Question about Vehicle Parts & Accessories
791 bypass module
I have recently installed remote starter on my car but it still needs to leave the car key in the ignition to works. people who have already installed bypass 791 on their car, how should I install this item on my car. I have 2000 Infiniti G20t.
doin12volt
  • 233 Answers
SOURCE: car starter not working
look under the dash for a small silver toggle switch....this is a disable switch for the remote start portion of the system..you may have kicked it / bumped it with your foot, causing the remote start portion to be deactivated. Just flip the switch the opposite way and try again..
Also, there may have been a pin style switch installed under the hood...Check to see if it is bent or broken, if it is, simply disconnect it and insulate the wire that was going to it.
This wire is used as a safety to keep the vehicle from remote starting while the hood is up..to keep people from being injured if the remote start is activated while the engine is being worked on.
Have whatever shop installed the system replace your pinswitch if that is the problem.
Posted on Dec 19, 2008
jpk528
  • 95 Answers
SOURCE: I have a 1998 Chevy cavalier with Avital 3200
it sounds like its the bypass module. When it doesnt start the car goes into security mode and wont let it start for up to 15 minutes. I would check the bypass module to see if it still has power or has been reset, if its not something you can do, bring it to a local mobile electronics shop and they should be able to take care of it for ya.
Posted on Mar 03, 2009
  • 87 Answers
SOURCE: My audiovox dealer installed remote starter starts
It dosent sound like there is a transponder bypass installed or installed correctlt, I dont know the year make and model of car but that sounds like what it would be
Posted on Jun 04, 2009
MECP Guy
  • 344 Answers
SOURCE: I have installed a bulldog security rs82p on a
put your key in the ignition leave it in the off position, now press the remote starter, if it starts you need to adjust the key in the 791, or adjust the transponder loop around the key chamber
Posted on Jan 25, 2010
  • 20 Answers
SOURCE: Cool Start model CS34-II TX manual
the problem with this remote is that it is used for a bunch of different models you have to look under the dash and get your unit model number and then check the crime stopper manuals for that units number you do this at www.crimestopper.com under support tab click on manuals and manuals again and then choose the model number you found under your dash
Posted on Feb 09, 2010
I need a wiring or instalation diagram for 03 silverado
Download manual from the attached link: https://www.gmupfitter.com/publicat/2004_BB/2003_Beyond_LD_Electric_CK.pdf
http://alarmsellout.com/support/diagrams/vehicle/CHEVROLET%20SILVERADO%201988-2005.pdf
This may help:
http://www.automotivetroubleshootingsecrets.com/2003_Chevrolet_Silverado_1500_4.8L_No_Start_Stall.html
This may help:
2003-2006 Chevrolet Silverado Wiring Diagram:
Listed below is the vehicle specific wiring diagram for your car alarm, remote starter or keyless entry installation into your 2003-2006 Chevrolet Silverado . This information outlines the wires location, color and polarity to help you identify the proper connection spots in the vehicle. Please be sure to test all of your wires with a digital multimeter before making any connections.
PART COLOR LOCATION 12 VOLT CONSTANT RED (+) @ IGNITION SWITCH HARNESS STARTER YELLOW (+) @ IGNITION SWITCH HARNESS STARTER 2 N/A IGNITION 1 PINK (+) @ IGNITION SWITCH HARNESS IGNITION 2 WHITE (+), SEE NOTE #2 @ IGNITION SWITCH HARNESS IGNITION 3 N/A ACCESSORY/HEATER BLOWER 1 ORANGE (+) @ IGNITION SWITCH HARNESS ACCESSORY/HEATER BLOWER 2 BROWN (+) @ IGNITION SWITCH HARNESS KEYSENSE N/A PARKING LIGHTS ( - ) GRAY/BLACK (-) @ BCM, BROWN PLUG, PIN B2, SEE NOTE #3 PARKING LIGHTS ( + ) BROWN (+) IN DRIVERS KICK PANEL POWER LOCK SEE NOTE #1, (for BASE MODEL TRUCKS, SEE NOTE #4) POWER UNLOCK SEE NOTE #1, (for BASE MODEL TRUCKS SEE NOTE #4) DOOR TRIGGER GRAY/BLACK (-)(DRIVERS) and BLACK/WHITE (-)(PASSENGER), SEE NOTE #5 @ EACH DOOR MODULE, IN EACH DOOR DOMELIGHT SUPERVISION GRAY/BLACK (-) @ BCM, BLACK PLUG, PIN E, SEE NOTE #3 TRUNK RELEASE N/A SLIDING POWER DOOR N/A HORN BLACK/YELLOW to BLACK (-) @ STEERING COLUMN HARNESS TACH Any wire NOT, PINK, BLACK or BROWN (AC) @ IGNITION COILS or FUEL-INJECTORS WAIT TO START LIGHT DK. BLUE (-) @ INSTRUMENT CLUSTER, PIN A2 BRAKE WHITE (+) @ BRAKE PEDAL SWITCH FACTORY ALARM DISARM LT. GREEN (-) @ DRIVERS DOOR MODULE, IN DOOR, BLACK 26-PIN PLUG PIN 15 ANTI-THEFT GM'S PASSLOCK 2 ANTI-THEFT SYSTEM, SEE NOTE #1 @ IGNITION SWITCH EXTRA INFORMATION NOTE #1: This vehicle uses GM'S PASSLOCK 2 ANTI-THEFT SYSTEM that requires a 791 Bypass Module to Remote Start, if you are using a REMOTE STARTER ONLY, use the 791. IF you are installing a REMOTE STARTER with KEYLESS ENTRY you MUST USE the INTERFACE BYPASS MODULE, Part # DB-ALL or XK09, EITHER Bypass will do the Anti-theft and Keyless entry. If connecting a keyless entry only you can use the GMDL-BP. NOTE #2: The IGNITION #2 wire WHITE must be connected to prevent a CHECK ENGINE LIGHT from turning on and to prevent DAMAGE to the TRANSMISSION on this Vehicle. NOTE #3; The BCM is located under the Drivers Side of the dash, the BCM has 6 plugs on it, with the PURPLE plug on the back. NOTE #4: On BASE model truck the DOOR LOCK INTERFACE MODULE is not necessary, the LOCK wire is a LT BLUE (TYPE B) @ the BCM, LT BLUE PLUG, PIN B5, and the UNLOCK wire is a WHITE (TYPE B) @ the BCM, LT BLUE PLUG, PIN B10. NOTE #5: On BASE Model trucks, the Door Trigger wires are @ the BCM, LT BLUE PLUG, PINS B4 and A5. On 4-Door Trucks the LEFT REAR Door is a LT BLUE/BLACK (-) PIN A3 and the RIGHT REAR Door is a LT GREEN/BLACK (-) PIN A2, located in a PURPLE PLUG at the BCM, use all 4 wires and diode isolate when installing an alarm system.
2011-03-28_044351_brakes_lamps_circuit_2003_2500_siverado-dfydxumns33ohqc3bsmt22yf-2-8.gif
collection-fuel-2003-chevy-silverado-wiring-diagram-estimation-information-standard-work-therefore-straight-swapped-dfydxumns33ohqc3bsmt22yf-2-34.jpg
igniton-black-2003-chevy-silverado-wiring-diagram-neutral-before-position-begin-switch-know-scheme-unsure-pairs-dfydxumns33ohqc3bsmt22yf-2-53.png
sensor-primary-2003-chevy-silverado-wiring-diagram-fuel-pump-plugs-solid-conductors-important-looking-more-channels-dfydxumns33ohqc3bsmt22yf-2-76.png
igniton-black-2003-chevy-silverado-wiring-diagram-neutral-before-position-begin-switch-know-scheme-unsure-pairs-dfydxumns33ohqc3bsmt22yf-2-151.png
Apr 16, 2017 | Cars & Trucks
Where in halifax nova scotia can i find someone to check my cool start remote
You did not mention the details of your vehicle but the most likely cause is not having a bypass module installed with the remote starter. The reason you may need a bypass module is to replicate the function of the chip that is imbedded in your key.
Jan 14, 2013 | 2-Way Remote Starter
I just installed a remote starter on a 1997 chevy malibu along with express kit xko6 down loaded with version (FIMWARE) 3.0 it seems it is programed but my vehicle will not start if i turn the key to acc...
You installed this unit yourself, correct? You mentioned the bypass unit but not the remote starter unit. First, are all of the car's power wires connected...ignition(pink), 2nd ignition(green or white), accessory(orange)? There is a brown but it is radio accessory and not necessary for remote starter installation. Second, make sure that the ground for the XK06 is connected to the pass lock ground wire(black or orange with black) and not chassis ground. Next, check the ground when running(GWR, brown) from the XK06...make sure that it is connected to the remote starters ground when running. Now, it CANNOT be connected during programming, so make sure that you connected it AFTER you programmed the module. You didn't mention the remote starter unit but this wire is blue/white for Directed, light blue for Prestige and blue with black for some Code. Next, make sure that the ignition and starter wires of the XK06 are properly connected to the vehicle or remote starter's ignition and starter wires. You stated that the remote starter starts when you turn the key to accessory on...what about with just putting the key in the ignition(withoput turning the key)?
