Question about Leisure Cookmaster CM101NR
Timer not working power on but not illuminated
I have 3 landscape lights that were working but quit working in a system with about a dozen other lights that continue to work. I presumed the bulbs needed replacement but that didn't help. I verified...
My experience has shown that this is nearly always a connection and/or wire corrosion issue. Be certain that all connections are clean-if not clean with fine grit sandpaper or replace. Remember these devices are exposed to the weather on a continuous basis.
Nov 04, 2013 | Intermatic Malibu 300W Power Pack...
Tip
Toshiba TDP-P9 Lamp time reset
I had sleepless nights with my customers TDP-P9 projector where I changed the lamp.
The lamp timer resetting gave me headache but now I finally solved the right combo:
1: Unplug the power cord
2: Hold down 'On/standby' 'Input' and 'up arrow'
3: While keeping the buttons pressed, insert the power cord and wait for the projectors led's to flash briefly and then power button to keep illuminated and then starting to blink.
4: Release the buttons and power on, it should now have 0 hours in the timer.
on Apr 06, 2011 | Toshiba TDP-P9 DLP Projector
Dodge dakota headlight
The most likely cause of this is a failing Central Timer Module (CTM). The CTM directly supplies power to the headlamps and dash illumination. The head lamp switch sends a signal to the CTM, and then the CTM sends power to the lamps. Replacing the CTM should take care of this.
May 15, 2013 | 2003 Dodge Dakota Club Cab
I replaced an old Malibu 300 watt powerpack with a new digital 300 watt Malibu power pack and when I turn it on it runs for about a miniut and then shuts down. I have 15 11watt light on it, the same as the...
300 watt power pack should have 300 watt load.
You have 165 watt load.
Copy following link for general tips to get Malibu power pack to last longer.
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Problem might be the photo eye.
http://waterheatertimer.org/images/Malibu-8100-9045-01-large.jpg
Rotate manual dial to ON position and see if lights turn ON.
Keep in mind the digital power pack has photoeye that is light sensitive, and must be exposed to dark light to activate.
For timed functions. Rotate manual dial until it points at timer. Press clock set function button, and use up-down buttons to set current time. Press timer ON button, and then use up-down to set ON timer. Then press timer OFF button , and use arrow keys to set OFF time.
This product has 1 year limited warranty, contrast with old-type analog power pack with 5-year warranty.
Malibu does not even post a manual on their site, which might have troubleshoot section to illuminate why your system has problem,
http://malibu.brinkmann.net/customer_service/owners_manuals.aspx
Nov 29, 2012 | Hardware & Accessories
How do I set the sleep timer? We got the tv from a friend and it had no manuel.
Programming the Sleep Timer:
  1. Press and release the TV key.
  2. Press and hold the SLEEP key for three seconds. The illuminated component name turns on.
  3. Release the SLEEP key.
  4. Using the number keys, enter the desired time in minutes (from 1-99 minutes). To set the timer to an umber under 10 minutes, first press 0 and then the desired number (e.g.,05 for five minutes). The illuminated component name blinks with each key press.
  5. Once the second number is entered,the illuminated component name turns off.
    Tip Any key press other than the number keys is ignored. If you don't enter the sleep time within 10 seconds after pressing the SLEEP key, you must start over at step 1. The illuminated component name blinks four times and then turns off, indicating your attempt to program the Sleep Timer has been unsuccessful.
  6. The Sleep Timer is now set.
  7. Leave remote aimed at the TV. Once the Sleep Timer is set, you can continue to use the remote without affecting the Sleep Timer. However, because the timing mechanism for the Sleep Timer is built into the remote itself, the remote must be in TV Mode and pointed at the TV to activate the Sleep Timer.
    Note: If the ON·OFF key is pressed, the Sleep Timer is canceled.
Aug 19, 2011 | RCA Rcr461 Remote Control
Where the fuse box to a 88 ford thunder bird 5.0 liter
The fuse panel is located underneath the dash, to the left of the steering column, next to the emergency brake pedal. You need to remove the under-dash insulation to access some parts of the fuse panel.
