Question about Hotpoint TDC32 Electric Dryer
Cotons high heat not working ctd80
But iron dry working and synthetics working
    Prodigy:
    An expert who has answered 500 questions.
  • 512 Answers
One element could be broken , dryer takes two for high and only one for lower temps
Posted on Dec 01, 2013
Whars the correct way of cleaning and drying my activewear?
Top wear or underwear are pretty much the same. Machine wash, cold water, high efficiency detergent on a setting for synthetics.
For underwear use fabric conditioner and air dry, with a tumble dry when almost dry, on a low heat, warm setting.
For outerwear dry on a hanger and spray twice with silicone water repellant spray allowing a couple of hours between sprays. Make particular attention to seams.
Nov 24, 2015 | Motorcycles
Tip
How to avoid damage your hair when using a hair straightener
1. Choose a hair flat iron depend on your hair type
The plate of a flat iron can be made by different material, while some materials will straight hair in a single pass, others might require more effort. So, before you go out and buy a straightener, you need to know which plate material suits your needs.
2. Go for Adjustable temperature Controls
No matter what type of material an iron has, it can malfunction. So, always invest your money in a straightener which has low, medium and high temperature settings. Afterward, to give your hair your favorite styles, try to keep the heat as low as possible.
3. Choose Size wisely
If you have short hair, you might want to go for a smaller iron. Conversely, only if you have extremely thick hair than going for a larger iron.
4. Fully Dry Your Hair
Unless you are using a wet iron, it's imperatively you fully dry your hair before ironing them. For, if you have wet hair while ironing, boiling the moisture out of them might do serious damage.
5. Use a heat protectant
Better be safe than be sorry. You don't want your hair to lose too much moisture while ironing. So, you might want to apply a heat protectant which will retain moisture in the face of excessive heat.
6. Don't heat one section for too long
While ironing hair, it is best that you divide them into different parts. Afterward, straighten each part for a specific time period which shouldn't be too long. For example, if you are using a flat or curling iron, it is essential that you never heat a single section of air with it for more than 5 seconds.
Source : http://selectedo.com/best-hair-flat-irons/
on Sep 29, 2017 | Health & Beauty
Dryer is new but only gets warm
Sometimes there is a switch for low heat - for delicates or synthetics and a high heat for cottons and linens.
Or there may be an ECO setting to dry clothes using less power but over a longer period of time.
Make sure the correct setting is chosen.
If this does not help, return it for a replacement as it is new. Do not accept a fix on the existing dryer.
You have rights as a consumer. A dryer that does not dry properly is not of merchantable quality.
Mar 15, 2015 | Dryers
Mi plancha modelo G1490 no calienta, no prenden los lod diodos wool silk y linen coton y max.
follow this steps and fix it. God bless you
f the iron doesn't heat, make sure power is on to the outlet, check the electric cord , and check the thermostat and replace if necessary. If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below).
If the iron produces too much or too little heat, test the electrical cord. Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle (see below).
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Oct 27, 2013 | Tefal T-fal E9421364 Castiron Plancha...
Bosch iron TDA8320/01 soleplate marked
pan scrub or brillo pad soft wire wool you could heat the iron up and use hot soapy water on a dishcloth but be careful not to burn fingers as the cloth will get hot aswell
Apr 01, 2013 | Bosch TDA8340 Iron
It is still not working plz can u help It still flickers
This is typical with many sets when it goes old as there is a high possibility that the components over a period of heating and cooling , tend to bring on a problem of dry soldering. So my advice is to check the set for some loose joints that have played on to give you these erratic shut downs.
Remove main plug, the covers - with caution of high voltage, check for dry joints, use a good soldering iron to solder all suspected points.
May 28, 2011 | LG Televison & Video
No picture no sound
Since power is working the fault is related to the tuner and associated circuits.
Apr 15, 2011 | Televison & Video
Fleece shirt melted on the bottom of non-stick iron
well try heating the iron and rub the wax on the heated iron and wipe it off using cotton cloth
Jan 04, 2010 | Sunbeam 4237 / 4238 Iron with Auto...
BRown water and stuff coming out of iron
Hi, two problems:
DIA' s problem - the brown water is due to poor water quality and debris in the boiler and iron sytem. Rowenta is clear that they do not want anyone to cleaning solutions - only clear filtered drinking water to rinse out the boiler (via the water inlet screw hole) and I have found running the system dry, letting it cool, rinsing and draining the boiler several times before putting unit away works fine.
Guest' problem with brown/black tar substance is likely caused by too hot and iron setting (steam setting may also be too high) for ironing man-made synthetics (like Nylon, Rayon, Polyester or blends are basically petroleum based fabrics) that breakdown or melt, leaving deposits on the iron's stainless steel soleplate. A secondary cause could be bad water or debris in the boiler/iron in which the solution for DIA's problem might provide relief. Cleaning the soleplate is tricky, I use nothing stronger than an old fashioned wooden orange stick to gently scrap of all traces of the "stuff" and dry "Dutch" cleanser w/ a terry cloth or old cotton sock to polish without scratching the soft stainless soleplate...
Apr 01, 2008 | Rowenta DG-980 Iron
Dial stops at "silk."
if the iron is under warranty send it back to the company.if not take down the iron it has a broken part that is stopping it from moving properly.good luck.
Apr 02, 2007 | Rowenta Perfect Iron
Hotpoint TDC32 Electric Dryer Logo
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
