Question about Exercise & Fitness
How do I order another safety button for my treadmill
The little red magnetic safety button on my treadmill is missing. How do I get one?
    Top Expert:
  • 12,223 Answers
Go to www. fitnessrepairparts.com and get it
God bless you
Posted on Nov 27, 2013
valiantma595
  • 176 Answers
SOURCE: I have a T54HR horizon treadmill. The problem is
best if you see the local retailer where you bought the treadmill. Obviously the switch, whick is a magnetic disc is not activating the sensor in the control panel and need to be looked at.
Posted on Sep 23, 2009
  • 246 Answers
SOURCE: WE have just moved home and lost our safety magnet
here's a link to an ebay page of treadmill safety keys for horizon treadmills. hope this helps!
Posted on Feb 18, 2010
SOURCE: I plugged in my Pro-Form 730cs treadmill and it won't start.
My i FIT treadmill won't turn on. Is there a reset button somewhere?
Posted on Apr 26, 2010
  • 95 Answers
SOURCE: I have a Sportsart treadmill
I would think that it can't hurt anything to try another magnet but if you end up needing to buy another one here is one website that sells them: Sportsart TR20F safety key
Posted on Apr 18, 2011
AJIN G
  • 6694 Answers
SOURCE: I have a proform fuel
hi,
You have to check the Driver circuit board for the motor. There is motor control IGBT Insulated Gate Bipolar Transistor) in this board .If the IGBT is short then the treadmill will try to run without setting any value or witout safety key . You have to check the OHMS between the seocnd and third of lead of the IGBT. If it shows less than 100 Ohms then the IGBT is short and you have to replace the same. Also you have to check the connection to the control pannel. Is there is any loose conatct. Remove the connection in the motor control board which go to the control pannel and reconnect it. Also check the speed sensor. In most of the treadmill you can find the speed sensor near the motor pully. Remove the speed sensor and clean it and the refix it. Remember one thing remove the power of the treadmill and leave it for 30 minutes then only oppen the treadmill. Because there is high voltage storage capacitors in the motor control board which will hold charge for some time even after the power is disconnected. i have added the picture of IGBT for your refference. There will be a part like this in your treadmill's motor driver board. You can see the part number on it.
OK
Posted on Sep 01, 2011
I need to purchase a replacement safety key for my pink confidence fitness treadmill and cannot find where to purchase in Australia. Need help
http://www.lifespanfitness.com.au/Treadmill-Safety-Key
just measure the diameter of the socket on treadmill and order a magnetic safety treadmill key.
Can get them on ebay but you would need to check the diameter of the sold key matches by contacting seller via ebay messaging.
this one below is from singapore $1.49 cost
http://www.ebay.com.au/itm/Running-Machine-Safety-Safe-Key-Treadmill-Magnetic-Security-Switch-Lock-New/172841698326?epid=2210203347&hash=item283e2b0416:g:wmIAAOSwRLlZo~B-
this one below is from australia
https://www.ebay.com.au/p/Running-Machine-Safety-Safe-Key-Treadmill-Magnetic-Security-Switch-Lock/26003745571?iid=282454053275&_trkparms=aid%3D555018%26algo%3DPL.SIM%26ao%3D2%26asc%3D20140106155344%26meid%3D255259a17a4f4034bdd90d3236d772e0%26pid%3D100005%26rk%3D4%26rkt%3D6%26sd%3D192235118553%26itm%3D282454053275&_trksid=p2047675.c100005.m1851
Jan 31, 2018 | eBay Computers & Internet
T700 treadmill console not working. Plugged in & worked; reached 3mph & removed safety magnet. Console went black; won't come on. Power switch lights up; lower board led light shows power on.
The treadmill will not run if you remove the safety magnet. Replace the safety magnet and reset the treadmill. Should start working again.
Thanks.
I’m happy to assist further over the phone at https://www.6ya.com/expert/christopher_722ea729aae6fd07
Aug 15, 2016 | Exercise & Fitness
Missing little magnitic sticker inside safety key slot?
Dear Sir:
Please go to any Hardware, and buy any small magnet, and put again in your treadmill. Since the little magnetic is the key for turn on any Treadmills.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a
Apr 04, 2012 | Sportcraft Exercise & Fitness
Error 7 on my york inspiration treadmill tried reset button but still not working any ideas.
hi,
By error 7 it means that the safety is not positioned correctly. or the saftey switch inside the unit is faulty. Its a magnetic switch. When you place the safety key (its made of magnet) this switch will activate. Then only teradmill start. Check the safety key is positined correctly or not. If it is in position then you have to replace the safety switch inside the control console.
OK
Sep 01, 2011 | York Barbell Home Use Fold-Up Treadmill
Im wondering if there is supposed to be a big magnet on my safety key for my eks treadmill because i went away for the weekend and had house sitters in and i returned to turn my treadmill on and its not...
Shannon-
Yes, EKS uses a magnet in the safety key for their treadmills. You may be able to find replacement magnet at your local hardware store. A dab of glue and you're all set. There are also a numerous online retailers that will sell a replacement EKS safety key. A google search will reveal a number of options.
Regards,
DIYpro
Apr 28, 2011 | Sport & Outdoor - Others
I lost my magnet safety key, can I us another magnet or do I need to order one from EPIC
Dear Sir:
Will be a good Idea to replace with the original, and order to the Company.
sincerely.God bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Jan 17, 2011 | Epic 425 Mx Treadmill EPTL88105 !
What can I use instead of a safety key? I have lost the red magnetic key from my york tredmill
staples sells a round magnet with the silver clip attached that works perfect,
Oct 20, 2009 | Weslo Cadence Ct 5.8 Treadmill
Buttons not working
there is a safety key (red magnet) needed to operate the treadmill; you can get that from the person responsible for the sports section.
Oct 07, 2009 | Weslo Pro Crosswalk 7.8 Treadmill
Sep 23, 2009 | Horizon Exercise & Fitness
Exercise & Fitness Logo
23 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
