Question about Water Heaters
WATER HEATER MOD # FG1F3030T3NOV THERMOCOUPL THREADS ARE BACKWARDS WHERE CAN I FIND IT TO RPLACE IT
Part number for standard heating element for eco smart 11.3kw?
Go to ecosmartus.com
Click products tab at top of page
Click on your model number
Click on replacement parts tab
Buy part from ecosmart
Or remove element from water heater and look to see if threads are standard water heater element threads... then look at volts and watts printed on end of each element... buy ordinary element if it will work.
http://waterheatertimer.org/How-to-replace-water-heater-element.html
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 18, 2015 | Element Water Heaters
Power vent rheem mod pvw50 underneath is leaking
You have a water leak coming out of side of tank?
Water heater must be replaced. It is rusted, and could rupture.
Inspect and replace anode rod to prevent rusted tank, so water heater will last longer.
http://waterheatertimer.org/Leaking-water-heater.html
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Aug 09, 2012 | Rheem 50 Gallon FVR NATGAS Water Heater...
Water leaking from top on water heater
If it's leaking from a hose then you can try unscrewing the hoses, put some Teflon tape on the water heater threads and tighten. If it's leaking from the rim or under the threads call a appliance repairman.
Jun 03, 2011 | General Electric GE SmartWater Household...
Rinnai R50LS- water doesn't heat, even though there is good flow.
If it's a new install: the water is going backwards through the heater and you need to check that your cold water IN is actually hooked up to the cold water IN spot on the heater. they don't register flow if the flow goes backwards through the heater.
If it's not a new install: something is stuck in your flow sensor, drain the unit and take it out to check.
Apr 16, 2010 | Rinnai Water Heaters
HAE A GE WATER HEATER MOD PE50TA. WANT TO INSTALL
Hi .. you would be better off with a double pole switch. That way all the power is disconnected from the heater when the timer turns it off.
Apr 06, 2010 | General Electric GE SmartWater Household...
Pilot light goes out after water heater shuts off.
sounds like the wiring is backwards check the wiring
also check the thermo coupler
Jul 27, 2009 | RTO Atwood DSI-RV Water Heater-6 Gallon
CHANGING AN ORFICE
This unit cannot be converted from gas type to gas type.
Feb 24, 2009 | Rheem RTG-53PVN Indoor Natural Gas...
Water heater leaks on top
Make sure to use pipe dope(compound) or teflon tape on the threads. If you use the tape make sure to wrap the tape in the direction of the threads. Don't over do it with the tape 5 or 6 wraps should be fine. I prefer pipe dope myself....Joe
Dec 16, 2008 | Water Heaters
Water Heaters Logo
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
