Question about Dayco 1999 Chevrolet Lumina 3.1L Curved Radiator Hose
Ethos code p1381 - Dayco 1999 Chevrolet Lumina 3.1L Curved Radiator Hose
My passat has a code p1381 what is mean of code p1381 on my volkswagen passat
By itself... not much is meant
(I'm just saying)
It would be nice to know why you were searching for diagnostic codes... but hey (we're just FREE volunteers).
It is directly translated into
"PC Solenoid Power Circuit - Low Voltage"
Have a nice day!
http://forums.vwvortex.com/showthread.php?1208701
http://www.ask.com/web?q=p1831+code+vw&qsrc=0&o=0&l=dir%24nextPageParams&qo=homepageSearchBox
Carnac the Magnificent
Jun 09, 2016 | Volkswagen Cars & Trucks
My check engine light keeps coming on code pops up P1381 i changed distributer what else can i do?
If it is a Honda (you do not indicate what vehicle you have) you will get that code with an aftermarket distributor. Replace with a genuine Honda distributor if you have a Honda and you will no longer get that fault code once it has been cleared.
Apr 07, 2016 | Cars & Trucks
I have a 98 chevy lumina with 61k miles.what can I do about these codes, P0300. P1381
P0300 is a random or multiple cylinder misfire, and P1381 is a misfire EBCM (Electronic Brake Control Module) or PCM (Powertrain Control Module) Since you mentioned replacing fuel components, it could be as simple as a fuel injector being clogged up causing a cylinder misfire. Have you checked your fuel injectors?
Jan 21, 2015 | Cars & Trucks
2002 chevy express 5.7L po300 and p1381 code
The P0300 is misfire detected. The P1381 is a loss of communication between the PCM and the electronic brake control module. You are going to have to have a scan tool for this note just a code reader. This is a complex diagnosis and I can't possibly convey all of the steps here. It is possible that you have a poor connection at the plug for either one of the ecm's. It's a long shot but you can try unplugging and re-plugging the harness going to both of them. Also check the ecm grounds, there is one at the back of the left cylinder head and a one at on a stud at the thermostat housing. Otherwise, this is not really a diy type of repair.
Mar 12, 2014 | Chevrolet Cars & Trucks
Code p1381
Error Code P1381: Cylinder Position Sensor Intermittent Interruption.
Fault:
- Cylinder Position Sensor defective.
- Wiring, loose connections, dirty connector.
- ECM
Jul 12, 2013 | Honda Cars & Trucks
1999 ford contour p1381 error code
Low oil level Cam timing improperly set Continuous oil flow to the Variable Camshaft Timing (VCT) piston chamber VCT solenoid valve stuck open Camshaft advance mechanism binding (VCT unit).
Read more: https://www.autocodes.com/p1381_ford.html
probably the cam sensor, sometimes the sensor can get damaged or the plug gets dislodged when the timing belt is done. .
Jun 20, 2017 | 1999 Ford Contour
P1381 Camshaft Position Timing Over Advanced (Bank 1)
Take vehicle back to the garage as it sounds like the sensor is loose or not plugged in.After paying all this money for the work to be done they should have it put right for free straight away and they should give you a cortesia car with a free tank of fuel while they put yours right
May 18, 2013 | 1999 Ford Contour
User instruction guide
Don't think it's a Honeywell product
http://www.gotoplumbing.com/uploads/Ethos-3654c.pdf
Jan 07, 2008 | Honeywell Programmable Thermostat Heater
Dayco 1999 Chevrolet Lumina 3.1L Curved Radiator Hose Logo
70 people viewed this question
Top Dayco Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Dayco Garden Expert? Answer questions, earn points and help others
