Question about Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus Gas Dryer
Got heat just no tumble belt is on - Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus Gas Dryer
    Scholar:
    New Friend:
  • 81 Answers
Try holding the door switch and having someone start the dryer. If you spin the drum by hand with the door open and it takes off spinning, you have a bad/jammed motor. 300-400 dollar repair someone else would be better off doing. 4 hours to figure it out. 130 dollar part on the internet.
Posted on Nov 27, 2013
My dryer turns on and reads sensing , but does not turn ....does heat
If your dryer heats yet does not tumble i would be looking for a broken belt..when its heating that means the motor is running,but since i suspect the belt of being broken its not tumbling
Sep 13, 2011 | Whirlpool WED8300S Dryer
My dryer heats up but does not tumble. I replaced
Sounds like worn tub back bearing.
take the belt off and spin the tub by hand to see if it is binding.
check that the pulley isnt loose on the tub back and also the motor pulley, feel if the motor spins free.
Finally check the tub itself for objects poking through or lodged in the outer tank.
Good luck
Mar 18, 2010 | Dryers
How to clean a whirlpool awz7913 condenser tumble dryer heat exchanger
how do i clean my heat exchanger on the whirlpool awz 7913 condenser tumble dryer?
Jan 19, 2010 | Whirlpool Dryers
Indesit is60v tumble dryer is not spinning although still heats, would this need a new belt?
Indesit tumble dryer not turning? How to replace a Indesit tumble dryer belt.
This video will show you how to replace a tumble dryer belt in your appliance
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question. Tumble Dryer Belts from How to Repair Home Appliances
Jan 18, 2010 | Dryers
Whirlpool tumble dryer model NO- AWZ 121/3-belt replacement
how do i replace my belt on my tumble dryer
Jan 09, 2010 | Whirlpool Dryers
Whirlpool LER 6620 heats, but does not tumble.
if the dryer heats the motor should be good. if it hums its either runing or the hum is a stall noise . if belt is in tact then if motor were going so would the drum . so i think the motor isn't going just humming and the heat sw in the motor is stuck closed with lint and you need to replace the motor .. take the belt off and turn motor if it turns free . the blow it out good and reinstall belt and try again ..mm
Dec 03, 2009 | Dryers
Kenmore dryer 75731 won't tumble. It heats fine.
Hi.
The machhine is belt driven check the belt first.
If the motor is must be tested energizing it.
In all cases test the lid switch to ensure it is not opening contact when machine starts tumbling.
The wiring harness to motor must be tested.
If there is no other fault elsewhere, replace the timer board.
Start from the belt, if the machine is heating, then it is probably a broken belt.
Nov 13, 2009 | Kenmore 63942 Dryer
The dryer heats but will not tumble. I am
if the belt was broken, the safety switch would shut off the machine. the belt is probably slipping, stretched from age. replace belt
Jul 09, 2009 | Frigidaire FGX831C Top Load Stacked Washer...
Dryer not tumbling
A broken belt is very common. If you hear the motor running, that's probably it. The dryer must be taken all apart to replace the belt. Hopefully instructions will come with the new belt. Routing the belt over the motor shaft and around the tensioner is always a challenge.
Apr 22, 2009 | Candy CDV262 Dryer
Dryer heats but does not tumble.
Yes, it is possible that the drum belt is broken.
Please rate this a FixYa
Jan 31, 2009 | Kenmore 74642 Gas Dryer
Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus Gas Dryer Logo
50 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
