wallplate.If its damaged outside the cable company will usually fix it for FREE.you pay for the service and it their responsibility to make sure you wiring outside the house is working properly.
Nov 03, 2007 | Televison & Video
Picture problem
i have vizio that turn on, but no picture, and the invarter light is on and it won`t turn off.
Oct 20, 2007 | Vizio L30WGU 30 in. HD-Ready LCD...
Plasma TV
If you mean the picture froze or formed fuzzy pixelated picture and crackling, this will be due to a poor aerial signal to the tv, but if you mean the screen rolls with pink/white patchwork type squares and shows the picture in the background, all be it fuzzy, then that's the same fault as I am getting and have had to report the fault to LG as I am on my second TV. If it is the problem mentioned in the first sentence, it is happening to our friends in OS and they have been told by specialist aerial fitters, the signal is too weak for the tv.
Mar 16, 2007 | LG 50PX4DR 50 in. Plasma TV
Motorola Mobility Digital Baby Monitor 7-inch Flat Screen MBP700 Logo
44 people viewed this question
Top Motorola Mobility Baby Gear Experts
Dorel UK
Dorel UK
Are you a Motorola Mobility Baby Gear Expert? Answer questions, earn points and help others
