Question about Samsung HC-P4363W 43 in. TV/DVD Combo
Dvd not working properly
The dvd works sometimes in long while,then it stops reading the dvds.It says no disc.Disc is clean and it doesn't have any scratches.Is dvd player shot.
When you have the dvd track open to where you can insert the dvd, try blowing in there, my boyfriend did that for me when I was having problems with it and it worked just fine afterwards. Hopefully this helps, sorry if it don't!
Posted on Jun 07, 2009
Hardly used it & now it doesnt recognize any dvd any clue what could be wrong
Laser eye reading buble,might be dirty,reqiure cleaning or having problems with those DVDs disc's itself like dirts,grimes or cracks and big scratches on those DVDs disc's laser shinning surfacing data's reading side?Check all ur DVDs disc's again u are using,might just require a good cleaning on DVD's discs on the reading data's shinning surface sides,with some dish washing soap?If the DVDs disc's are not the problems.Tries websites like Ebay.com,Amazon.com to buy a DVD disc cleaning kit.By using the DVD cleaning disc,might work,might not.But than u don't have to be littery taking the portable DVD player aparts and used some Q tips,dipping in with some rubbing alchahol to clean the Laser eye reading buble itself.
Dec 01, 2010 | TruTech PVS12701 Portable DVD Player
The dvds are not detected - No Disc or Disc Error
Hi. These steps should help.
  1. Check the disc you're using for scratches and dirt. If the disc is damaged it won’t play properly, regardless of the DVD player’s ability to function. You can use a DVD repair device like the "Disc Doctor" to repair the DVD or purchase a new DVD.
  2. Make sure the discs you're using fit the correct format specified by your DVD player. For example, if your DVD player doesn’t support home-burned DVD-R's, then you can’t use a DVD that you made at home. You may need to upgrade to a newer model, most of which accept the latest DVD formats.
  3. Clean the laser lens with a DVD laser lens cleaning disc. DVD laser lens cleaning discs can be purchased at most electronics retailers or online. Insert the laser lens cleaning disc and follow the instructions.
  4. Insert a correctly-formatted, undamaged disc into your player. Listen to see if it begins to read the disc. If it continues to make no sound and gives you the same message, then the problem is probably that your disc is not spinning in the device.
  5. Turn the device off and unplug it. Take off the outer casing by removing the three or four screws and lifting the top piece off. This will allow you to see if anything is simply stuck or jammed. If this is the case, a simple nudge back to the correct position will fix the problem.
  6. Clean the lens while the DVD player is open. A dirty lens is most likely the cause of your no-disc error. The lens should be cleaned with isopropyl alcohol and a cotton swab.
  7. Take your DVD player to have it professionally fixed only when none of these other solutions solves the problem. A professional repair technician will be able to tell you if fixing your DVD player is worth the money.
Nov 22, 2009 | Aiwa HT-DV90 System
Playstation 2 won't play DVDs
if it's a fat PS2 and
model SCPH 30001, SCPH 35001
(not including the models with an 'R' after the model #.
these models need the following to play DVDs:
- PS2 DVD remote with IR unit
- PS2 DVD disc player (sold with DVD remote w/ IR unit)
- PS2 memory card
you copied the DVD disc to the memory card. you used the memory card to play DVDs.
later models didn't need the memory card to play DVDs.
hope this helps :D
Jul 16, 2009 | Sony PlayStation 2 (PS2) Console
My panasonic DMR-ES 15 cannot read anymore!
There maybe a problem with the optic lens (dirt) try to clean it very gently with cotton, also the motor plate that holds the cd/dvd is not holding it very well so it not rotates at proper speed try to clean the both sides where the hole of the cd/dvd is when it´s inserted, if you think that you migth not have skills for that don´t do it.
Hope it help
Jun 25, 2009 | Panasonic DMRES15 DVD Recorder
Sony vaio VGN-CR320E dvd drive issue
i'm sure some problems with your dvd lens, first clean your lens with dvd lens cleaner and play after finish tracking.
May 06, 2009 | Sony VGN-CR320E/P Notebook
Invalid disc reading
reset to factory mode, should be in the instuction manual ,how to do it.
Mar 28, 2008 | Lite On LVC-9016G DVD Recorder/VCR
DVD stopped playing all DVDs
Reset you player by doing the following:
With the player on, hooked properly to your television, and on the correct station:
Open the tray
Close the tray (with no DVD inserted)
Hold the stop button down for a full 5 seconds
The CyberHome screen should appear. You should be able to play your dvd's now.
Feb 20, 2008 | Cyberhome CH-DVD 300 DVD Player
Not reading pre-recorded dvd's and ocassionally not re-wrtten dvds
Over recent months my recorder has stopped reading pre-recorded disc's and more requently re-writer disc's. I had thought that the region had some how been altered, but not too sure now. Is there a way of checking? Or is there a problem with the laser block. I have stripped the machine down and thoroughly cleaned (but no dust found) and no loose parts. I have reset to manufacture default but this hasn't helped.
postsolution.gif Post Solution addwq.gif Work Queue -->sameproblem.gif Have the same problem? --> Have the same problem? Click Here
X This Problem has been added to the Share Your Expertise Page under "My Work Queue". OK 1 Other User Has The Same Problem Comment by Guest, posted on Dec 19, 2007 DVDR70-051 recorder functions generally becoming more and more erratic. DVD-RW discs I have recorded sometimes say 'disc error' sometimes 'no disc' sometimes start ok but cycles round and round for 5 - 10 mins before stopping, sometimes goes straight into play at last position, won't stop back in menu just goes straight to stndby. Factory reset dosn't help. Wont play pre-recorded discs without going into menu and messing around. It seems to damage or not record RW discs properly a lot of the time. Not even sure if it's resetting to factory settings properly.
Oct 28, 2007 | Philips DVDR70 DVD Recorder
DVD cannot read DVD's anymore
Have you tried cleaning lense with soft cloth and alcohol? Sometimes cd or dvd cleaners do not work well for some systems.
Aug 30, 2007 | Durabrand DUR-1700 Portable DVD Player
Samsung HC-P4363W 43 in. TV/DVD Combo Logo
78 people viewed this question
Jerry Greenberg
Jerry Greenberg
