Question about Simplicity American Denim SA1100 Mechanical Sewing Machine
How to thread a bobbin on huskystar 219 - Simplicity American Denim SA1100 Mechanical Sewing Machine
How do I adjust the thread tension and bobbin tension on a Huskystar 207?
thread tension is by a knob on the face of the machine
if you find by adjusting that , nothing is happening , check the way the thread has been put in as it can get behind the pressure plates and jam on the bolt or not be between the pressure plates and just running free
bobbin tension is by the small screw that holds the flat spring under which you pull the thread after fitting in the bobbin back in the carrier
( seldom need to adjust bobbin thread tension)
Dec 13, 2016 | Sewing Machines
Huskeystar219 how to thread the sewing machine
here is a link for a manual or you can check youtube for a video
Viking Huskystar 219 224 User Guide
Aug 01, 2014 | Sewing Machines
Bobbin loading
it wont unless there is thread and it has to catch with the top thread. or else you put it where the thread is fed backwards. or, you have to push the lever back over that you filled your bobbin with.
Aug 22, 2012 | Husqvarna Huskystar 215 Sewing Machine
I can not get my bobbin thread to sew but my top thread does on my Huskystar 207 sewing machine
have you checked to may sure the bobbin is turned the right way & inserted
in the bobbin case the right way?
try changing the needle --flat side goes to the back of the machine
Apr 05, 2012 | Sewing Machines
Bobbin thread jams
try changing the needle--flat side goes to the back of the machine
check the thread take up lever & see if the thread is still on it
it's also possible that the machine is out of time & needs to serviced
Feb 19, 2012 | Husqvarna Huskystar 207 Sewing Machine
Husqvarna Huskystar 207 Sewing Machine not stitching. It won't pull the bobin thread up to sew.
Be sure not to use Singer Needles. They are longer than standard needles. Don't know if this helps, but I did this once on my Huskystar 207 and that is what happened. It also damaged the bobbin thread.
Fairleigh
Sep 18, 2011 | Husqvarna Huskystar 207 Sewing Machine
No info in the book for Huskystsr 219-224 for oiling it--HOW DOES ONE LUBRICATE IT??
Not sure if you want to oil the hook and bobbin area or the whole machine.
The hook and bobbin area is eazy, just put a drop of oil in the Hook. To do this just put a drop just under the bobbin Do this ever 2-3 bobbins and just one drop, not two.
To do the whole machine you will need to remove the panels and lubricate all metal on metal moving parts, but that is usaly done buy a sewing machine teck.
Mar 27, 2011 | Husqvarna Huskystar 207 Sewing Machine
My 5 year old Huskystar 216 sewing machine is
Sounds like the hook/needle timing. To check do the following:
With the power off!!
remove bobbin and bobbin case.
push needle all the way to the left.
Turn handwheel toward you watching the needle and bobbin housing hook. The point of the hook should line up right above the eye of the needle.
If not timing, clean bobbin area removing lint and thread.
Check bobbin tension, should get slight resistance when pulling thread.
Make sure using only Husqvarna Viking bobbins -- most are green but they have new colors now. All will have the Husqvarna logo on them (an H). Make sure the bobbin is unwinding in the right direction.
Remove fabric. Pull extra long bobbin thread (about 3 inches). Hold upper thread tail in left hand, turn handwheel toward you for 1 revolution. Is the bobbin thread caught by the top thread and pulled through the opening of the needle plate?
If you are still unable to get a good stitch, take to an authorized Husqvarna Viking dealer for service or have them send to Husqvarna Viking (SVP) Technical Service Dept for repair. A list of dealers close to you can be found at the Husqvarna Viking website - http://www.husqvarnaviking.com/us
Good luck.
Sep 26, 2009 | Husqvarna Sewing Machines
Simplicity American Denim SA1100 Mechanical Sewing Machine Logo
112 people viewed this question
Top Simplicity Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
doylesouders
Level 1 Expert
Are you a Simplicity Sewing Machine Expert? Answer questions, earn points and help others
