Question about RCA HD61W66 61" Projection HDTV
I need to change from gray scale to color - RCA HD61W66 61" Projection HDTV
  • Lori K
    Lori K Nov 26, 2013
    yes the tv picture is black and white but if i use net flix or play a dvd its in color? kids must have pushed something on remote but i do not know what and everything i tried did not work..
  • Lori K
    Lori K Nov 26, 2013
    i think i fixed it by doing auto format on the settings .. i hope that it is fixed
Changing printer mode from color to black
Dear You can print only gray scale. Go to printer and fax setting-right click on printer icon-go to-printing preference-click on graphic- in color mode choose gray scale- then click on apply.
Thanks.
Oct 29, 2014 | Samsung CLP 315 Laser Printer
Konica Minolta Bizhub C552 is counting Grayscale pages as color.
I changed my image/graphic into a bw bitmap image. It worked for me. I get charged one side color and the other side bw.
Aug 21, 2012 | Konica Minolta Bizhub C552 Color Printer /...
Hi there, I have a canon printer: PIXMA MG5250. I do a lot of office printing. Can you tell me how to change the setting to only print in gray scale? I like to safe ink usage as much as...
go to the Printing preference, then there's a a settings of Color that change into grey scale.
or if you have a drive /software of your canon PIXMA, theres a printer preference and a settings to grey scale.
Mar 21, 2011 | Canon Office Equipment & Supplies
Can you make the brother mfc-490cw print in black only? I bought a new black and it wont print because it says that the other colors are too low is there any way to bypass this?
Yes, go to properties for the printer, probably right click on the printer under printers, click on "printer preferences", and then click on "color", and change it to print in "gray scale". This will be black only. This may not be the exact way to do it on your system but look for the color setting under the printer and change to gray scale.
May 17, 2010 | Brother MFC 490cw Color Inkjet...
I just bought a new printer today its a lenmark Z2300m Color Printer i only have color ink for it do i need black ink for it because everytime i try to print it comes out greenish
Under your printer preferences there is a way to print gray scale. SO even if your image is in color, it will print black and white. Every printer interface is different, but when you go to print, there's usually a properties or setting button that will bring you to another page from the initial print menu. here is where you would choose gray scale.
If you try for black with only a color cartridge, it'll come out a dark green or blue color. Or on some cases, it will tell you it's out of black and you can't print.
Sep 30, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Why Does My Color Ink Run Out So Fast When I Am Printing In Gray Scale
When sending your print job to the printer, you need to be sure to select "black and white", otherwise your computer will use your color ink cartridges to produce your gray scale image/document.
Aug 12, 2009 | Canon PIXMA MP470 All-in-One Printer
PRINTER
go to file print, then properties and select color settings or look for a gray check box that is checked for gray scale
Dec 03, 2007 | Computers & Internet
Colors in QL-711V shifted to green
Hi, I had the same problem and I wrote an email to Nu. They wrote me back that I should use the Factory reset feature which you have to go through the Factory Menu to get to. Instructions to do this are as follows. I got to the menu my first try but it has been a pain to get back to it. I hope it will be easier to access for yours.
Hope this helps
-Nate
Page 1
You will need to display a gray scale picture which varys from black to white
You will need to display a gray scale picture which varys from black to white. Displaymate 16 grays pattern is good or something like the picture to the right. 1 Press and hold SEL/AUTO and press the power button. Then release the SEL/AUTO button. 2 Press the MENU key to display the factory menu. Sencore 11 gray Pattern 3 Press the and select FACTORY2 menu. Factory2 is at the bottom. Press SEL/AUTO to select the FACTORY2 menu. 4 Press the to select AUTO COLOR. 5 Press the to run AUTO COLOR. Wait until finished. You will see the colors changing and then become stable when finished. About 10 seconds. 6 Press the and select COLOR UPDATE. 7 Press the to run COLOR UPDATE. It will finish quickly. < 1second. 8 Press MENU to exit the menu. Power off/on.
Nov 05, 2007 | NuTech QL-711V 17" Flat Panel LCD Monitor
RCA HD61W66 61" Projection HDTV Logo
16 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
