C310a 0xc19a0013 - Office Equipment & Supplies
Will not print in the middle of the page after installing all new cartridges
Hi there, I would be happy to help you with your C310a. I understand you have changed your cartridges and now the middle of your page will not print. Please use the following link to troubleshoot the issue: Fixing Print Quality Problems for the HP Photosmart Premium All in One...
I hope this helps. If the issue persists, you might consider calling us. Don't hesitate to call, although the printer may be out of warranty, the cartridges could be in warranty; therefore, there wouldn't likely be a fee for the phone support. We will, at our option, either replace products under warranty that prove to be defective or refund the purchase price.
We could even determine after troubleshooting that it is a problem with the printer, in which case they may offer you a discount on a newer model.
The number to call is 1-800-474-6836 for Canada and US, or you canContact HP Worldwide.
Best of luck!
I work on behalf of HP.
Jul 01, 2015 | HP CN503A - Photosmart Premium C310a...
Ink cartridges
Are you posting a telecom message or you need to say more about your problem.
Oct 15, 2013 | HEWLETT-PACKARD C310a All-In-One InkJet...
My C310a printer wont align
on the front panel press setup >> Tools >> Clean Cartridges
again press setup >> Tools >> Align Printer...
if it does not work then do a reset on the printer
and to do that Press BL/TL/BR/TL Buttons, in sequence
(BL: Bottom left, TL: Top left, BR: Bottom Right) >> Touch Support Menu >> Press Right arrow for Reset Menu and Touch OK >> Press Right arrow for Partial Reset and Touch OK >>
Wait for unit to Power Down/Turn Off >> Press Power button to turn the Printer On...
the printer would automatically align itself...
Hope this helps...
Oct 30, 2012 | HEWLETT-PACKARD C310a All-In-One InkJet...
I've just got HP Photosmart Premium c310a printer and when i start it up it shows the error! (0x61011beb) hope u can help. THNX
Hi
I've just got HP Photosmart Premium c310a printer and when i start it up it shows the error! (0x61011beb) hope u can help. Thanks
Feb 10, 2011 | Office Equipment & Supplies
Ink system failure error code 0xc19ac001
Go to hp support website .follow all the steps to resolve your problem.click on + '0xc19a0013' or no code displays with the 'Ink System Failure' message
Dec 11, 2010 | HP Photosmart C5180 All-In-One InkJet...
Hp 3310 photosmart - ink system failure 0xc19a0013
Ink may be new, but their nozzles may be blocked; depending on manner of storage. To be sure apply a folded tissue paper to the ink nuzzle and press firmly. If the tissue comes off well blotted with ink it means you still have a good amount of ink in it and the nozzle is not blocked. If not blotted or scantily blotted, it means ink is really low or nuzzle is blocked. To be very sure of this, place nuzzle in a plate/saucer with a bit water so that the nuzzle is soaked. Leave for about 10 minutes. Then apply the tissue again. If still not well blotted it means ink is really low or empty. If new you should return it for a replacement. In the case of blocked nozzles, the procedure may be repeated over to get results.
If this doesn't work let me know.
Dec 20, 2009 | HP Photosmart 3210 Printer
48 people viewed this question
k24674
jasbo
jasbo
