Question about Kent International Alameda 26" Adult Tricycle
L.R. wheel bearings placement of bearings and spacers
Show me proper spacer placement on rear axle of 2002 hd duece
The axle enters from the disc brake side through a collar (washer with a cut out on it, axle adjuster bolts sits in cut out), through the swing arm, through the plain spacer, then through the wheel, then through the spacer that has a type of grouve in the middle of it, through the swing arm and finally through another collar, then a washer and finally the axle nut. Nut torque is 60 - 65 ft/lbs. Do not exceed 65 ft/lbs or wheel bearing damage will occur.
Oct 04, 2014 | Harley Davidson Motorcycles
What is the front wheel spacer placement on 2005 flht
Install or place the wheel into position between the forks with the valve stem on the right side of the vehicle. THEN coat the axle with bearing grease. THEN while supporting the wheel, insert the threaded end of the axle through the right fork leg and push it through the fork, the short external spacer and the wheel hub until it begins to emerge from the left side. THEN with the three notches on the bearing side, push the axle through the long external spacer and the left fork leg until the axle shoulder contacts the external spacer on the right fork side. THEN install the flat washer, lock washer and axle nut. THEN insert a screwdriver or a steel rod through the hole in the axle on the right side of the motorcycle AND THEN while holding axle stationary tighten the axle nut to 50-55 ft-lbs (68-75 Nm). THEN insert a 7/16 inch drill bit into the hole in the axle and pull the fork leg so that it just contacts the drill bit, and then tighten the axle holder nuts to 132-180 in-lbs or (14.9-20.3 Nm). THEN remove the drill bit from the axle hole. THEN install the brake caliper tightening the mounting bolts to 28-38 ft-lbs or (37.9-51.5 Nm). THEN BEFORE moving the motorcycle, pump the front brake hand lever until the caliper pistons push the pads against the brake discs because if the pads have not been hydraulically pushed out against the brake disk the brakes will not work when they are first attempted to be applied. SO, depress front brake hand lever several times to set the brake pads to the proper operating position within caliper before you attempt to move or ride the motorcycle.
Aug 05, 2014 | 2000 Harley Davidson FLHTCUI Electra Glide...
2004 harley flhrci rear wheel spacer positioning
If you look at it the spacer will only LOGICALLY go one way. The small side matches the bearing inner race diameter so it will go to the bearing on the right side and another giveway is that the left side spacer is the same diamter as the right side narrow diameter so that would have to go to the bearing so both similar diameter spacer dimensions will go the same way ie to the bearing race.
Aug 19, 2012 | Harley Davidson FLHRCI Road King Classic...
Im trying to replace the wheel bearing on the front wheel suzuki vz800 2000 trying to get them out
Push the spacer between the bearings off to one side. Get a chisel or an old screw driver and tap the inner race of the bearing out from the opposite side. Save the spacer. Flip the wheel over and tap out the other side. Grind the outer edge off one of the old bearings and place it over the new bearing. Tap on the old bearing to drive the new bearing into place. You may have to finish the install with a chisel on the outer race. Alternate tapping from side to side being careful not to damage seal. Flip the wheel over put the spacer back into the wheel and tap the new bearing into place so that it barely touches the spacer. The bearings should spin freely, but should not bind (inner races pushing too hard against spacer will cause binding). If you install too tightly reach through the wheel and tap on the opposite bearing only enough to stop the binding. Press in the seals and reinstall the wheel on the bike.
Apr 01, 2011 | Suzuki VZ 800 Marauder Motorcycles
1993 Kawasaki ZX6E rear wheel bearing diagram
Hi, Est2rad1961 nice novella but all you needed was the bold print up top and what you mean your spelling is bad you only made 78 spelling errors no big scare I cleaned it all up for you at no charge, for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Kawasaki, despair not, for a mere zero $ you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day
1993 Kawasaki NINJA 600R ZX600 C6 Rear Wheel Chain
OEM Parts for Kawasaki
Kawasaki 1994 Ninja ZX 6R Service Manual
Kawasaki Ninja ZX 6R Owner Manual
http://www.motorcyclespecs.co.za/model/kawasaki/kawasaki_Zx6%2093.htm
Feb 28, 2017 | kawasaki Ninja ZX6 R Motorcycles
I need to know rear wheel spacer placement. also where to rreference to align the rear wheel. it seems i have un equal space between the wheel and fender. i have a total of three spacers two on the pulley...
The wheel not being equally spaced under the fender is typical of all Softail motorcycles. They have an "offset" wheel stance. I don't know exactly why but they are designed this way.
The three spacers you are talking about is actually one spacer and two seal races. The two seal races go into the wheel bearing seals on either side of the wheel. This provides a smooth finish for the wheel bearing seals to ride on. The other "spacer" is a bit larger and goes on the belt side of the wheel and the rear brake caliper bracket acts as the spacer on the other side. Anytime you take the wheels off your bike, always mark and make a drawing of the positions of the spacers.
Good Luck
Steve
Oct 12, 2010 | 2003 Harley Davidson FLSTFI Fat Boy
How many spacers are with the front wheel
Not quite sure how to answer this because of your definition of spacer may not be the same as mine. If I'm not mistaken, there are two "spacers" that are actually part of the wheel bearing seal. The are both exactly alike and the sit in the wheel bearing seals. Then there is one spacer that goes on the axle. The axles is undercut on the other side.
Good luck
Steve
Aug 13, 2010 | 2001 Harley Davidson FLSTF - FLSTFI Fat...
Rear wheel spacer placement?
Take great care on reassembly ,as the spacers may be of diffrent lenghts which will if put back wrongly will throw the wheel off its true running centre .and cause problems .Allway remember to mark parts or do a drawing when removing and stripping down for repair or servicing ..It saves a great deal of problems .Try and assemble the spacers and look to see if the wheel is in line with the belt drives .
Mar 14, 2010 | 2005 Harley Davidson FLHTCUI Electra Glide...
Kent International Alameda 26" Adult Tricycle Logo
530 people viewed this question
Top Kent International Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Kent International Toy Expert? Answer questions, earn points and help others
