Question about Reliance 99-2005 Chevy Silverado Tahoe Suburban Yukon Alternator
Back door wont open - Reliance 99-2005 Chevy Silverado Tahoe Suburban Yukon Alternator
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,095 Answers
All other doors respond to the Key?
Try pushing the back door CLOSED then try again, maybe mechanism is not fully closed
Posted on Dec 15, 2013
How to open a door when the door handles wont work
Open the door from the other side.
Then... remove the inner door panel and the plastic sheeting that isolates the interior of the door from the back of the door's upholstery panel. Be careful with that plastic so you don't damage any more of it than you have to.
Find the linkage between the door handle and the strike mechanism. One piece of that linkage is probably disconnected. Reconnect it (you may need a minor clip from the auto parts place, or you may be able to fashion something from wire or a bobbypin).
Tape the plastic back on the door and reinstall the inner door panel. Test the door to be sure it opens correctly.
Jul 26, 2014 | 1997 Ford Expedition
Doors in the back wont open from the outside?and the front passenger door wont open from the inside?
It appears you have a situation with electric door locks.When the locks are open,so will the doors.I'd check fuses first,if good,then the electric door locls need repositioned or replaced.
Apr 20, 2014 | 2009 Pontiac Torrent
Rover 75,back doors wont open?
Child locks are on.
Open from inside and flick lock bars
Apr 08, 2014 | Rover 75 Cars & Trucks
Passenger sliding door and rear cargo door wont unlock but other doors will why?
window is an issue by itself.its most likely a bad window regulator or a motor or a switch.the sliding door and back door might be an issue with power door lock actuator.or broken handle
Jun 20, 2013 | 02-03 Caravan 2 Tire Pressure Sensor...
Back doors wont open
did you check the child safety switches on both doors open doors and you will see the location on the sides of the doors
Sep 06, 2012 | Ford Explorer Sport Trac Cars & Trucks
Back door wont open
door latch is jammed. the door panel will get damaged most likely during removal then latch will need to be opened some time a air chisel is needed to bust latch apart take to shop to have repaired if you dont have the tools.
Aug 19, 2012 | 1999 Audi A2
1986 nissan 300zx passenger door wont open from inside ,can from outside
Remove the inside door handle cover , Take out the piece that has yhe rods attached to it . There is 2 black plastic pieces that one opens the door and the other one locks the door. One is broken . The one that opens the door from inside, Reolace the piece and put the rods back on. put cover on . Done.
May 07, 2012 | 1986 Nissan 300ZX
My back doors wont open, the child safety locks wont unlock my back doors
Your post is somewhat confusing, BUT with child locks engaged, you can only open the door from the outside, when unlocked.
Jul 10, 2011 | 1999 Ford Explorer
97 Ford Explorer back doors won't open
A common problem with these are that the power door lock actuator freezes, and wont let the door unlock all the way,or the latch rusts up and again wont let door open, see if the lock arm is going up and down all the way, if not then try grabbing the lock with pliers and pulling up and then opening the door, or pull and push a few times then try to open the door, good luck.
Apr 08, 2010 | 1997 Ford Explorer AWD
Washing machine door wont open
well, Either clip on the door is faulty or its the door interlock in which the door locks into easily replaced by undoing the clip pullling back the door rubber and replacing ..
Jul 19, 2008 | Washing Machines
Reliance 99-2005 Chevy Silverado Tahoe Suburban Yukon Alternator Logo
Top Reliance Electrical Supplies Experts
Craig Butler
Craig Butler
GFTALON
Are you a Reliance Electrical Supply Expert? Answer questions, earn points and help others
