Question about Peavey Xr 8600 8 Channel Powered Mixer
My Peavey amp has powered on but no sound coming out of channels at all? I have replaced both fuses but still no sound! please help!
My Peavey amp has powered on but no sound is coming out of any channels at all? I have replaced both fuses but still no sound! please help! It was working fine the last time it was turned on? I have also checked all cables to speakers and output channels ! Help it's so annoying.
    Genius:
  • 1,198 Answers
Look for a 'monitor' switch, change it's position.
Posted on Nov 26, 2013
4 Suggested Answers
  • 5603 Answers
SOURCE: How to remove amp from cabinet? reverb doesn't work.
SOMETIMES the handle screws must be removed as well.
I have taken a lot of these out and the key is to figure out which direction it comes out... MOST are out the back and sometimes a board across the back has to be taken off with four screws to clear a transformer.
FIGHTING getting the thing out when it catches on the Tolex covering is the USUAL problem. Takes patience and sometimes a blade to hold the Tolex back.
USUALLY the speaker baffle stays in place.
Posted on Nov 12, 2009
KeithOB
  • 59 Answers
SOURCE: Peavey Pr-15 fuse blown, speaker
Actually its pretty funny thing with those speakers is the "fuse" is Actually called a Lamp in this case. These are what they call a " Red Dot Fuse ". in all the years i've been doing this i've never thought to look up the value haha. Just have to know there are Red Dot lamps and Blue dots and No Dot. If you examine the LAMP you should see somewhere close to the ends ON THE GLASS a color dot of some kind. almost like someone painted it on there. Red Dot Lamp. any parts distributer for people like Harbinger, Peavey, and B52 will KNOW what your talking about
Posted on Sep 06, 2011
SOURCE: my peavey vypyr 75w won't turn on
my vypyr 75 JUST did what you were talking about. From what I'm researching this has happened before and it's the fuze which is soldered to the circuit board. I'm taking it to the store I bought it from so they can fix it. I see you posted your problem a long time ago but I hope this helps someone new that it happens to.
Posted on Jan 15, 2012
Peavey amp
Most likely a power supply problem. Take it to the repair shop.
Apr 06, 2014 | Peavey Xr 8600 8 Channel Powered Mixer
I have a Peavey amp but no sound is coming out?
Bad output transistors or bad Soldier joint in output section
Nov 26, 2013 | Peavey Xr 8600 8 Channel Powered Mixer
How can you tell if a fuse is blown on a XR 8600 power amp by peavey?
The fuse is probably placed near the power cable entrance in the power amp.
Pick it up from it's placing dock and look for the wire inside. If the wire is whole, the fuze is fine, however, if the wire inside the fuze is missing or burned, the fuze needs to be replaced.
Jan 27, 2013 | Peavey Xr 8600 8 Channel Powered Mixer
Why does the 1.6amp fuse blow when the amplifier is switched on?
The owners manual shows a AC fuse for the 8300 as 8amp / 250 volts but doesn't show an external fuse holder for the 8600d. It's unlikely that the 8300 would use a 8amp and your 8600 a 1.6 amp. Double check your original fuse values.
http://www.peavey.com/products/index.cfm/item/701/117405/XR%26nbsp%3B8600D
Oct 25, 2012 | Peavey Xr 8600 8 Channel Powered Mixer
I use my Peavey XR 8600 with an acoustic duo that I'm in. At my last show, an audience member grabbed and dropped a vocal microphone that sent a sharp sound through the Peavey and shut it down. When I...
Chances are one of the power amps has shorted. Replacing the fuse probably fried additional components. Unless you are electronically adept this is NOT a DIY repair.
Expect that this is going to be an expensive repair as often quite a few transistors and other components fry when one goes in these power amps.
Mar 09, 2011 | Peavey Xr 8600 8 Channel Powered Mixer
Peavey XR800F 8 channel - I can't get but very little sound to my big speakers. Help
Troubleshooting is always a "process of elimination." Have you tried hooking up your Peavey powered mixer to another set of speakers? How about connecting the speakers to another audio system? Your term "very little sound" could mean audio input problems, mixer/amp settings or failure and possibly speaker damage (internal passive crossovers). Please be more specific.
Jun 12, 2010 | Peavey Pv 2600 Power Amplifier
Peavey sound board 2 channels not working
check for cold solder joints from the input jacks and the fader. If any look suspicious (dull or grainy) re-solder.
Apr 29, 2009 | Peavey Pv 2600 Power Amplifier
PV6 clip lights stay on
You've lost one of the power supply rails. It needs to be repaired or replaced.
Jan 15, 2009 | Peavey 32fx USB 32 Channel Mixer
Peavey Xr 8600 8 Channel Powered Mixer Logo
218 people viewed this question
Top Peavey Music Experts
Michial Gueffroy
Ben Armstrong
Vito Vacirca Jr.
Are you a Peavey Music Expert? Answer questions, earn points and help others
