How to repair protect on my Sony str av1020 - Audio Players & Recorders
  • 3 Answers
SOURCE: code for sony receiver model str d565 protect mode
If you need support you can log into:
http://esupport.sony.com/US/perl/support-contacts.pl?mdl=STRDG510
for free tech support on sony chat line
Posted on Jun 02, 2008
  • 336 Answers
SOURCE: sony str de415 ( protect
You can try tighting the ground screws that hold the circuit boards and heat sink to the chassis, But more times than not it will need a pair of output transistors replaced (and a few resistors). This is a job for a pro. A rough estimate is $100-$130.
Sorry for the bad news.
Posted on Mar 08, 2009
SOURCE: Sony STR DE-725 going into ''protection'' mode
Audio Amplifier IC damaged
Posted on Aug 23, 2009
  • 336 Answers
SOURCE: Sony Receiver STR-DE310 flashing "PROTECT'
Replacing ouput transistors and probably a couple of resistors is best left up to a repair shop. The entire main board needs to be removed to access the solder side of the board, many screws and several connectors.
Posted on Jan 21, 2010
smarthome2
  • 1114 Answers
SOURCE: Sony STR-D665 receiver display flashes "PROTECT"
The most common problem found on FixYa for Audio Video Receiver's is:
My receiver say's "Protect" or turns on then off. What's wrong? Seven times out of ten it is a shorted speaker or speaker wire. To determine your exact problem, the first step is to disconnect all speaker wires "at your receiver" Next: Turn the receiver back on. If your receiver still says "protect" or turns off, it needs to be serviced. If your receiver stays on; reconnect your speakers one at a time and power back up after each speaker. You may find that after reconnecting all speaker wires it works! Most commonly the small braids of wire from the + to the - have touched and have caused the problem. In some instances, you noticed the problem only when turning the volume up. either way, make sure the exposed wires to your receiver are no longer than 1/2" long and are completely under the screw down terminal or slide in. When you've found the wire or speaker with the problem, your receiver will go back into "protect" At this point, disconnect the wire from the speaker at the speaker that may be causing the problem then test again.* Note* Make sure speaker wires do Not touch each other as this Will cause a short! If you turn the receiver back on and it stays on, you now know the problem is in your speaker itself. To test your speaker, you will need a multimeter. Set it to ohms resistance and touch the speaker terminals, if there is a short internally the meter will read "1......" If it's an analog meter, it will peg to the right. There's your problem. Now, within any speaker there are quite a few possibilities as to what could be causing the problem. Most common is a blown coil and the speaker needs to be replaced. Some speakers have internal crossovers (usually floor standing speakers) and may have a shorted or burnt board (usually very visible brown burn marks on the board) and can possibly be repaired if your handy with a soldering iron. Now, if you disconnect the speaker wire at the speaker and it still says "protect" Check your wire for the obvious cut or nail thru the wire if possible. If your system has wiring that runs behind walls, you may need to use your meter again. Disconnect the wire at both ends, keep the ends separated, put your meter on ohms resistance and touch probes to the + and - wires at one side. If the meter pegs to the right or reads "1...." the wire is shorted and needs to be replaced or repaired at the short. Hope this helps.
Posted on Jun 07, 2010
Sony str-av1020 reciver Power supply transformer burned!
http://www.sony.owner-manuals.com/STRAV1020-service-manual-SONY.html
Aug 19, 2016 | Sony Audio Players & Recorders
My Sony str de335 is in protection mode speakers are unhooked how do I get it out of protection mode?
if you disconnected everything and it still goes into protect, the most likely there is a damaged amp channel that will need to be repaired.
Feb 23, 2015 | Sony STR-DE335 Receiver
Hi. my sony STR-DE 597 go in protect mode. how can I fix/repair this? Give me a tips.
protect mode means there is a shorted components inside your reciever it's probably the out put transistors take out the transistors and test it with a multimeter.
Jul 11, 2011 | Sony STR-DE597 Receiver
Sony str-de335 flashing protect when powered on and no sound comes out
Please see the link below for an explanation of protect mode. After that, please post here any additional questions that you have. Specific to your model, you can expect a parts cost in the $40-$60 range for the repair.
Dan
Link: http://www.fixya.com/support/r5390728-protector_means
May 20, 2011 | Sony STR-DE335 Receiver
Hello my sony audio/video control center #STR DE335 is in PROTECT MODE.. and i cant listen to it..can u please tell me whats wrong?
PROTECT display indicates that receiver got serious problem in output amplifier section and protection mode is activated to avoid further damage.
Output amplifier section should be tested by qualified technician to find out and replace defective part(s) to solve this issue. Local repair shop will do this job as it is not user level repair.
Thanks.
Apr 29, 2011 | Sony STR-DE335 Receiver
I have a STR AV1020 receiver. If I leave the power cable plugged in, even if the system is off, there is an issue. When I power on the receiver, all lights come on and stay on. Sometimes playing with the...
Hello i have a Sony str-av 1020 reciver. But reciver is burned power supply transformer. At the transformer walks around 125 v, but i don't know how much Current transformer on the other side is, and i don't know what transformer i have to buy? Please help. I would be very grateful!
Mar 08, 2010 | Sony Audio Players & Recorders
My sony STR-DE695 flashes protect with nothing hooked up except the power supply. Is it a grounding problem, or something else?
if it is in protection mode with no speakers connected, then youve got an internal problem which will need repaired
Feb 23, 2010 | Sony STR-DE695 Receiver
Jan 21, 2010 | Sony STR-DE310
I HAVE A SONY RECIEVER SRT-DE597 6.1 CHANNEL AND I ITS ON PROTECTED MODE CAN YOU HELP ME UN PROTECTED
Amp output is damaged and needs repaired. Protect mode cannot be deactivated. When amp is repaired and operating normally protect mode will not be displayed.
Aug 29, 2009 | Sony STR-DE597 Receiver
Sony STR-DE698 7.1
in Sony receivers Protect display shows problem / fault in Amplifier output area. Qualified technician can repair the damage.
Regards,
Sep 04, 2008 | Sony STR-DE698 Receiver
 Grubhead
Grubhead
