Question about Crosley Keepsake USB Turntable
Record arm does not retract - Crosley Keepsake USB Turntable
2 Suggested Answers
SOURCE: Tone arm retracts before recording is complete (CR-245)
The nickel on the tone arm is the best solution that I have found. I taped a nickel onto the head of the tone arm about 1/4 inch back from the point of the stylus and then taped 3 quarters near the fulcrum to slightly counterweight the nickel's effect. This fixed one of the disc skiing that my Crosley had when I first got it. A new stylus is in the mail and I will try the new needle without the nickel and quarters to see if the original needle was just bad.
Posted on Feb 15, 2010
Wurlitzer tone arm will not retract after record over
sorry to ask but is the jukebox we are talking about?
its just I have never heard of it iam from the uk.
if it is I think I have found a manual for it if you don't have one. http://www.carlhaines.com/jukebox/manuals
Nov 08, 2016 | Wurlitzer Audio Players & Recorders
On a L-A55, what causes the arm to retract not high enough and cause the needle to scratch across the record?
I think you you mean the lift and there is are screw on it , and a feather on the other side, turn the screw to the the right a bit , so it gets a little lower
Oct 16, 2014 | Audio Players & Recorders
Record doesnot finish and tone arm does not retract
Are you sure that the deck has an auto retract function? Give make and model please
Aug 31, 2014 | Audio Players & Recorders
When inserting vhs tape, the player pulls the tape from inserted vhs
That is exactly what a typical M-Load mechanism is supposed to do. Once the VHS tape cassette is inserted, cassette housing cover will be flipped up and two arms will pull tape out of cassette housing to wrap tape around cylindrical spinning head housing that contains video heads and, if VHS HI-FI, audio heads as well. When stop or eject button is pressed, arms will retract and tape will wind back into cassette housing. What type of problem are you experiencing with unit? It may have nothing to do with M-load engaging tape around head cylinder.
Mar 22, 2014 | Samsung DVD-VR325 DVD Recorder/VCR
Tone arm consistently retracts as if the record was finished
Without the make and model, I can't give you much at the moment, but if the unit is an older one, the problem is that the grease has gotten stiff and won't let the mechanism work properly. Please update this with the make and model and more specifics will be provided.
Thanks,
Dan
Oct 02, 2010 | Audio Players & Recorders
Tone arm goes to record but retracts to start position
Afraid I have no solution, but suffer the same problem. It comes and goes without a pattern. I'm happy with all other elements of this turntable I have successfully converted over 100 LP's into .wav files at this point.
If it's easier, email me at eglerum@advantageiq.com
Mar 01, 2010 | Sony PS-LX300USB Turntable
actual old units (not sure about modern nostalgics) sometimes had a lever that said 7 or 12 inches for 45's or 33's this would tell the mechanism when to set down the arm. If your unit does not have something like this then it sounds like an internal failure that would require it being opened by a tech or sent in for warranty repair.
Feb 10, 2009 | Crosley CR249TA Turntable
Miele Dishwasher door release problem
I switched the dishwasher off at the mains and then back on again. At this point the plastic arm started making a noise like it was trying to retract so I pulled the door to help it along. The door opened and the arm fully retracted - much to my relief.
Mar 15, 2008 | Miele Dishwashers
Record won't retract
If it isn't making any move to retract the tray it's probably the trip switch. If you look in the back and follow the mechanics under the tone arm you'll see how it closes a switch as the arm goes to the centre of the record. Clean the switch or adjust it.
If it is half returning the tray it is the tray stack all gummed up. Use Servisol Silicon spray or have it rebuilt by someone who knows how.
Dec 06, 2007 | Wurlitzer Jukebox 1015 One More Time...
Crosley Keepsake USB Turntable Logo
44 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Sam Palermo
Sam Palermo
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
