Question about Kenmore Washing Machines
Floor is wet after washer spins out when washing king size comforter
After washing our comforter the floor is wet under and around washer...Kenmore model 2130
    Habit-Forming:
  • 88 Answers
Check the door seal is in the correct position and is not cracked or porous
Posted on Nov 26, 2013
aborcass
  • 2651 Answers
SOURCE: HE4t King Size Washer Balance Problem
remove the lower acess panel ( 3 screws across bottom) check for broen suspension/shock absorbers
Posted on Mar 03, 2008
Destinova
  • 46 Answers
SOURCE: Kenmore Elite Heavy Duty King Size Capacity Top Load Washer Won't Spin/Agitata
I am sorry to say that you WILL need a tech to come out and service this unit.  From what you are telling me it is either a dead short in the motor, OR one of the conntections got wet and cause a short.  BUT I would put my money on the motor, since this is a direct drive unit.  Sorry
Posted on May 26, 2008
  • 198 Answers
SOURCE: Kenmore 70 series washer will not spin, clothes are too wet
Not a belt, this is only a sound deadening devise on the brake housing. Not really needed. Replace the coupler
Posted on Jan 05, 2009
honeymokey
  • 3113 Answers
SOURCE: Washer will not stay balanced on spin cycle no matter what size load.
The tub brace or spring may have come loose.
Posted on May 05, 2009
  • 311 Answers
SOURCE: My Kenmore Elite washer spins to slow cauisng the
If this is occurring mostly on heavier loads your clutch may be slipping. If you take a flathead screwdriver and push down the lid switch so the washer will spin with the lid up, grab the inside of the drum. If you can easily stop the drum its most likely a bad clutch. If you tip the washer back and see oil underneath then its probably your transmission leaking oil onto the the clutch causing it to slip (in which case you need transmission and clutch assy). If you see oil I would probably not bother calling a tech it would be a pretty expensive repair.
IF the problem is with the clutch only it may be worth repairing but to replace the clutch you will have to remove the pump, motor, transmission, and the clutch mounts on top. The other less common possibility could be a bad drive block under the inner tub. hope this helps. _MJ_
Posted on Jan 28, 2010
Just want to know the cubic foot load capacity of my kenmore front load washer 592-49047 so I Know if I can wash my king size comforter in it
I wouldn't recommend washing a king size comforter in your machine. That would be ******* it. I take mine to a laundry mat where they have bigger machines.
Mar 25, 2016 | Washing Machines
How do I balance a Kenmore 70 series washing machine.
Wood laminate flooring is never a good idea in areas that can get wet often. But, that being said, there should be leveling feet on the washer which should allow you to get it stable on the floor, if that's what your problem is. If your problem is that the washer tends to walk around the room when in the spin cycle, well that is partially due to the fact that washers often vibrate when they spin, especially when spinning large, bulky objects like quilts and comforters, that the feet on the bottom of washer are smooth plastic, and that smooth plastic feet don't stay in one place to well on wood laminate floors.
Mar 04, 2015 | Kenmore Washing Machines
Vibrates when it spins
Here are a few quick facts on washing machine vibration.
  1. All washing machines and dryer vibrate. Dryers usually have less vibration than washers because the load is only wet clothes (as opposed to a drum of water and clothes). Front loading washing machines cause high frequency vertical oscillation while top loading washers usually have horizontal oscillation.
  2. Almost all front loading washing machines are not recommended for use on standard joist-construction floors (most common floor type, compared to a concrete slab sub-floor). Manufactures like GE, LG, Maytag, Samsung, Whirlpool, Kenmore, Bosch and more, all recommend installing a pad like Silent Feet under the washing machine to absorb the vibration.
  3. The only alternative to using Silent Feet pads to prevent structural damage is costly upgrading of the sub-floor. This usually involves adding a second layer of plywood sub-floor and adding sister boards to the rafters that support the floor. But even this won't reduce the amount of vibration noise that you hear. Sub-floor upgrades can cost thousands of dollars.
  4. Vibration can also cause appliance "walking" (unwanted movement) usually during the spin cycle. Simply installing a pad designed to prevent walking can solve this problem and mean that you'll never have to reposition your washer after every load again. Both Original Silent Feet and Anti-Walk Silent Feet prevent walking, however for washers that move a lot or stacked units it is recommended that you install Anti-Walk Silent Feet for the best results.
You were not specific in either type or model. I hope the above information helps. Also, the size of the loads plays a great part in how a machine functions. have a nice day
You wer
Dec 16, 2013 | Kenmore Washing Machines
After washing comforter there is water on floor on Kenmore 2130 top load washer
This happened to me a while back...the comforter was too much for the washer & water sloshed over the rim of the tub... The rest of the laundry sent fine...no water on the floor!
Nov 26, 2013 | Kenmore Washing Machines
Washer is extremely loud
defective back bearing and spin basket..onthejob
Feb 03, 2009 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Jan 03, 2009 | Kenmore 24032\24036 Top Load Washer
What is the capaity of 2005 Kenmore Elite Washer and Dryer, models 110?
Starting in early 2002, the capacity sizes were changed around a little bit. A normal sized washer now all have the same sized tubs (pretty much) in the 110 series (Whirlpool Manufactured) washers. The capacity is now rated somewhat by the agitator action the washer comes with. Depending on the type of agitator you have, will determine the capacity. King size capacity means you have a pretty good capacity (size wise) than others. You have normal capacity, large capacity, super capacity, king capacity, and I even think they have canyon (yes canyon) capacity. Capacity sizes dont really mean to much though. In order for you clothes to get clean, the must have room in the tub to move. The must be able to float up, then get pulled down by agitator action. That should determine the size of what goes in the washer. Always use same type clothing when doing laundry (i.e. towels with towels, sheets with sheets, etc, this will keep the load balanced better). Watch what you load, comforters are ok (per manufactures ok) but I do not tlike the idea unless its a front loader, and only by itself. Let me know if this helps you out any.
May 10, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Mar 02, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Kenmore Front Loading Washer Slow Final Spin Cycle
out balance are water still in tub will do that try cleaning out the pump filter under the panel at the bottom of the washer some have a big white looking screw you turnit remove filter if there water in it it will flow to the floor so have something to catch it with
Jan 26, 2008 | Kenmore 44102 Front Load Washer
Washing Machines Logo
41 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