If it doesn't have a diagram inside the box, here's one I found online: http://www.coolcats.net/tech/reference/images/fusepanel.jpg
1 15A Lt. Blue Stop Lamps, Hazard Warning Lamps, Speed Control, Cornering Lamp Relays 2 6A - CB - Windshield Wiper/Washer Pump 3
Spare - Not Used 4 15A Lt. Blue Taillamps, Parking Lamps, Side Marker Lamps, Instrument Cluster Illumination, License Lamps, A/C and Heater Illumination, Radio Illumination, Digital Clock Illumination, Autolamp Relay 5 15A Lt. Blue Turn Signal Lamps, Electronic Day/Night Mirror, Lighted Vanity Mirrors *, Backup Lamps, Illuminated Entry, Keyless Entry, Cornering Lamps 6 20A Yellow Rear Defrost Timer, Chime, Back-Up Lamps, Cornering Lamps, Rear Reading Lamps, Trunklid Release, Digital Clock Display, Illuminated Entry, Anti-Theft Module, Turbo Buzzer 7 15A Lt. Blue Fog Lamps (Turbo Only) 8 15A Lt. Blue Courtesy Lamps, Key Warning Buzzer, Illuminated Entry Module, Glove Box Lamp, Door Lock Relays, Radio Memory, Cluster Memory, Outside Mirrors, Tripminder Module, Analog Clock, Anti-Theft Relay 9 30A Lt. Green A/C Heater Blower Motor 10 20A - CB - Horn, Cigar Lighter, Fuel Filler Door, Flash-to-Pass, Speed Control 11 20A Yellow Radio, Tape Player, Premium Sound Amp, Power Antenna, Graphic Equalizer 12 20A - CB - Power Seats, Power Locks, Keyless Entry 13 5A Tan Instrument Cluster Illumination, Radio, Climate Control 14 20A - CB - Power Windows, Power Moonroof 15 10A Red Taillamps, Rear Side Markers, License Lamps, Electoluminescent Coach Lamps 16 4A Yellow Electronic ATC 17 15A Lt. Blue Electronic Cluster, Tripminder Display, Fuel Gauge (non-electronic cluster), A/C Clutch, Speed Control Module, Graphic Warning Display Module, Electronic Blower Speed Controller 18 10A Red Warning Indicator Lamps, Autolamp System, Throttle Position Sensor, Low Fuel Module, Dual Timer Chime, Tachometer, Washer Fluid Level Indicator
May 20, 2011 | 1988 Ford Thunderbird
Timer clock is not illuminated and oven will not work
This does have an internal fuse and there are probably 2 or 3 of them. They should be located right behind the timer or thermostat.
Feb 03, 2009 | Blodgett Ovens
Need instruction sheet
Your unit has a lifetime warranty. Go to this website to get the instructions in PDF format:
http://www.hardwareinnovations.com/pdf/SA_210_IB61056_33.pdf GOODLUCK
SA 210 Zip Set Outdoor Digital Timer with 3 Outlets features a Zip-Set One-Step Set-up where you simply enter your area code and the timer is programmed. Your lights will automatically turn on at sunset, and auto-adjust for seasonal time changes. Other features include a random setting for added security, a 7-5-2 setting for full weeks, weekdays, or weekends. Battery back-up (batteries included) to save resetting time in the event of a power failure. It has 2 timed outlets, plus 1 extra untimed outlet for use with other products. It has an easy-to-read, large illuminated digital display, and 15 amp capacity. Lifetime warranty.
Product Description
Zip-Set™ Technology with One-Step™ Set-Up Two Timed Outlets + 1 Untimed Outlet Controls three Products Simultaneously Controls Outdoor Landscape, Security and Holiday Lighting, Pool/Spa Pumps and Engine Block Heaters Optional 4 On / 4 Off Settings Random Settings for Added Security 7-5-2 Feature allows you to set times based on the 7 Day full week, 5 Day work week, or 2 Day weekend Large Illuminated Easy-to-Read LCD Display & Keypad Battery Back-Up (battery included) saves resetting time in the event of a power failure Weatherproof 15 Amps Lifetime Warranty
Dec 22, 2008 | Sylvania Hardware & Accessories
Oven not working
i think both of you have not set the clock correctly and oven is on automatic. get the book out and try again
Sep 07, 2008 | Ovens
Leisure Cookmaster CM101NR Logo
13 people viewed this question
Top Leisure Kitchen Ranges Experts
Timllfixit
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Leisure Kitchen Range Expert? Answer questions, earn points and help others
