Question about Motorola Mobility TZ710 Bluetooth Car Kit Speaker
Failure of audio
The motorola TZ 710 blue tooth car kit speaker will pair with the phone but there is no audio
When i try to pair with my galaxy tab s through bluetooth the tab goes through the process of connecting but doesnt pair however my galaxy s5 phone pairs immeditely ?
  • Your issue is that you can only connect one mobile or tab to a blue tooth.
  • It only accepts one device at a time.
  • You need to connect one to your blue tooth in your vehicle and try something like a blue tooth pill or blue tooth speaker.
  • I have had this problem with my Parrot car kit.
  • Hope this helps. Russell
Nov 22, 2015 | Cell Phones
Motorola bluetooth phone will not pair with jbl charge 2 wireless speaker.
What model phone? Have you gone to JBLs website for troubleshooting?
Mark
Motorola Support
Mar 16, 2015 | Motorola Cell Phones
My phone has no sound, and it now says "-Car Kit-" WHY?
Firstly i come to your 2nd question where you asked what the meaning of Car Kit. Bro Car Kit means a sound system which contain also blue tooth, DVD, FM etc. So in Car Kit any one can pair their blue tooth devices i mean your cell phone where blue tooth are available. So when you pair your device at the define range then Car Kit will be connected with your phone so when your receive or dial a call then the Car kit speaker will be active automatically. You can hear voice from there.
Now come to your next question,
If your Car is off or you are so far from car then your speaker will be enable normally but if it don't work then means your speaker disable or inactive. As a result, you have to change your speaker by a expert technician then you will release from this problem. Thanks a lot
Nov 09, 2012 | Cell Phones
Can't remember how to pair my LG HBM-710 to my new phone - Samsung Fascinate. Can you help?
to pair a blue tooth device to a phone first you must turn the bt power on the phone to on,then you have to put your blue tooth device into discovery mode,now most manufactures use the power button for thisw feature.By holding down the power button on your device when turning it on for 6 to 10 seconds it usually puts the device into discovery mode.there should be a light that stays on on your blue tooth device.once you have the bt device into discovery mode you will be able to pair the device to your phone by search or add new device,once it pairs it will ask for a pin or pairing code.most manufactures of blue tooth devices use a 4 digit factory pin pairing code they aare as follows 0000,1234,9999,or 1111 once youve put tjhe pin code on they will pair ,i hope this helps
Feb 25, 2011 | LG HBM-710 Wireless Headset
Need password to connect to my phone. Motorola bluetooth H371
Hi,it all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Hope it helps..
Thanks for using fixya...
Oct 27, 2010 | Motorola Mobility H371 Bluetooth Headset
My nokia 2330 classic doesnt pair with my parrot 3200 ls color. after synchrinsing them unable to get authorisation code
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
Take care.
Aug 16, 2010 | Parrot 3200 Ls Color Handsfree Bluetooth...
Motorola handsfree kit
these kits are not very good and they are old, you are also unable to update software to work with new phones and the mic quality is poor.
go to your paired devices on your phones and change the hf850 to not connect automatically on both the phones, this may work.
If you can get a full refund and only pay the difference for a parrot it will be worth it. Also look at the THB Bury kit.
Dan
Mar 25, 2009 | Motorola Mobility Bluetooth??ยข HF850 Car...
How can i reactivate my blueant blue tooth on my motorola ic902?
Try following the below instructions, if you haven't already tried them..
First Time Pairing to your Bluetooth Mobile Phone
When you turn ON your Supertooth Light for the first time, it will automatically go into Pairing mode ready to be found by devices in Bluetooth searches. This will be the case until you have successfully paired a phone. If you have already paired a
phone, please go to the next section.
1. Power ON your Supertooth Light. The Bluetooth Indicator (3) will turn a blinking
red/blue, The kit is now in pairing mode.
2. Go to Point 3 in the next section, “Pairing to your Bluetooth Mobile phone”
Pair the SUPERTOOTH LIGHT to your Bluetooth mobile phone to create a “Pairing”
link, or audio connection between the two. This has to be only done once when first connecting each new phone.
1. From OFF, Press and Hold the Accept Button (1).
2. While holding the Accept Button (1), switch the kit on (Press-and-release the
Microphone Shaft (5)).
3. The Bluetooth Indicator (3) will turn a blinking red/blue, when you see
this, release the Accept Button (1). The kit is now in pairing mode.
4. While the kit is in pairing mode, access the Bluetooth menu of your phone. Turn on the Bluetooth function then execute a Bluetooth search, or discover. (See your phone’s manual for specific instructions.)
5. When the phone displays the list of Bluetooth devices, select ST LIGHT.
6. When the phone asks for the password, enter 0000 and press Ok.
7. Set the ST LIGHT as a trusted/authorized device, if this is option in your phone.
Important Note: The kit is now paired. Most phones automatically connect to the
kit after pairing. With some phones you need to connect manually after pairing.
Go back to Bluetooth > Paired devices > highlight ST LIGHT > press
Options > then press Connect.
When connected you may see the Bluetooth Symbol on your phone change
slightly, either inverting in color or changing to a headset or car symbol. The kit
is now ready to use.
Repeat steps 1 -7 above for each new phone you want to use with the
Supertooth Light.
This was copied from the user manual, which you may or may not have already.. Here's a link to a .pdf file of the manual which you can also save to your computer:
http://www.blueantwireless.com/downloads/supertooth_light/supertooth_light_manual.pdf
Hope this helps :)
Season's Greetings!
Chris (ziraffa)
Dec 22, 2008 | Blueant Supertooth Light Bluetooth Speaker...
Bluetooth pairing
1.Explore blue tooth devices from your motorola phone.
2.it will sure find your blue tooth headset.
3. Make sure your blue tooth headset is on
4.in pairing function select your blue tooth headset
Dec 22, 2007 | Motorola Mobility Bluetooth Hands Free...
Motorola Mobility TZ710 Bluetooth Car Kit Speaker Logo
27 people viewed this question
Top Motorola Mobility Audio Players & Recorders Experts
David Payne
David Payne
ka4iup
ka4iup
john h
Are you a Motorola Mobility Audio Player and Recorder Expert? Answer questions, earn points and help others
