Question about Maytag Bravos Series MVWB850YW 28" Top-Load Washer with 4.6 cu. ft. Capacity, 13 Wash Cycles,
Maytag Top Load Washer MVWB850YW making loud noise in spin cycle.
Washer was making a loud "airplane" sound during spin cycle. Started about 2 weeks ago, house continued use. Now halfway through spin cycle unit displays 'uL' code even with an empty basket. I removed agitator and inner basket to see if something was stuck between. I leveled the unit but still same problem. I ca't tell if these are two seperate issues or caused by the same thing.
    Genius:
  • 1,198 Answers
If it's a roaring noise, the tub bearing is probably wearing out. Spin the tub a little with your hand, if you hear a little of the roar, that's it.
Posted on Nov 26, 2013
    New Friend:
    Problem Solver:
  • 11 Answers
Need new shaft bearing. Seals kit .
I've repaired lots of these. Bearing tool is required. Part W10435302
tool W10447783
Posted on Dec 07, 2014
  • 17 Answers
SOURCE: make loud noise during spin cycle
Washer may be out of balance, Move closes around in washer and restart
Posted on Oct 24, 2009
  • 84 Answers
SOURCE: Grinding sound during agitation cycle on my Maytag Performa
Its probably you stator plate and rotor. But you need special tools for this repair. There a spring that is under 200 pounds of pressure and if you take the screws off that hold the plate its going to fly into you face if your dont use the special tools to depress the spring. Is it more of a clanking kinda of noise? DOes it olnly happen with heavy loads? Try this out. Fill the washer with water only. and get it into a wash cycle with water only. If there is no noise then put in like a load of towels. A heavy load. Now if you hear the noise now then its for sure you stator plate and rotor..hope this helps, but like i said you need those special tools to do this repair or injury can result from the spring part.
Posted on Jul 27, 2009
duby1990
  • 370 Answers
SOURCE: Maytag Washer HAV2558AWW loud noise during spin cycle
Your maytag is really an amana and the bearings are bad. Yes it does cost a lot. If i were you i would buy another washer. Get a whirlpool. (whirlpool now owns maytag)
Posted on Nov 18, 2008
sdmc73
  • 121 Answers
SOURCE: Loud noise(not jet whirring sound) during rinse & spin cycles.
the rear bearing is bad the bearing is press in to the outer tub the outer tube is like a **** shell you need the rear half and new seals it is a big job if you are going to do it you will need a manul
Posted on Dec 02, 2008
  • 219 Answers
SOURCE: Grinding noise during agitation on washing machine
check water pump
Posted on Apr 17, 2009
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Have a unit that started making noise comparing to a loose coin in the tub during the spin cycle and has now turned into a loud binding type noise, doesn't seem to spin as fast either. Any idea what...
The main center bearing is going bad that's why it is not wanting to spin as fast and is also making the loud noise when its spinning i.e. sounding like a jet engine firing up or metal grinding noise. I would not repair this very expensive cost around $300 to $600 to fix I would go buy a good quality used one or a new one sorry for the bad news but that's what it is I see 2 of these a week in my shop same problem but hope this helps.
Jan 07, 2011 | Maytag PAV2300 Top Load Washer
Make loud noise during spin cycle
Oct 24, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Washer makes loud, thumping noises during spin cycle.
support bracket that supports the tub is breaking. stick your hand inside and push up and down and see if its coming apart. if u look at it when it runs does it wobble?(the tub) if not take a look at the pulley on the back and see if its wobbly.
Jun 22, 2009 | Washing Machines
Loud screeching noise on spin cycle
I have the same problem...during SPIN it make a LOUD SCREECHING sound.
Apr 20, 2009 | Maytag PAV2300 Top Load Washer
Loud sounds coming from the washer on spin cycle
That is a characteristic of bearings gone bad. You should look into replacing the bearings.
Mar 01, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Loud noise
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary
Hope it may help you;
Regards;
VOTIT
Jan 29, 2009 | Maytag Neptune MAH5500B Front Load Washer
Nov 16, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Loud noise on spin cycle
How did that answer get an 83% rating? It is absolutely useless. My washer has the exact same problem as described above.During the spin cycle it sounds like a jet engine. It kinda sounds like the belt hitting the drive wheel but may be bearings in the motor.
May 03, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Bravos Series MVWB850YW 28" Top-Load Washer with 4.6 cu. ft. Capacity, 13 Wash Cycles, Logo
1,121 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
