Hoover washer not working
Big bang lights went out tripped the switch now washer not working, door lock light stays on which means door is not locking lights on machine are ok but will not work
    Genius:
  • 1,198 Answers
Find the big capacitor inside the machine, see if it looks bad. Careful, even damaged it still can hold a charge like a tazer.
Posted on Nov 26, 2013
  • 1314 Answers
SOURCE: My Hotpoint Aqaurius WD62 door is shuting but the door lock light wont come on!
you may need a switch but not a door see if you can adjust the door and try shutting it hard as front loaders close snug because of the rubber boot check your power too
Posted on Mar 02, 2008
  • 8 Answers
SOURCE: child lock light stays on - & cant start mc programmes
HI I KNOW IT SOUNDS DAFT BUT HAVE YOU TRIED SWITCHING THE CHILD LOCK OFF? I CANT REMEMBER EXACTLY WHICH BUTTONS IT IS ON YOUR MODEL BUT YOU USUALLY HAVE TO PRESS 2 BUTTONS AT THE SAME TIME (& SOMETIMES HOLDING THEM FOR A COUPLE OF SECONDS) RATHER THAN JUST 1 TO SWITCH THE CHILD LOCK ON/OFF. IF YOU STILL HAVE THE INSTRUCTION MANUAL IT WILL TELL YOU WHICH BUTTONS YOU PRESS TO SWITCH CHILD LOCK ON/OFF HOPE THIS HELPS!
Posted on Jul 30, 2008
mumma_1
  • 903 Answers
SOURCE: Door Lock Light - flashing
does the door still lock? becasue it sounds like a faulty lock. It may need to be replaced.
Posted on Oct 23, 2008
ginko
  • 19396 Answers
SOURCE: Whirlpool duet 9400 Washer won't do anything?
Hi.
Please read the Fixya article below explaining how to fix the problems related to control lock on Whirlpool dryers and washers.
The front light lit on my Whirlpool.
Regards.
Posted on Feb 22, 2010
SOURCE: Hoover washer/dryer VHW854D SHOWS ERROR
I have exactly the same problem. Hoover Service Centre told me to tip a bucket of warm water into the drum and leave for 5 minutes before switching it back on. The idea is that the machine may be affected by the cold weather. Needless to say it made no difference and Error 11 remains - I am expecting an engineer on Thursday 23 I'll keep you posted on the outcome.
Posted on Dec 20, 2010
My water was not in when I ran a cycle thru my front load maytag washer. Now it there are no lights on and it won't unlock
bang the door when its switched on
sounds like something to do with the door lock
turn it on and bang the front of the door lock
then seek a new door lock interlock,,,
Nov 14, 2014 | Maytag Washing Machines
Hoover nextra washing machine door wont lock / cycle start
sounds like the door lock mechanism. if this cannot signal it has engaged, to the board, no other function will work (you don't want the washer going with the door open, trust me :) )
Nov 08, 2013 | Hoover Nextra 160 HNWF 3137 Front Load...
Machine wont sart
Your door lock/latch is broken, this is a common issue with front loading washing machines and the only way to fix it is to replace the door switch.
Mar 05, 2012 | Hoover Nextra HNF 2137 Front Load Washer
Cannot open door and lock light stays on
It has a timer circuit that locks the door with a selenoid. It has a sprig that pulls the safety latch back off of the latch. Either it isn't turning the power off or the spring is broken or too dirty with soap and wont work right. Try pulling the power and see if that works. If not got to take front cover off and check it out.
Jun 01, 2010 | Hoover AAA140 Front Load Washer
My Hoover Optima OPH 714 D washing machine won't start
Hope your tried switching off the machine for half to one hour, to re plug. Machine might re-set.
If helped, pl click, it could help others.
Dec 07, 2009 | Bosch Washing Machines
Hotpoint WMA33 washer - door won't open
Problem seems to have corrected itself! I tried another slow spin cycle, waited a reasonable interval for the Door Locked light to go off, then when it didn't I switched the power to the machine off. I tried squeezing the door catch a few times and pressing the door downwards, then left it. Some time later when I went into the kitchen the door was open. I washed a small load this morning and the machine worked normally. Fingers crossed, it's ok now.
Oct 07, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Machine partially fills and then stops working.
THE RCD SWITCH is concealed on the inner side of the hindges of the door or on the top innerside of the door. it is a simple push switch which has a mechanism of push to on/off
this switch has got stuck in off position.
change this switch or spray a drop of rust removal oil. it will start functioning
Aug 27, 2009 | Whirlpool AWM8123 Front Load Washer
Affinity LTF7000ES door not staying locked
unplug the washer and wait 5 minutes before plugging it in again!
this resets the system. If this does not work then you may have a faulty door lock, latch, or switch!
An need hands on service on location
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Dec 31, 2008 | Frigidaire Affinity ATF7000E Front Load...
Door lock light flashing
could be a faulty belt. May need replacing. Or in the worse case scenario the bearings may need replacing.
Sep 21, 2008 | Hotpoint WMA46 Front Load Washer
Door on the Hoover washing machine, model H130E
make sure the tap is not broken off ,if the tap is good that means you switch is bad, replace it. hope this information could help you.
Apr 23, 2008 | Hoover H130E Front Load Washer
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
