Door release siemens s14 38 - Washing Machines
Siemens iq500 washing machine. WD15G460GC PLEASE ASSIST!!! I've seen previous responses where to solve the problem people suggest holding start/reload, however this isn't helping. The key symbol is...
not sure if this was suggested but Siemens suggests unplug the machine, plug it back in and wait a few seconds, then select a cycle. The locked door should release.
Feb 06, 2018 | Siemens Washing Machines
My washing machine siemens has developed e 57 error code how can i recover that
Hi Evans,
E57 is a door lock fault. Now either the door lock itself or the control board will cause this fault.
What you need to do is open the little filter cover in the bottom right corner and there is a pull tab.
Pull this and that should release the door and allow you to open it.
Then retry the washer again and see if the fault has cleared.
If not then remove the top of the washer and remove the control board. From there check to see if theres any signs of burning on there. If so then the board will need to be replaced.
If the board looks ok then you can try and replace the door lock and see if it cures it. But if still after replacing the lock its the same then the control board will be the fault here.
Jan 05, 2017 | Siemens Washing Machines
Error code F63 for Siemens 14.46? - Siemens WFXD5200UC Front Load Washer
This error indicates a fatal error with the control board. A replacement board for the WFXD5200UC is available here: http://www.repairclinic.com/Shop-For-Parts/a11b129i1995d691201/Model-WFXD5200UC01-Bosch-Washing-Machine-Main-Control-Board-Parts .
Before you replace the board, you may be able to reset the error code. Start with the washer off (the knob will be at the 12 o'clock position) and the door closed. Turn the knob to the 6 o'clock position and wait 2 seconds. Press and hold the spin button while you turn the knob to the 7 o'clock position. Wait another 2 seconds and release the spin button. Turn the knob to off. You may need to repeat this up to 6 times. If the error continues to appear, the board is faulty.
If the washer is under warranty, contact Siemens. I hope this helps.
Jul 11, 2016 | Siemens Washing Machines
I can't get the child lock to deactivate on my Seimens S12-38 washing machine. Anybody got a solution?
Deactivate child lock siemens washing machine S12-74 ...
www.fixya.com/.../t15773878-deactivate_child_lock_siemens_washing
Jan 10, 2013 - deactivate child lock siemens washing machine S12-74 - SiemensWashing ... -Press and hold the option down touch button for 5 seconds or until you seethe magic message 'Child lock released'. ... I can`t deactivate the childlock ... I CANTDEACTIVATE THE CHILD LOCK AFTER WASHING MY CLOTHES.
How to unlock washing machine door for siemens s12.38 ...
www.fixya.com/.../t11409270-unlock_washing_machine_door_siemens
Dec 21, 2015 | Washing Machines
Have any idea how to open the washing machine door iQ700 Siemens
Wait for cycle to fi?ish, plus another minute or so. Then activate door release. If this fails I suggest that you have the machine looked at by a technician.
Jul 16, 2015 | Siemens Washing Machines
Door of Washing machine doesnot opened
the door interlock has failed
other then try to leave it off and struggle with the door
you need sometimes to release it from behind
not easy sometime with some machines
the replace the door lock interlock catch
it will work fine then
Sep 19, 2014 | Siemens Washing Machines
S14-44 washing machine door locked
the door interlock has become worn or has failed
you need to get to the switch from behind
by taking the lid off taking the power off
and reach down to release it
the door interlock has failed and needs replaced
common fault.
look on ebay
but the model number you give is is not right
so i can help you more just now
post the actual model number
and a quick ebay search as .com .uk etc .de
will bring up the part you need
Jun 01, 2014 | Siemens Washing Machines
How to unlock siemens wd12d520/01
unplugging the appliance for 10-15 minutes should automatically release the door unless the appliance is still full of water. If it is then this needs to be drained out manually by lowering the waste hose into a bucket until the water level is below the door seal
Apr 11, 2014 | Siemens Washing Machines
Washing Machines Logo
50 people viewed this question
Top Washing Machines Experts
