Question about Slumberjack Big Steel Chair Khaki - 56744212
Where can I buy replacement seat, back and arm rests?
I need to replace the seat on a Slumberjack big steel chair so will replace back and armrests also. Where can I buy the replacements?
Remove center armrest hhr
Hi Konakalela, I'm Al the owner of Big As Auto Repair
Most arm rest have a round trim cover on the side of the seat that's removable. Simple remove that cover and there is a bolt behind it that holds the arm rest remove it counter-clock-wise and pull the arm rest straight outward. For further assistance go to my website. Have an awesome day Konakalela.
Auto Repair
Dec 21, 2014 | Seat Cars & Trucks
Trying to find the right handed arm rest for Ever med wheelchair, model CBS 89, Serial number: 20013940. Where can I get this part?
depending on the type of arm rest you might have a look on eBay for " wheelchair arm rest" there are several universal types, they are often far cheaper to buy a new pair that to just replace one with original genuine parts.
Dec 16, 2014 | Health & Beauty
How do I remove middle armrest on 2008 Honda accord sedan
Most likely 3 screws hold the armrest lid on.Towards the back.
Nov 12, 2014 | Cars & Trucks
"serta executive chair # 21779363 replacement arm
Have a Serta Office Chair Big and tall ex chair, one of the arms broke where can I get a replacement
Sep 11, 2013 | Serta Executive High-Back Chair
How do i take off the armrests from the bucket seats
  • On most vehicles the arm rest are attached the same way, here is something you can try...Put the armrest in the upright position. Look along the bottom and sides of the armrest where it connects to the body of the seat. There should be small circles like tabs if the armrest is made of plastic, and there should be a seam that you can look through if the arms are made of cloth.
  • Pop out the tab or peel back the fabric to reveal the holding mechanism. If the chair is screwed in then you'll need a screwdriver, and if there's a nut or a bolt then you're going to need a socket wrench.
  • Hold the armrest up and make sure it doesn't move. Unscrew or unbolt the arm from the bucket seat. Pull the arm outwards once the hardware is removed.
  • Nov 13, 2012 | 2007 Dodge Grand Caravan SXT Minivan
    Removing arm rest on driver seat
    using a flat blade tool like a small flat blade screwdriver, release retaining clip on arm rest and pull armrest from seat. slip the screwdriver between seat back and armrest and pry up on the retaining clip.
    Dec 31, 2010 | 2001 GMC Yukon XL
    I've got a Drive TR17 wheelchair. The handle has broken. The steel has snapped right through at the bottom of the handle where the handle attaches to the arm rest. (Below the folding part) Is it...
    This wheelchair has a limited lifetime warranty. The steel frame was defective and should not have broken under normal use. You should contact the dealer from whom you purchased the chair and have them replace the frame and/or wheelchair free of charge. You can also contact Drive Medical with the model and serial number of the chair for help in resolving your problem. The phone number for Drive Medical is 877-224-0946. Hope this helps.
    Dec 27, 2010 | Drive Medical TR17SV DDA Steel Transport...
    The right arm rest on my clients chair goes up and down but it goes the whole way down n lays on the side of the seat. I tried to tighten the bolts n that did not fix the prob. is there something else I...
    If you tightened the Arm Angle Adjustment bolt as shown on page 28 of your Owner's Manual (under the arm rest near the pivot point) by using your supplied 1/4" hex wrench, but it does not want to stay in place, the threads on the bolt may have become stripped with age and wear and needs to be replaced. You can also try applying a substance like Lock-Tite to the threads to see if that will keep them in place. If not, the armrest may need to be replaced, approx $118 plus labor to install.
    Dec 10, 2010 | NRS Hoveround MPV 5 - Used Power...
    How do you remove the armrest on the front seats?
    The armrests have covers that can be removed. Locate the zipper on the arm rest. Once you unzip it pull it toward the back of the arm rest and this will expose the one bolt that hold the armrest on. You will need a large torx and rachet to get it off. Once you take out that bolt the armrest will come right off.
    Feb 02, 2010 | 1995 Ford Bronco
    How do i remove the armrest on my winstar
    The real real answer. If the threaded stud is in the armrest there is a clip at the bottom of it you have to push it up and pull the stud out with vice grips twisting as you pull out. If both the studs are in the chair you have to make sure the clip is pushed up & out of the way then simply line up the arm rest and push it on. It should clip into place. Hope that is clear enough. Also I would put some Lock Tight on the threads. (Blue)
    Apr 30, 2009 | Ford Windstar Cars & Trucks
    Slumberjack Big Steel Chair Khaki - 56744212 Logo
    48 people viewed this question
    Top Slumberjack Furniture Experts
    John Tripp
    John Tripp
    Charles T Nevin
    Charles T Nevin
    Are you a Slumberjack Furniture Expert? Answer questions, earn points and help others
