Zenith floor model tv
I am in need of IC 221-652-01 for a Zenith model: SF2517TR. Please advise if you know of a source. Thanks, Roscoe Spencer 309 792-0622 Mars Electronics
    Top Expert:
  • Televison & ... Master
  • 74,383 Answers
jimbo4026
  • 50 Answers
SOURCE: can't get my zenith TV off Video mode
not sure what year this tv is, but I had some where the tuner was bad and would be stuck on video. The only way is replacing the tuner. Or you may want to try hooking up a vcr into the video audio jacks and run the channels from the vcr it may work yet.
Posted on Nov 28, 2007
SOURCE: need a code for my tv zenith
Zenith Product Codes
TV Mode Zenith Code 101 - VCR Mode Zenith Code 201 - Cable
Mode Zenith Code 353 - AUX Mode Zenith Code 401.
Programming Codes---
TV - 101 149 175
Posted on May 07, 2008
daniel719
  • 240 Answers
SOURCE: need zenith tv codes
with zenith you can only replace the eprom to reset the unit. once it is locked up.
regards,
daniel
Posted on Jan 13, 2009
Shuttle83
  • 1139 Answers
SOURCE: cannot connect zenith vcr to zenith tv thru cable box
Hello mcgillicu390,
From your VCR you should have an (RF OUT) and an (RF IN) Connector (these also might be marked as ANT IN and ANT OUT, or CABLE IN and CABLE OUT).
The same goes for your TV (RF IN), (ANT IN) or (CABLE IN).
Now, take your Coaxial Cable (Cable with screw on or Push on connector with a wire in the center of it) and connect it to the TV (RF IN), take the other end of the same cable and connect it to the VCR (RF OUT).
Then connect your cable TV set top box or antenna to the (RF IN) of the VCR.
If you are using a cable box set your VCR and TV to Channel 3 or 4 (depending on your area)
If you are just using the VCR and an antenna set your TV to channel 3 or (depending on your area).
That should do it for coaxial connectivity.
If you are using the composite video and Audio cables to connect to your TV here are the directions for that.
Looking at the back of your TV you will see Three RCA type connectors colored as Yellow, White, and Red. Yellow is Video, White is your Left Audio, and Red is your Right Audio. They should be marked as (Video IN), (R Audio IN), and (L Audio IN). *note these markings may not be exactly like what is written, however the indicators should be close to what you are seeing.
Now look at your VCR, you may see a lot of RCA Connectors (up to 6 of these connectors) don't worry, you are only looking for the ones that say (Video OUT) (R Audio OUT), and (L Audio OUT).
Once you find the connectors on both pieces of equipment, take the Yellow, Red, and White tipped cables and plug the in their respective jacks Yellow tipped cable connects VCR (Video OUT) to TV(Video IN). Red tipped cable connects VCR (R Audio OUT) to TV (R Audio IN), and finally White tipped cable connects VCR (L Audio OUT) to TV (L Audio IN),
Once the cables are connected you will be able to use the composite selection on your remote to view the images from your VCR, the VCR in this case will be acting as the tuner for your TV with out you having to set the TV to channel 3 or 4, you will just have to use the AUX or whatever setting on you remote that allows the composite video to display.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Posted on Mar 27, 2009
bernardlunda
  • 318 Answers
SOURCE: Zenith tv picture jumps after 20-30 min.
the variations of the supply causes that. a verticle stability be checked, specially semiconductors and capacitor changing valuas
Q= CV
Q=IT
THEREFORE
IT=CV=Q AND frequincy = f=i/t
so if I AND T CHANGES CAUSING MOVEMENT OF PICTURE
SO I is for time and T for tempareture
Posted on Mar 28, 2009
When I turn my TV on, I have sound but only a horizontal white/color line across the screen. My TV is an old Zenith 25" floor model.
You can buy a new one for less than 200 bucks. I'd advise you do this. It sounds like you need a new
picture tube
Dec 31, 2010 | Zenith C27A24T 27" TV
HAVE A 25' 1990 FLOOR MODEL ZENITH AND BOTH SPEAKERS WORK BUT THE VOLUME IS NOT LOUD PLEASE HELP
Hi! have your unit check by a qualified technician. its either you have some leaky capacitor on the audio amplifier.
Sep 11, 2009 | Zenith H25F36DT 25" TV
Our Zenith tv has a line across the center and the rest of the screen is black. The sound is not affected. Is this expensive to fix
The problem is either poor solder connections at the vertical IC or a defective IC. EIther is relatively simple to fix if you can solder. Also, be aware that there are potentially dangerous high voltages present inside even with the unit unplugged.
Having said this, please confirm the model number and I'll post the part numbers and approximate cost.
Thanks,
Dan
Aug 07, 2009 | Zenith Z32H41D TV
What would cause a straight line threw tho middle of my tv monitor. I have a zenith model number z27h96r8.
If this is a straight white line you may have a vertical collapse. You need to either solder bad connections at Vertical IC or change the vertical IC
Apr 23, 2009 | Zenith Z27H96R 27" TV
My Zenith DVC player has quit shownin movies etc. in color. Only black & white
I just went out and bought a new DVD. Since my Zenith was a "cheapie" buying a new one seemed the thing to do.
Thanks for your response.
Jack Spencer
Jan 05, 2009 | Televison & Video
Horizontal line in top screen
could be vertical output IC or capacitors located close around the IC
Nov 27, 2007 | Zenith B25A24Z 25" TV
Vertical/horizontal
Since you can bang it to heal it some, try checking for cold solder joints. Caps and IC's next. Careful TV's store up to 3000 K volts unplugged. Enuff to kill.
Sep 10, 2007 | Televison & Video
R57w46 zenith
Hello Was wondering if you ever found anything out how to reset the IC Screen Numbers or what the factory numbers all are on the Zenith Rear Projection TV Model # R57W46? I have the same problem ! My 2 year old son, not knowing how he did it cuze only a technecian is suppose to get into this screen, but he did change numbers in the too. I called zenith themselves and no luck ! My screen is bowed , etc.. Any Help ?
Jan 16, 2007 | Zenith R57W46 57" Rear Projection...
Televison & Video Logo
75 people viewed this question
Top Televison & Video Experts
Electro Med Services...
