Can not update windows because of failed connection
Why does window updates fail?
could be a bad update prior to the failure.Suggest going to programs and features and selecting show updates . Then remove two last updates and then try to update it again
May 02, 2017 | The Computers & Internet
Windows update stops working, check for updates failed
I've found that re-registering the dlls has solved quite a lot of windows update issues. have you tried this?
see method 5 here:
http://support.microsoft.com/kb/326253
Dec 22, 2012 | Toshiba Satellite X205 Notebook
Windows update failed
You version is no longer supported, time to upgrade
Apr 04, 2017 | Office Equipment & Supplies
Hi!! How are u? My english not good that much but i will try to explain my problem: when iam open my computerwhich work by windows xp sp3 i got massage the ip operator (3.0208.911.01) is not...
OK, sounds like the problem is that the computer cannot get a valid IP address. In fact it sounds like you might have a IP address conflict on your network. Each IP address on a network segment must be unique.
Check if you are using DHCP.
  • Go to
  • Control Panel
  • Network connections
  • Locate the network connection you are using e.g. 'Local area connection' or perhaps 'Wireless connection'
  • Right click on the relevant network connection
  • Select 'Properties'
  • Select Internet Protocol (TCP/IP)
  • Select Properties
Is your machine set to "Obtain an IP address automatically" (DHCP) or "Use the following IP address".
If its "Use the following IP address" then make sure no other machines are also using this IP address. You can try setting to 'automatic' but if you do, make sure that you note all details first, so you can revert back to the settings you currently have if you need to.
if its "Obtain an IP address automatically" then make sure no other machines have been manually set.
With regards to the microsoft update, then your best bet is to only select a small number of updates at a time, until you determine which update(s) is causing the failure. Once you know which update is the problem then you can troubleshoot the specific update.
Hope this helps
Please take the time to rate this answer. Many Thanks Don.
Sep 05, 2011 | Microsoft Computers & Internet
Windows Vista: I cannot install anything at all.
Is your Vista a 32 bit or 64 Bit O/S
open this link and run the Windows readiness tool, This will help the PC unblock any failed updates for Windows and help you install the new updates.
http://www.microsoft.com/downloads/details.aspx?FamilyId=b4d90b06-c27d-4483-bc1f-04d43fa7b293&displaylang=en
Windows installer for Vista is Installer version 4.5, so the updates should fix the issue.
Jun 29, 2010 | Computers & Internet
Windows Vista:: to Install Problems: 1."Windows Update cannot currently check for updates, because the service is not running. You may need to restore your computer." 2."The Windows Installer Service...
I have a failed update in my update history list
I am sorry, there's was an unexpected connection failure which i didn't notice. If your problem isn't solved yet, please let me know. I am ready to assist you further. Good luck.
May 26, 2010 | Computers & Internet
Keep getting a message that updates failed. Go to
Please try connecting yyour computer directly to modem, bypassing the router. In case you are able to download updates in this way, please contact your ISP to forward ports on the router for windows updates.
May 07, 2010 | Webroot AntiVirus with AntiSpyware &...
Driver update problem for digital camera
In order to get rid of the error, you have uninstall the driver, update your operating system with updates from Microsoft (see below for instructions) and follow these suggestions:
  1. Best method, copy the photos to the computer by connecting a card reader to the computer and plug the SD card into the card reader and transfer using your favorite software (like Picasa) or through My Computer.
  2. Drivers are not required for the A400 and Windows XP. So you can plug in the camera, without drivers and it should work. This appears to be the one that's not working, You need to un-install the drivers and either reinstall, try updated drivers from the links below, or don't use the drivers.
This information is in the manual on page 96. See this link for the manual.
See this link for details about the WIA driver.
About the error "driver update failed" rea
I personally have stopped altogether trying to get the drivers and software installed because they can cause more problems. I just transfer using a card reader.
If you want to use the software that comes with the A400, it's best to install ZoomBrowser, then you will need to follow to this link to get the update to this software.
Once this is done, reboot your machine to make sure the system is then up-to-date.
Make sure you have also updated your machine with Windows Updates. This is done by opening Internet Explorer and clicking on Tools | Windows Updates. Follow the links at their site to update your machine.
Dec 06, 2007 | Canon PowerShot A570 IS Digital Camera
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