Jan 09, 2011 | XKEYUB XpressKit XpressKey Series...
I recently replaced my ignition in my Grand Am. Now my DEI Valet remote starter does not work. How do I reset it or get it to read my remote. I have the kind where you have to press both buttons at the...
Your bypass module has to be reprogrammed if, you have the type that is programmable. If you have relays with inline resistors then they have to be replaced with new resistors. If the ignition switch was swapped out for a new switch, with a new key, the resistance is no longer the same. If the entire ignition harness was changed then the remote starter has to be re-installed at the switch(behind the radio).
Nov 22, 2010 | Directed Dei Valet 561r Remote...
It starts and runs, than shuts off 3 seconds later? i havent tried anything yet, and it was installed in 2002. jeep grand cherokee.
Do you have anti-theft system bypass module installed? Transponder key bypass? Try unlocking the doors with your factory Jeep remote (turns off alarm) and leaving the gray transponder key in the ignition cylinder. Then try activating your remote start. Sounds like one of the factory anti-theft systems is still active. Basically if the car's computer doesn't want it to run, the car won't run. You have to fool the car into thinking it is OK to start and stay running without the key and anti-theft device deactivated. You need to leave a transponder key in the vehicle under the dash to bypass that system. You can get a generic one for about $20. You MUST have 2 original gray transponder keys in order to program a third. There is a sequence of putting one key in the ignition, then the second, then the new blank key so the cars computer knows to allow that key also. If you do not have 2 original keys, then you need to go to someone that can program properly like dealership or some locksmiths or alarm shops. Then they usually charge about $100 for a second key. You don't have to have the key cut. That way if someone finds the spare transponder key in the vehicle, it wont turn the ignition cylinder. The anti-theft bypass module (factory alarm bypass) runs about $25. Bulldog Security or JBS model 791 should work for your vehicle. If you live in an area where car thefts are common, you may not want to bypass these factory security measures.
Hope this information helps.
Nov 02, 2010 | Prestige Remote Start
I need to be walked through installing a Bulldog self learning anti theft bypass module 791 on 2007 GMC Sierra 2500 HD SLE. Thanks!
Here have information about #791 bypass module: Bulldogsecurity Model791
IF YOUR REMOTE STARTER IS CLICKING AND/OR FLASHING THE PARKING LIGHTS AND IS NOT RESPONDING TO THE REMOTE, IT IS IN SAFE MODE AND NEEDS TO BE INITIALIZED BY DOING THE FOLLOWING:
If you have a 4 button remote, you must ground the black/blue hood pin wire (raise hood if hood switch is installed). Apply 12volts to blue/black brake wire (press and hold brake pedal if wire is installed). Press and hold any button on your remote until clicking and flashing stops. Unit will now respond to the remote. Remove ground from hood pin wire and voltage from brake wire. If you have a 2 button remote, hold brake and press any button on the remote until clicking and flashing stops.
ADDENDUM
If you have an RS1100 or RS1200 and your vehicle runs for several seconds, shuts off, restarts, runs, and shuts off again, perform the following step: Connect the Black/White tach wire (from the 16 pin plug) to the heavy gauge White Ignition 1 wire and program the unit for Tach Mode (bottom of page 19).
Witch model alarm have your vehicle?
Good luck.
Mar 10, 2010 | GMC Sierra 2500HD Cars & Trucks
Bulldog Remote Start Problem
if thats a key resisor bypass i never heard of that, i would check with with bulldog to see if may be a set upproblem
Jan 24, 2010 | 2000 Chevrolet Impala
I have an o3 ford escape with an aftermarket autopage remote start system.when i try to use the remote start it flashes the parking lights and all the accesories fire up but will not ingauge the starter....
the issue is the securilock system I installed one in my 03. You need a spare coded key (one that starts the vehicle) and a Bulldog 791 kit. ths will store the spare key and tell the vehicle it is not being stolen. Its the only way unless you want to leave your key in the ignition. BTW, the Theft light is on when you engage the remote started w/o the key in the ignition, Been there.
Dec 27, 2009 | 2003 Ford Escape
I installed a remote car starter. I was wondering
use the 791 and wire it up for VATS, you will not use the loop at all
Dec 16, 2009 | 1997 Chevrolet Lumina
I have installed a bulldog security rs82p on a 2004 merc sable. The bypass module used was originally labeled as a model 20402,23402,27402,&29402. This is now the 791 the unit turns on but does NOT...
Oct 25, 2009 | Bulldog& Remote Alarm System With 1-wire...
Vehicle Parts & Accessories Logo
29 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
