Question about Amana Refrigerators
WATER LEAKS ON FLOOR EVERY MORNING
I can't find drain tube
  • dottielove46 Nov 28, 2013
    I think I solved the problem by tightening a compression fitting.
    Scholar:
    New Friend:
  • 81 Answers
It may only be when your ice maker is filling. I hope you found the problem. The fitting sounds accurate towards your problem though.
Posted on Nov 28, 2013
applianceboy
  • 77 Answers
SOURCE: FRIGIDAIRE FRS22ZRGD2
you may need to clean the drain tube again. the only other place that water may come from is the ice maker if it is over flowing. this however would be very obvious. use some thing like a length of cloths line cable to "snake" the drain after you defrost it. the fastest way to defrost it is to use hot water and a turkey baister. good luck.
Posted on Sep 26, 2007
tborn6
  • 700 Answers
SOURCE: so water leaks out onto floor-Jennair side by side
THERE IS A DRAIN LINE HEATER ON MOST UNITS now days, if yours is an older one what you need to do is make sure that it's level, and that the drain line is cleared so that the water has a place to go when it thaws during the defrost cycle.
Posted on Jan 27, 2009
MNfisherman
  • 11896 Answers
SOURCE: drain tube gets clogged
I suggest using a sink snake. After the clog is out, then use drano or equivelant.
Posted on May 22, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: Defrost Drain clogged
Take a spray bottle with VERY hot water and spray it down the drain line
Posted on Jun 02, 2009
Testimonial: "Good advice. Wife called repairman before I could apply. Repairman did same thing, but with pressureized."
  • 110 Answers
SOURCE: Clogged defrost drain tube.
It should be just below the evaporator coils. The panel covering the fan should also be the one covering the drain tube. You'll probably have to pull the shelves out to get the panel off (depending on the model, sometimes you'll have to pull the back panel off too, sometimes it's just on the top.)
Posted on Mar 30, 2010
Water leaking on floor of 2005 camry AC
Ok well had same problem. The drain hose is blocked and is backing up and coming out of top of drain plug and tube into the car so the tube hanging down in engine bay left side of motor may be blocked with mud dirt or something else so check it and with aircon on if the water is not dripping out of the drain tube then it is blocked
May 29, 2014 | 2003 Toyota Camry
Frigidaire FFHS2311LWD has water pooling up and freezing bottom drawer and lower vent. Drain tube doesn't seem to be clogged. Water leaks onto floor some days.
the drain tube is most likely clogged. if the lower vent is freezing up there is no way to confirm because it is covered with ice. the reason water leaks onto the floor is, the refrigerator goes into defrost, frost melts and runs down the ice to the door. use a hair dryer to remove all ice, then use hot water to check drain. drain tube may be up to a foot long and may have a trap. you may have to go in through the back to gain access to the drain
Oct 22, 2013 | Kenmore Freezer 20.3 cu. ft. Frost Free...
A/c leaking water passenger floor
Usually a sign of a plugged drain tube.
The HVAC box has a tube that drains the water onto the ground.
The tube should be at the bottom of the firewall near the passenger floor.
Jul 24, 2012 | 2002 Nissan Sentra
How to stop water from pass side floor
Hot or cold water? You need to determine whether it is the A/C drain or leaking heater core. we will start here with A/C. There will be a drain hose going through the firewall into the engine bay. Push a piece of wire up the drain tube then blow softly with compressed air or get fish tank tube put it in drain tube & blow. If you free blockage water will pour out of that drain tube. If the tube is blocked the water will go in the car But a leaking heater will do the same.
Jul 01, 2012 | 2001 Hyundai Elantra
JENN AIRE LEAKING WATER ON FLOOR. NOT SUPPLY LINE PROBLEM. HELP
Open freezer, remove lower crisper & look for solid ice on freezer floor & area at rear of freezer. If present, defrost drain is restricted. Depending on make & model remove ice, remove rear wall and clear defrost drain trough and drain path. Verify by removing kick panel, pour a cup of near boiling water through drain and watch as it drains into pan. Once clear, pour one ounce of bleach into drain tube. Also check as water is draining into pan that the pan is not leaking due to pan cracks. This solution is based on the fact that you are stating no hoses are bad.
Mar 27, 2012 | Freezers
I have a AMH95 gas fired furnace. there are 2 drain tubes on the back of furnance that drain water when the central air is running. One tube runs to a tube that runs to a floor drain and the other just...
Hello RR,there are 2 tubes one is the PRIMARY drain & the other is secondary drain.If the primary drain becomes CLOGED or slows down the 2nd drain leaks.Its time to clean out the primary drain tube.Find the end or disconnect it & blow/flush it out to clear it.
Aug 09, 2010 | Heating & Cooling
Water on passenger floor /water leak
So little information to work with...
You say WATER ???.... OK Then Water it is..
INFO:
Evaporator has a drain tube that carries away the excess water that forms when the ac is operative After several years it's not uncommon for this drain tube to get plugged up
RECOMENDATION:
Look under the vehicle for a drain tube, A Black Rubber tube and clean it out with Caned air Using all the proper safety equipment.
Hope this tip helps.
R/
David
Jan 31, 2010 | 1994 Pontiac Grand Am
Water leaking all over
The water leaks all over the floor instead of running into the water containner. if that is right then your condenser drain pan tubing is blocked or the pan is rusted out that cause the water leaks all over instead of running down the tubing into the water containner . You've to dismantle the panels to get into this condenser drain pan to have a good clean out . Hope this will help . God Bless.
Jul 23, 2009 | Heating & Cooling
Smeg fride freezer leaking
HI Mark,
The evaporator drain is blocked causing the defrost water to pool, freeze and then leak onto your floor.
Clear out the freezer, then use a hammer to break up the ice on the floor. Now remove the rear panel. You'll see more ice build up. Don't use the hammer on it! (Too close to the coils for comfort) Use a hair dryer to warm up/melt the ice below the coils.
You'll see the drain hole now. Clear the drain by forcing a solution of water and bleach or water and baking soda into it with a basting syringe. If the solution will not flow through, slide a length of ¼ inch flexible tubing into the drain tube to push the clog through to the drain pan. Remove the tubing after clearing the clog.
SG
Mar 27, 2009 | Smeg FA561X Side by Side Refrigerator
Water on floor in the morning front of refrigirator
HI thanks for your question. the drain tube is under the freezer. the drain hose goes to the drain tray at the back by the compressor. pull fridge from wall, remove the back panel, clean all the dust on the coils. find drain tube, by the drain tray. turn fridge off. let thaw. clean out the drain tube. if you need more assistance. please don't hesitate thanks
Oct 15, 2008 | Kenmore Refrigerators
Refrigerators Logo
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
